项目简介:
上海污水处理自控系统一般包括污水厂部分和厂外泵站部分。工业计算机和工业以太网组成的监控系统通讯网络和PLC是污水处理自动化系统的核心组成部分,它们的性能对污水处理自动化系统会起到决定性的作用。在上海污水处理自动控制系统中,由于地处潮湿、苛刻温度变化的环境要求,对工业计算机的性能提出了更高的要求。作为污水处理自动控制系统的信息控制首脑位置,其本身必须稳定可靠,并具有预先处理数据和集中传输数据的能力,具有较高的故障保护能力,须综合考虑整个监控系统的性能要求和自然条件以及运营周期对设备的要求进行选择,需要选择性能更好的2U无风扇工控机。所以,在该项目的工控机选型上,我们采用瑞强AE468MD-FL工控机和AE-NF202无风扇工控机。
The sewage treatment automatic control system mainly includes the sewage plant and outside plant pump. The major components of sewage treatment system arethe control & monitoring system communication network and PLC composed by industrial computer and ethernet.For harsh environment requirements of humidity and variable temperature, Shanghai sewage treatment system has higher requirements for industrial computer performance. As the system control center, the products have to have the data pre-processing and central-transferring capacity with the feature of stability and reliability, and higher fault protection. Nematron 2U fanless IPC fulfill all the requirements of integrated monitoring system performance, natural condition and operation circle. Nematron AE468MD-FL and AE-NF202 have been chosen to be the equipment of this project.
应用领域:能源\水处理\环保
所用我司产品:AE468MD-FL、AE-NF202
AE468MD-FL
AE-NF202
系统解决方案:
