产品名称: OPTIMESS
型  号:
品  牌: OPTIMESS
OPTImess laser sensors - due to their small size, high measurement frequency, and accuracy as well as their characteristic feature of being capable to operate in nearly all environmental conditions - are developing into a nearly universal measuring device in the areas of research & development, production, quality control and testing.
In geodesy, distance measurements by means of optical triangulation have been used for Ordnance Survey for a long time. On the basis of a known basic length and by defining two angles, it is hereby possible to determine exactly the position of a required point. The OPTImess sensors operate according to the same method.
The laser beam, which is projected by an optical installation, appears on the measuring object''s surface as a diffuse reflecting light spot. This spot is again projected by a second optical installation onto the detector. Each movement of the measuring object in the direction of the beam towards the receptor will result in a movement of the projected spot on the photo detector.
The OPTImess sensors have been developed for the exact measurement of measurable variables as, for example, positions, dimensions, vibrations and thicknesses in the industrial sector.
关 键 词: LASER SENSOR 激光测量 激光传感器
公司名称: 瑞士ELAG电子有限公司北京代表处
联 系 人: Sandy Zhang
电  话: 010-51285271
手  机:
地  址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮  编: 100016
轨道叉道段测量
车轮踏面轮廓测量----
轮对在线测量台----E
OPTIMESS MR
偏心率测量
抗强太阳光干扰--OPT
水平度测量
车轮踏面轮廓在线测量系统
ELAG OPTIMES
抗强太阳光干扰-OPTI
瑞士OPTIMESS铁路
赛车
宽度测量
ELAG OPTIMES
厚度测量(单轨和多轨)
重叠测量
零配件工业
轨道车车轮轮廓的监测
ELAG OPTIMES
