Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Î÷ÃÅ×ÓCPU417
²úÆ·Ãû³Æ£º Î÷ÃÅ×ÓCPU417
ÐÍ ºÅ£º 6ES7 417-4XT05-0AB0
Æ· ÅÆ£º 1
Î÷ÃÅ×ÓCPU417¶©»õºÅ£º
S7400/300/200CPU¶¼ÓÐÏÖ»õ£¬ÏÂÃæÊǾßÌå¶©»õºÅ£º
6ES7 412-3HJ14-0AB0 CPU 412-3H; 512KB³ÌÐòÄÚ´æ/256KBÊý¾ÝÄÚ´æ
6ES7 414-4HM14-0AB0 CPU 414-4H; ÈßÓàÈȱ¸CPU 2.8 MB RAM
6ES7 417-4HT14-0AB0 CPU 417-4H; ÈßÓàÈȱ¸CPU 30 MB RAM
6ES7 400-0HR00-4AB0 412H ϵͳÌ×¼þ°üÀ¨ 2 ¸öCPU¡¢1¸öHÐÍÖÐÑë»ú¼Ü¡¢2¸öµçÔ´¡¢2¸ö1M ´æ´¢¿¨¡¢4¸öͬ²½Ä£¿é¡¢2¸ùͬ²½µçÀ£¬ÒÔ¼°4¸ö±¸ÓÃµç³Ø(PS407 10A)
6ES7 400-0HR50-4AB0 412H ϵͳÌ×¼þ°üÀ¨ 2 ¸öCPU¡¢1¸öHÐÍÖÐÑë»ú¼Ü¡¢2¸öµçÔ´¡¢2¸ö1M ´æ´¢¿¨¡¢4¸öͬ²½Ä£¿é¡¢2¸ùͬ²½µçÀ£¬ÒÔ¼°4¸ö±¸ÓÃµç³Ø(PS405 10A)
6ES7 412-1XJ05-0AB0 CPU412-1,144KB³ÌÐòÄÚ´æ/144KBÊý¾ÝÄÚ´æ
6ES7 412-2XJ05-0AB0 CPU412-2,256KB³ÌÐòÄÚ´æ/256KBÊý¾ÝÄÚ´æ
6ES7 414-2XK05-0AB0 CPU414-2,512KB³ÌÐòÄÚ´æ/512KBÊý¾ÝÄÚ´æ
6ES7 414-3XM05-0AB0 CPU414-3,1.4M³ÌÐòÄÚ´æ/1.4MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 414-3EM05-0AB0 CPU414-3PN/DP 1.4M³ÌÐòÄÚ´æ/1.4MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-2XN05-0AB0 CPU416-2,2.8M³ÌÐòÄÚ´æ/2.8MÊý¾ÝÄÚ´æ
6ES7 416-3XR05-0AB0 CPU416-3,5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-3ER05-0AB0 CPU416-3PN/DP 5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-2FN05-0AB0 CPU416F-2,2.8M³ÌÐòÄÚ´æ/2.8MÊý¾ÝÄÚ´æ
6ES7 416-3FR05-0AB0 CPU416F-3PN/DP,5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ
6ES7 417-4XT05-0AB0 CPU417-4,15M³ÌÐòÄÚ´æ/15MÊý¾ÝÄÚ´æ
6ES7 312-1AE13-0AB0 CPU312£¬32KÄÚ´æ
6ES7 312-5BE03-0AB0 CPU312C£¬32KÄÚ´æ 10DI/6DO
6ES7 313-5BF03-0AB0 CPU313C£¬64KÄÚ´æ 24DI/16DO / 4AI/2AO
6ES7 313-6BF03-0AB0 CPU313C-2PTP£¬64KÄÚ´æ 16DI/16DO
6ES7 313-6CF03-0AB0 CPU313C-2DP£¬64KÄÚ´æ 16DI/16DO
6ES7 314-1AG13-0AB0 CPU314,96KÄÚ´æ
6ES7 314-6BG03-0AB0 CPU314C-2PTP 96KÄÚ´æ 24DI/16DO / 4AI/2AO
6ES7 314-6CG03-0AB0 CPU314C-2DP 96KÄÚ´æ 24DI/16DO / 4AI/2AO
6ES7 315-2AG10-0AB0 CPU315-2DP, 128KÄÚ´æ
6ES7 315-2EH13-0AB0 CPU315-2 PN/DP, 256KÄÚ´æ
6ES7 317-2AJ10-0AB0 CPU317-2DP,512KÄÚ´æ
6ES7 317-2EK13-0AB0 CPU317-2 PN/DP,1MBÄÚ´æ
6ES7 318-3EL00-0AB0 CPU319-3 PN/DP,1.4MÄÚ´æ
6ES7 211-0AA23-0XB0 CPU221 DC/DC/DC,6ÊäÈë/4Êä³ö
6ES7 211-0BA23-0XB0 CPU221 ¼ÌµçÆ÷Êä³ö,6ÊäÈë/4Êä³ö
6ES7 212-1AB23-0XB8 CPU222 DC/DC/DC,8ÊäÈë/6Êä³ö
6ES7 212-1BB23-0XB8 CPU222 ¼ÌµçÆ÷Êä³ö,8ÊäÈë/6Êä³ö
6ES7 214-1AD23-0XB8 CPU224 DC/DC/DC,14ÊäÈë/10Êä³ö
6ES7 214-1BD23-0XB8 CPU224 ¼ÌµçÆ÷Êä³ö,14ÊäÈë/10Êä³ö
6ES7 214-2AD23-0XB8 CPU224XP DC/DC/DC,14DI/10DO,2AI/1AO
6ES7 214-2BD23-0XB8 CPU224XP ¼ÌµçÆ÷Êä³ö,14DI/10DO,2AI/1AO
6ES7 216-2AD23-0XB8 CPU226 DC/DC/DC,24ÊäÈë/16Êä³ö
6ES7 216-2BD23-0XB8 CPU226 ¼ÌµçÆ÷Êä³ö,24ÊäÈë/16Êä³ö
Î÷ÃÅ×ÓCPU417²úÆ·ÐÅÏ¢¼°²ÎÊý£»
Overview
  • ¹¦ÄÜÇ¿´óµÄ SIMATIC S7-400 CPU
  • ¿ÉÓÃÔÚ¸ßÐÔÄÜ·¶Î§ÖÐ×ÔÓµÄ×°ÖÃ
  • ÓÐ 2 ¸ö IF Ä£¿é²å²Û
go up
Area of application
The CPU 417-4 is the most powerful SIMATIC S7-400 CPU. The integral PROFIBUS DP interfaces permit direct connection to the PROFIBUS DP fieldbus as master or slave.
Two further DP master systems can be connected via the IF 964-DP interface submodules.
Note :
Only the interface module 6ES7 964-2AA04-0AB0 can be used.
go up
Design
The CPU 417-4 has:
  • Powerful processor:
    The CPU achieves instruction execution times as low as 0.018 µs per binary instruction.
  • 30 MB RAM (of which 15 MB each for program and data);
    fast RAM for parts of the user program relevant to execution.
  • Flexible expansion:
    Up to 262144 digital and 16384 analog inputs/outputs.
  • Multi-point interface MPI:
    With the MPI it is possible to establish simple networking of max. 32 stations at a data transmission rate of up to 12 Mbit/s. The CPU can establish up to 44 connections to stations of the communications bus (C bus) and the MPI.
    Note:
    If the PROFIBUS DP interface and MPI interface are operated simultaneously, it is only possible to connect the following bus connector to the MPI interface:
    • With socket: 6ES7 972-0BB41-0XA0
    • Without socket: 6ES7 972-0BA41-0XA0
  • Mode selector switch:
    Designed as toggle switch.
  • Diagnostics buffer:
    The last 120 fault and interrupt events are retained in a ring buffer for diagnostic purposes (extendable).
  • Real-time clock:
    The date and time are appended to diagnostic messages of the CPU.
  • Memory card:
    For expansion of the integrated load memory. The information in the load memory comprises S7-400 parameterization data in addition to the program and therefore requires twice as much memory space. The result is:
    • The integral load memory is not sufficient for large programs, therefore a memory card is frequently required.
      RAM and FEPROM cards (FEPROM for retentive storage) are available
  • PROFIBUS DP interface:
    The PROFIBUS DP master interface allows a distributed automation configuration offering high speed and ease of use. From the user''s point of view, the distributed I/O is treated as central I/O (same configuring, addressing, and programming).
    Mixed configuration: SIMATIC S5 with SIMATIC S7 as PROFIBUS master to EN 50170.
    Note:
    If the PROFIBUS DP and MPI interface are operated simultaneously, it is only possible to connect the following bus connectors to the MPI interface:
  • Two additional slots:
    Two additional PROFIBUS DP master systems can be connected via IF 964-DP interface modules.
go up
Functions
  • Block protection:
    a password concept also protects the user program from unauthorized access
  • Integrated HMI services:
    The user only has to specify the source and destination of the data with HMI devices. The data are then transported cyclically and automatically by the system.
  • Integrated communication functions:
    • PG/OP communication
    • Global data communication
    • S7 standard communication
    • S7 communication
Configurable Attributes
The STEP 7 tool "Hardware configuration" can be used to program the properties and response of the S7-400 including the CPUs, e.g.
  • Multipoint interface MPI:
    • Definition of node addresses
    • Startup/cycle behavior
    • Stipulation of the maximum cycle time and communication load
  • Address allocation:
    Addressing of I/O modules
  • Retentive area:
    Definition of the number of retentive bit memories, counters, timers, data blocks, and clock memories
  • Size of the process image, local data
  • Length of the diagnostics buffer
  • Protection level:
    Definition of access authorizations to program and data
  • System diagnostics:
    Definition of the handling and scope of diagnostics messages
  • Timed interrupts:
    Setting of periods
  • Configuring
Reporting functions
  • Status and fault indicators:
    LEDs indicate internal and external faults and operating modes such RUN, STOP, restart, test function, etc.
  • Test functions:
    The PG can be used to display signal states in program execution, modify process tags irrespective of the user program, read out the contents of stack memories, run separate program steps and inhibit program components.
  • Information functions:
    The PG can be used to provide the user with information about the memory capacity and operating mode of the CPU, and the current utilization of the working and load memories.
go up
Technical Specifications
6ES7 417-4XT05-0AB0
CPU 417-4
Ò»°ãÐÅÏ¢
Ó²¼þ²úÆ·ÐͺÅ
04
¹Ì¼þÐͺÅ
V5.3
¹¤³Ì×é̬
  • ±à³ÌÈí¼þ°ü
STEP 7 V5.3 SP2 »ò¸ü¸ß£¬´øÓ²¼þ¸üÐÂ
CiR - ÔÚ RUN ģʽÏÂ×é̬
CiR ͬ²½Ê±¼ä£¬»ù±¾¸ºÔØ
60 ms
CiR ͬ²½Ê±¼ä,ÿ¸ö I/O ´ÓÕ¾µÄʱ¼ä
7 µs
µçÔ´µçѹ
24 V DC
¡Á£»µçԴͨ¹ýϵͳµçÔ´Ìṩ
ÊäÈëµçÁ÷
´Ó±³°å×ÜÏß 5 V DC£¬×î´ó
1.8 A
´Ó½Ó¿Ú 5 V DC£¬×î´ó
90 mA£»ÔÚÿ¸ö DP ½Ó¿Ú´¦
¹¦ºÄ
¹¦ºÄ£¬µäÐÍÖµ
7.5 W
¹¦ºÄ£¬×î´ó
8 W
´æ´¢Æ÷
¹¤×÷´æ´¢Æ÷
  • ¼¯³É
30 Õ××Ö½Ú
  • ¼¯³É£¨ÓÃÓÚ³ÌÐò£©
15 Õ××Ö½Ú
  • ¼¯³É£¨ÓÃÓÚÊý¾Ý£©
15 Õ××Ö½Ú
  • ¿ÉÀ©Õ¹
X
×°ÔØ´æ´¢Æ÷
  • ¿ÉÀ©Õ¹ FEPROM
¡Ì£»´ø´æ´¢¿¨(FLASH)
  • ¿ÉÀ©Õ¹µÄ FEPROM,×î´ó
64 Õ××Ö½Ú
  • ÄÚÖà RAM£¬×î´ó
1 Õ××Ö½Ú
  • ¿ÉÀ©Õ¹ RAM
¡Ì£»´ø´æ´¢Æ÷¿¨ (RAM)
  • ¿ÉÀ©Õ¹µÄ RAM£¬×î´ó
64 Õ××Ö½Ú
ºó±¸
  • Ìṩ
¡Ì
  • ´øµç³Ø
¡Ì£»ËùÓÐÊý¾Ý
  • ÎÞµç³Ø
X
CPU ´¦Àíʱ¼ä
λ²Ù×÷£¬×îС
18 ns
×Ö²Ù×÷£¬×îС
18 ns
¶¨µãÊýÔËË㣬×îС
18 ns
¸¡µãÊýÔËË㣬×îС
54 ns
CPU ¿é
DB
  • ÊýÁ¿£¬×î´ó
16 000£»±àºÅ·¶Î§£º1 ÖÁ 16000
  • ÈÝÁ¿£¬×î´ó
64 kbyte
FB
  • ÊýÁ¿£¬×î´ó
8 000£»±àºÅ·¶Î§£º0 ÖÁ 7999
  • ÈÝÁ¿£¬×î´ó
64 kbyte
FC
  • ÊýÁ¿£¬×î´ó
  • ÈÝÁ¿£¬×î´ó
64 kbyte
OB
  • ÈÝÁ¿£¬×î´ó
64 kbyte
ǶÌ×Éî¶È
  • ÿ¸öÓÅÏȼ¶
24
  • ÔÚÒ»¸ö´íÎóOBÖи½¼Ó
2
¼ÆÊýÆ÷¡¢¶¨Ê±Æ÷¼°Æä±£³ÖÐÔ
S7 ¼ÆÊýÆ÷
  • ÊýÁ¿
2 048
  • ¼ÇÒäÐÔ
    • ¿Éµ÷½Ú
¡Ì
    • ÏÂÏÞ
0
    • ÉÏÏÞ
2 047
    • Ô¤ÖÃ
Z 0 ÖÁ Z 7
  • ¼ÆÊý·¶Î§
    • ÏÂÏÞ
0
    • ÉÏÏÞ
999
IEC ¼ÆÊýÆ÷
  • Ìṩ
¡Ì
  • ÐͺÅ
SFB
  • ÊýÁ¿
²»ÏÞ£¨Ö»È¡¾öÓÚ RAM ÈÝÁ¿£©
S7 ¶¨Ê±Æ÷
  • ÊýÁ¿
2 048
  • ¼ÇÒäÐÔ
    • ¿Éµ÷½Ú
¡Ì
    • ÏÂÏÞ
0
    • ÉÏÏÞ
2 047
    • Ô¤ÖÃ
ÎÞ±£³Ö¶¨Ê±Æ÷
  • ʱ¼ä·¶Î§
    • ÏÂÏÞ
10 ms
    • ÉÏÏÞ
9 990 s
IEC ¶¨Ê±Æ÷
  • Ìṩ
¡Ì
  • ÐͺÅ
SFB
  • ÊýÁ¿
Êý¾ÝÇø¼°Æä±£³ÖÐÔ
±£³ÖÊý¾ÝÇøÓò£¬×ܹ²
×ܹ¤×÷´æ´¢Æ÷ºÍ×°Èë´æ´¢Æ÷£¨´øÓб¸ÓÃµç³Ø£©
±êÖ¾
  • ÊýÁ¿£¬×î´ó
16 KB£»Î»´æ´¢Æ÷µØÖ·Çø´óС
  • ¿É±£³Ö
¡Ì
  • Ô¤Éè±£³ÖÐÔ
MB 0 - MB 15
  • ʱÖÓ´æ´¢Æ÷µÄÊýÁ¿
8; (1¸ö´æ´¢×Ö½Ú)
¾Ö²¿Êý¾Ý
  • ¿Éµ÷½Ú£¬×î´ó
64 kbyte
  • Ô¤ÖÃ
32 kbyte
µØÖ·Çø
I/O µØÖ·Çø
  • ÊäÈë
16 kbyte
  • Êä³ö
16 kbyte
  • ÆäÖзֲ¼Ê½
    • MPI/DP ½Ó¿Ú£¬ÊäÈë
2 kbyte
    • MPI/DP ½Ó¿Ú£¬Êä³ö
2 kbyte
    • DP ½Ó¿Ú£¬ÊäÈë
8 kbyte
    • DP ½Ó¿Ú£¬Êä³ö
8 kbyte
¹ý³ÌÓ³Ïñ
  • ÊäÈ룬¿Éµ÷½Ú
16 kbyte
  • Êä³ö£¬¿Éµ÷½Ú
16 kbyte
  • ĬÈÏÊäÈë
1,024 ×Ö½Ú
  • ĬÈÏÊä³ö
1,024 ×Ö½Ú
  • Ò»ÖÂÐÔÊý¾Ý£¬×î´ó
244 ×Ö½Ú
  • ·ÃÎʹý³ÌÓ³ÏñÖеÄÒ»ÖÂÐÔÊý¾Ý
¡Ì
×Ó¹ý³ÌÓ³Ïñ
  • ×Ó¹ý³ÌÓ³ÏñµÄÊýÁ¿£¬×î´ó
15
Êý×ÖÁ¿Í¨µÀ
  • ÊäÈë
131 072
  • Êä³ö
131 072
  • ÖÐÑëÇøµÄÊäÈëͨµÀ
131 072
  • ÖÐÑëÇøµÄÊä³öͨµÀ
131 072
Ä£ÄâÁ¿Í¨µÀ
  • ÊäÈë
8 192
  • Êä³ö
8 192
  • ÖÐÑëÇøµÄÊäÈëͨµÀ
8 192
  • ÖÐÑëÇøµÄÊä³öͨµÀ
8 192
Ó²¼þ×é̬
À©Õ¹É豸£¬×î´ó
21
¶àCPUÔËÐÐ
¡Ì£»×î¶à 4 ¸ö CPU£¨´ø UR1 »ò UR2£©
½Ó¿ÚÄ£¿é
  • ¿ÉÁ¬½ÓµÄÈ«²¿ IM ÊýÁ¿£¬×î¶à
6
  • ¿ÉÁ¬½ÓµÄ IM460 ÊýÁ¿£¬×î¶à
6
  • ¿ÉÁ¬½ÓµÄ IM463 ÊýÁ¿£¬×î¶à
4; IM 463-2
DPÖ÷Õ¾µÄÊýÁ¿
  • ¼¯³É
2
  • ͨ¹ý IM 467
4
  • ͨ¹ý CP
10£»CP 443-5 À©Õ¹
  • ÔÊÐí IM+CP »ìºÏģʽ
¡Á£»IM 467 ²»ÊÊÓÃÓÚ CP 443-5 Ext.¼° CP443-1 EX4x¡¢EX20¡¢GX20£¨PNIO ģʽ£©
  • ͨ¹ý½Ó¿ÚÄ£°å
2
  • ¿É²åÈë S5 Ä£°åµÄÊýÁ¿(ͨ¹ýÊÊÅäÆ÷)£¬×î¶à
6
IO ¿ØÖÆÆ÷µÄÊýÁ¿
  • ¼¯³É
0
  • ͨ¹ý CP
4£»²»Óë CP443-1 EX40 ¼° CP443-1 EX 41/EX20/GX20 »ìºÏ²Ù×÷£¬ÖÐÑë¿ØÖÆÆ÷ÖÐ×î¶àΪ 4 ¸ö
¿ÉÔËÐÐµÄ FM ºÍ CP ÊýÁ¿£¨ÍƼö£©
  • FM
Êܲå²ÛÊýºÍ½Ó¿ÚÊýµÄÏÞÖÆ
  • CP£¬µãµ½µã
CP 440£ºÊܲå²ÛÊýÏÞÖÆ£»CP 441£ºÊÜÁ¬½ÓÊýÏÞÖÆ
  • PROFIBUS ºÍ Ethernet CPs
14£»ÆäÖÐ×î¶àÓÐ 10 ¸ö CP »ò IM ×÷Ϊ DP Ö÷Õ¾£¬×î¶àÓÐ 4 ¸ö PN ¿ØÖÆÆ÷
ʱ¼ä
ʱÖÓ
  • Ó²¼þʱÖÓ£¨ÊµÊ±Ê±ÖÓ£©
¡Ì
  • µç³Øºó±¸ºÍ¿Éͬ²½
¡Ì
  • ·Ö±æÂÊ
1 ms
  • ÿÌìÎó²î£¨»º´æ£©£¬×î´ó
1.7s£»µôµç
  • ÿÌìÎó²î£¨Î´»º´æ£©£¬×î´ó
8.6s£»Í¨µç
ÔËÐÐСʱ¼ÆÊýÆ÷
  • ÊýÁ¿
16
  • ÊýÁ¿/ÊýÁ¿·¶Î§
0 ÖÁ 15
¹«Ë¾Ãû³Æ£º ÉϺ£ÔÞ¹ú×Ô¶¯»¯¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 31129608 / »Æ³¬
ÊÖ»ú£º 13764683783
µØ Ö·£º ÉϺ£Ëɽ­ÇøË¼ÏÍ·1855Ū91ºÅ
ÓÊ ±à£º 201600
Ö÷ Ò³£º http://
  • DP×ÜÏߣ¨ÏÖ³¡×ÜÏߣ©
  • Î÷ÃÅ×ÓDP×ÜÏß
  • Î÷ÃÅ×ÓDP²åÍ·
  • 6SE6420-2UD21-1AA1
  • 6SE6420-2UD21-5AA1
  • 6SE6420-2UD22-2BA1
  • 6SE6440-2UC11-2AA1
  • 6SE6440-2UC12-5AA1
  • 6SE6440-2UC13-7AA1
  • 6SE6440-2UC15-5AA1
