| Number/型号 |
FSC3015-N |
FSC3015-N2 |
FSC3015-P |
FSC3015-P2 |
FSC3015-B |
FSC3015-B2 |
| Output Motnod/输出模式 |
NPN.NO |
NPN.NC |
PNP.NO |
PNP.NC |
二线.NO |
二线.NC |
| Scanning distance/检出距离 |
15mm |
| Recommened distance/建议距离 |
9mm |
| Standard sensing object/标准检测物 |
30*30*1铁 |
| Response frequwncy/反应频率 |
DC:600Hz/AC:20HZ |
| Hysteresis/磁滞 |
≤1O% ofsensing distance |
| Operating Voltage/工作电压 |
DC:12~24VDC±10%/AC:90~260V |
| Current consumption/消耗电流 |
DC:≤8mA No—Load/AC:2mA Max |
| Output Current/负载电流 |
DC:30V 200mA Max/AC:5-200mA Max |
| Leakage current/漏电流 |
DC:≤1.1mA no-Load/AC:2.OmA no-Load |
Residual voltage/残余电压 |
DC:≤1.5VDC/AC:≤4VAC |
| Operating temperature/工作温度范围 |
-20°C~+70°C |
| Housing/外观方式 |
ABS |
| Wiring method/也线方式 |
40φ*2M/3 Cores |
| Degree of portection/防水等级 |
IP66 |
