Vision Pro & MVS-8000为康耐视强有力的最新PC架构的视觉开发工具。此款以COM/ActiveX为基础的视觉工具套间适用于MVS-8000系列影像撷取卡。具备强大功能,建构复杂运用的弹性,图形开发环境易于快速开发。
MVS-8501 |
File Download Link |
PC Requirements
166Mhz Pentium class CPU or Greater
(MMX required for PatMax software) |
An AGP-based video display adaptor with at least 8MB of RAM |
Direct Draw, and operating in a minimum 256 color mode. AGP is preferred. |
One open +5V/32-bit PCI expansion slot |
Optional: Microsoft VB.NET, Visual C++.NET(UNMANAGED),or C# |
Memory |
8MB FIFO |
Video Input
Up to four multiplexed analog cameras |
Supports standard and high-speed analog |
Supports high resolution,rapid reset,progressive scan,and interlaced cameras |
Selectable anti-aliasing filter for high image quality |
Parallel I/O |
16 bi-directional TTL I/O |
One line can be configured as trigger input |
One line can be configured as trigger output |
Opto-isolation available via a breakout box |
