1、WIMA DC-LINK HC Metallized Polypropylene (PP) - Capacitors for DC-Link Applications
Special Features:
- Very high volume/capacitance ratio
- Self-healing, internal safety disconnector
- Versatile and safe contact configurations by screwable plates
- Dry construction without electrolyte or oil
- Very low disipation factor
- Negative capacitance change versus temperature
- Very low dielectric absorption
- According to RoHS 2002/95/EC
Electrical Data:
- Capacitance range: 85 mF to 4500 mF
- Rated voltages: 400 VDC, 800 VDC, 1600 VDC
- Capacitance tolerances: ±20%, ±10%, (±5% available subject to special enquiry)
- Operating temperature: –55+ C to +85° C (+100+ C available subject to special enquiry)
- Insulation resistance at +20+ C: ? 30 000 sec (M¸ x mF) (mean value: 100 000 sec)
- Measuring voltage: 100 V/1 min.
- Dissipation factors at +20° C: See General Data.
- Test voltage: 1.1 Ur , 2 sec
- Dielectric absorption: 0.05 %
- Voltage derating: A voltage derating factor of 1.35 % per K
- must be appliued from +85° C for DC
- voltages and from +75° C for AC voltages.
- Reliability: Operational life ? 100 000 hours at 40° C
- Failure rate:36 fit (0.5 x Ur and 40) C)
- Specific dissipation:See General Data.
2、WIMA FKP 1 Polypropylene (PP) Capacitors for Pulse Applications
Special Features:
- Extremely high pulse duty
- Self-healing
- Internal series connection
- Very low dissipation factor
- Switch mode power supplies
- Converters in drives and power electronics
- Deflection systems in monitors and TV-sets
- Electronic ballasts
Electrical Data:
- Capacitance range: 100 pF to 0.22 mF (E12-values on request)
- Rated voltages: 400 VDC, 630 VDC, 1000 VDC, 1250 VDC,
- 1600 VDC, 2000 VDC, 4000 VDC, 6000 VDC
- Capacitance tolerances: ±20%, ±10%, ±5% (other tolerances are available subject to special enquiry)
- Operating temperature range: –55+ C to +100+ C
- Climatic test category: 55/100/56 in accordance with IEC
- Insulation resistance at +20+ C: C T 0.1 mF: 1 x 105 M¸ (mean value: 5 x 105 M¸) C ? 0.1 mF: 30 000 sec (M,
xmF) (mean value: 100 000 sec)
- Test voltage: 2 Ur, 2 sec / 6 kV: 1.6 Ur, 2 sec.
- Maximum pulse rise time: See General Data.
- Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and
from +75+ C for AC voltages
- Reliability:
Operational life: 300 000 hours
Failure rate: 1 fit (0.5 x Ur and 40+ C)
3、WIMA MKP 2 Metallized Polypropylene (PP)
Special Features:
- High volume/capacitance ratio
- Self-healing
- Increased pulse duty from 250 VDC rated voltage
Electrical Data:
- Capacitance range: 1000 pF to 0.33 mF (E12-values on request)
- Rated voltages: 63 VDC, 100 VDC, 250 VDC, 400 VDC, 630 VDC, 1000 VDC
- Capacitance tolerances: ± 20%, ±10%, ±5%
- Test specifications: In accordance with IEC 60384-16 and EN 131 200
- Climatic test category: 55/085/56 in accordance with IEC
- Insulation resistance at +20+ C: 3 x 104 M¸(mean value: 1 x 105 M¸)
- Measuring voltage:Ur = 63 V: Utest = 50 V/1 min.
- Ur: 100 V: Utest = 100 V/1 min.
- Test voltage: 1.6 Ur, 2 sec.
- Maximum pulse rise time:See General Data.
- Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and from +75+ C for AC voltages
- Reliability:
Failure rate: 2 fit (0.5 x Ur and 40+ C)
4、WIMA MKP 10 Polypropylene (PP) Capacitors for Pulse Applications with Double-Sided Metallized Electrodes and Schoopage Contacts
Special Features:
- Pulse duty construction
- Self-healing
- TV and monitor sets
- Lighting
- Audio/video equipment
Electrical Data:
- Capacitance range: 1000 pF to 15 mF (E12-values on request)
- Rated voltages: 100 VDC, 250 VDC, 400 VDC, 630 VDC, 1000 VDC, 1600 VDC, 2000 VDC, 2500 VDC
- Operating temperature range: –55) C to +100) C
- Insulation resistance at +20+ C: C T 0.33 mF: 1 x 105 M¸(mean value: 5 x 105 M¸) C 0.33 mF: 30 000 sec (M¸ x mF) (mean value: 100 000 sec)
- Dissipation factors at + 20) C: See General Data.
- Voltage derating: A voltage derating factor of 1.35 % per K must be applied from +85+ C for DC voltages and from +75+ C for AC voltages.
- Reliability:
Failure rate: 1 fit (0.5 x Ur and 40) C)
More information, please refer to below web:
http://www.sansonic.com.cn
Brandon Wu
Shanghai Sansonic Electronics Co.,LTD
TEL: +86 21-55128778*808
FAX: +86 21-67115334
Mobile: 13636360451
Add:Room 909, NO.2158, Siping Road, Yangpu District Shanghai
Post Code: 201206
Web: http://www.sansonic.com.cn
