ÐͺÅ
EB-C1030WN
ͶӰϵͳ
RGB ¹â·§Ê½Òº¾§Í¶Ó°ÏµÍ³
Ö÷Òª²¿¼þ¼¼Êõ²ÎÊý
LCD
Òº¾§°å
0.59Ó¢´çº¬Î¢Í¸¾µ
Çý¶¯Ä£Ê½
¶à¾§¹è TFTÓÐÔ´¾ØÕó
ÏñËØÊý
1,024,000 dots (1280 x 800) x 3
·Ö±æÂÊ
WXGA
×ݺá±È
16:10
ͶӰ¾µÍ·
ÊÖ¶¯¾Û½¹£¬1.6 ±¶¹âѧ±ä½¹ F=1.51-1.99 / f=18.2 mm-29.2 mm
µÆÅÝ*1
ÀàÐÍ
275W UHE (E-TORL)
²Î¿¼ÊÙÃü
3000 Сʱ (±ê׼ģʽ )
ÆÁÄ»³ß´ç£¨Í¶Ó°¾àÀ룩
29Ó¢´çµ½ 280Ó¢´ç [0.84 µ½ 13.7m]
Æ«ÒÆÁ¿
10:0
ÁÁ¶È *2*3
°×É«ÁÁ¶È
±ê׼ģʽ
3500 Á÷Ã÷
»·±£Ä£Ê½
2800 Á÷Ã÷
É«²ÊÁÁ¶È
±ê׼ģʽ
3500 Á÷Ã÷
»·±£Ä£Ê½
2800 Á÷Ã÷
¶Ô±È¶È *2*3
2000:1
É«²ÊÔÙÏÖ
È«²Ê (1677ÍòÉ« )
ÉùÒôÊä³ö
5 W
ÆäËü¹¦ÄÜ
Óû§±êʶ¸ü¸Ä¹¦ÄÜ£¬»Ãæ¶³½á¹¦ÄÜ£¬ÐźÅÔ´×Ô¶¯ËÑË÷
ÓÐЧɨÃèÆµ¶Î ( Ä£Äâ )
µãʱÖÓ
13.5 MHz to 162 MHz, ×î¸ßµ½ UXGA 60 Hz
ˮƽ
15 kHz to 92 kHz
´¹Ö±
50 Hz to 85 Hz
ÓÐЧɨÃèÆµ¶Î ( Êý×Ö )
µãʱÖÓ
ˮƽ
15 kHz to 75 kHz
´¹Ö±
24/30/50/60 Hz
Ä£Äâ RGB ÊäÈë / Êä³ö
ʵ¼Ê·Ö±æÂÊ
1280 x 800 µã
ÊäÈë¶Ë¿Ú
ÊÓÆµ
D-sub 15pin x 2
Stereo mini jack x 2
Êä³ö¶Ë¿Ú
ÊÓÆµ
D-sub 15pin x 1
Stereo mini jack x 1
ÊÓÆµÊäÈë / Êä³ö
ÊÓÆµ±ê×¼
NTSC / NTSC4.43 / PAL / M-PAL / N-PAL / PAL60 / SECAM
ÊäÈë¶Ë¿Ú
ÊÓÆµ
¸´ºÏÊÓÆµ£ºRCA ( »Æ ) x 1£¬S-Video£ºÃÔÄãDIN x 1
·ÖÁ¿ÊÓÆµ : D-sub 15pin x 2
ÊÓÆµ RGB: D-sub 15pin x 2
RCA£¨°×£¬ºì£©× 1 ¶Ô
HDMI
ʵ¼Ê·Ö±æÂÊ
1280 x 720 µã (720p)
ÊÓÆµ±ê×¼
480i / 576i / 480p / 576p / 720p / 1080i / 1080p
ÊäÈë¶Ë¿Ú
HDMI x 1
HDCP
ÊÇ
ÍøÂç
ÓÐÏß
RJ45 x 1 100Mbps
ÎÞÏß
Ñ¡Åä
²Ù×÷ζÈ
0 ¡æ to 40 ¡æ <32 °F to 104 °F> ( ʪ¶È20%¡« 80%£¬ÎÞÄý½á)
²Ù×÷º£°Î*4
0Ã×µ½2000Ã×£¨³¬¹ý1500Ã×ÇøÓò£ºÓ¦ÓÃÓڸߺ£°Îģʽ£©
Ö±½Ó¿ª»ú
ÊÇ
Ö±½Ó¹Ø»ú
ÊÇ
Æô¶¯Ê±¼ä
´óÔ¼ 6 Ã룬ԤÈÈʱ¼ä£º30Ãë
Àäȴʱ¼ä
0 Ã루¹Ø»úºó·çÉÈÁ¢¼´Í£×ª£©
µçÔ´µçѹ
110 - 240 V AC +/- 10%, 50/60 Hz
¹¦ºÄ£¨220-240V£©
ÔËÐÐ
380 W
´ý»ú£¨Í¨Ñ¶¹Ø±Õ£©
0.38 W
³ß´ç£¨³¤×¿í׸ߣ©£¨²»°üÀ¨Í¶Ó°»ú½Å¶¤£©
450×274×114 mm
ÖØÁ¿
Approx. 9.7 lbs. / 4.4 kg
·çÉÈÔëÒô
»·±£ÁÁ¶Èģʽ
33 dB
