²úÆ·Ãû³Æ£º
Ô×°ABBµçÁ¦µçÈÝÆ÷
ÐÍ ºÅ£º
CLMD43/15KVAR 4
10011767 CLMD53/32KVAR 230V 50Hz
10034869 CLMD53/33KVAR 500V 60Hz
10036713 CLMD13/13.5KVAR 415V 50Hz
10060486 CLMD33/25KVAR 473V 50HZ
10060888 CLMD13/12.5KVAR 400V 50HZ
10066184 CLMD63/50KVAR 550V 60Hz
10057368 CLMD13/3KVAR 250V 50HZ (1 ph)
10058756 CLMD33/15KVAR 220V 50HZ
10055483 CLMD43/21KVAR 690V50HZ
10050724 CLMD43/25KVAR 480V 50Hz
10091888 CLMD33/28.1KVAR 440V 50HZ
10079976 CLMD43/30 KVAR 500V 50HZ
10083830 CLMD43/15KVAR 690V 50Hz
10084525 CLMD53/40KVAR 450V 50HZ
10083831 CLMD43/10KVAR 690V 50Hz
10083843 CLMD13/10KVAR 690V 50HZ
10090534 CLMD43/20.8 KVAR 480V 50Hz
10090536 CLMD63/60.8 KVAR 480V 50Hz
10074299 CLMD13/5KVAR 440V 50HZ
65100029 CLMD53/42KVAR 660V 50Hz
65100015 CLMD63/60KVAR 400V 50Hz
65100005 CLMD13/10KVAR 400V 50Hz
65100007 CLMD43/15KVAR 400V 50Hz
65100018 CLMD53/40KVAR 415V 50Hz
10094484 CLMD43/5.4KVAR 500V 50HZ
10094950 CLMD63/67KVAR 440V 50HZ
10095522 CLMD43/30KVAR 450V 50HZ
10095503 CLMD13/3.5KVAR 400V 50HZ
10099259 CLMD53/25KVAR 230V 50HZ
10099830 CLMD53/35KVAR 480V 60HZ
10095953 CLMD53/40KVAR 400V 50HZ(1 PH)
10099462 CLMD63/75KVAR 525V 50HZ
10099834 CLMD43/10KVAR 400V 50HZ(1PH)
10040151 CLMD53/53KVAR 660V 50Hz
10035197 CLMD63/60KVAR 480V 50Hz
10041289 CLMD53/40KVAR 480V 50Hz
10061129 CLMD63/65KVAR 480V 50Hz
10069229 CLMD13/5KVAR 440V 50HZ (1 ph)
10069228 CLMD13/9KVAR 440V 50HZ (1 ph)
10065621 CLMD43/22KVAR 415V 50Hz
10055448 CLMD63-45KVAR 400V 60HZ
10063049 CLMD53/40KVAR 460V 50Hz
10075246 CLMD43/20KVAR 400V 50H (1 PH)
10091887 CLMD63/60KVAR 690V 50HZ
10092315 CLMD43/7KVAR 440V 50HZ(1 PH)
10093043 CLMD83/100KVAR 500V 50HZ
10080493 CLMD13/15KVAR 500V50HZ
10091974 CLMD43/5KVAR 200V 50HZ
65100010 CLMD43/30KVAR 400V 50Hz
65100027 CLMD53/32KVAR 460V 60Hz
65100003 CLMD63/48KVAR 230V50Hz
65100008 CLMD43/20KVAR 400V 50Hz
65100011 CLMD53/30KVAR 400V 50Hz
10094421 CLMD53/50KVAR 415V 50HZ
10099706 CLMD33/17.3KVAR 430V 50HZ
10095952 CLMD53/30KVAR 400V 50HZ(1 PH)
10096828 CLMD13/13.8KVAR 420V 50HZ
10099854 CLMD33/30KVAR 440V 50HZ
10025115 CLMD83/100KVAR 460V 50Hz
10011613 CLMD33/12.5KVAR 400V 50Hz
10036714 CLMD53/37KVAR 480V 50Hz
10051111 CLMD13 /5KVAR 400V 50Hz
10051275 CLMD13/8KVAR 400V 50HZ
10072578 CLMD63/60KVAR 480V 60HZ
10051122 CLMD13 /8KVAR 480V 50Hz
10069582 CLMD43/28KVAR 440V 50Hz
10061001 CLMD53/38KVAR 660V 60Hz
10071561 CLMD63/45KVAR 480V 60HZ
10069227 CLMD13/7KVAR 440V 50HZ (1 ph)
10069230 CLMD13/6KVAR 440V 50HZ (1 ph)
10054544 CLMD43/23KVAR 460V 50HZ
10054539 CLMD13/10KVAR 525V 50HZ
10059543 CLMD53/50KVAR 480V 50Hz
10078904 CLMD53/20KVAR 400V 50Hz (Y)
10091886 CLMD53/30KVAR 690V 50HZ
10086026 CLMD53/45KVAR 500V50HZ
65100020 CLMD43/25KVAR 440V 50Hz
65100033 CLMD63/75KVAR 480V 50Hz
10095505 CLMD43/15KVAR 600V 50HZ
10095504 CLMD13/12KVAR 600V 50HZ
10095731 CLMD63/70KVAR 750V 50HZ
10099349 CLMD43/10KVAR 400V 50HZ(Y)
10099350 CLMD43/3.3KVAR 400V 50HZ(1PH)
10099751 CLMD53/20KVAR 480V 50HZ
10099898 CLMD53/45KVAR 750V 50HZ
10012679 CLMD63/66KVAR 250V 50Hz
10012236 CLMD13/14KVAR 440V 50Hz
10040274 CLMD33/12.5KVAR 400V 50Hz(350mm)
10034714 CLMD53/30KVAR 440V 50Hz
10036336 CLMD13/12KVAR 440V 50Hz
10066181 CLMD43/25KVAR 550V 60Hz
10063286 CLMD13/14KVAR 762V 50HZ
10061053 CLMD53/35KVAR 400V 50Hz
10061130 CLMD43/27KVAR 415V 50Hz
10069288 CLMD33/30KVAR 400V 50Hz
10069581 CLMD63/57KVAR 440V 50Hz
10054541 CLMD43/30KVAR 525V 50HZ
10093018 CLMD53/36KVAR 500V 50HZ
10085123 CLMD53/45KVAR 480V 50HZ
10085296 CLMD63/60KVAR 460V 50HZ
10077021 CLMD63/56KVAR 440V 50Hz
10090537 CLMD43/22.5 KVAR 525V 50Hz
10091973 CLMD43/2.5KVAR 200V 50HZ
10090539 CLMD63/67.8 KVAR 525V 50Hz
10074279 CLMD83/70KVAR 460V 50HZ
10092316 CLMD43/15KVAR 440V 50HZ(1 PH)
10081458 CLMD63/40KVAR 280V50HZ
10094349 CLMD53/50KVAR 400V 50HZ
65100030 CLMD63/53KVAR 660V 50Hz
65100021 CLMD53/35KVAR 440V 50Hz
65100019 CLMD43/20KVAR 440V 50Hz
10095498 CLMD63/80KVAR 525V 50Hz
10095509 CLMD43/8KVAR 400V 50HZ(1PH)
10099258 CLMD63/35KVAR 277V 50HZ
10099829 CLMD83/90KVAR 440V 50HZ
10099832 CLMD33/17.3KVAR 430V 50HZ
10099752 CLMD43/20KVAR 400V 50HZ
10099683 CLMD13/11.5KVAR 690V 50HZ
10099464 CLMD53/18KVAR 950V 50HZ(1 PH)
10099465 CLMD53/36KVAR 950V 50HZ(1 PH)
10039912 CLMD83/100KVAR 480V 50Hz
10040275 CLMD33/25KVAR 400V 50Hz(600mm)
10035198 CLMD63/80KVAR 480V 50Hz
10039626 CLMD43/20KVAR 690V 50Hz
10039625 CLMD43/25KVAR 690V 50Hz
10055449 CLMD13-5.5KVAR 400V 50HZ
10057367 CLMD53/30KVAR 415V 50HZ
10057370 CLMD63/60KVAR 280V 50HZ
10072915 CLMD83/100KVAR 600V 50HZ
10054717 CLMD43/30KVAR 440V50HZ
10064265 CLMD13/10KVAR 440V 50HZ
10085665 CLMD53/9.5KVAR 250V 50HZ(Y)
10074281 CLMD63/60KVAR 525V 50HZ
10078800 CLMD13/16.7KVAR 400V 50Hz(1PH)
65100006 CLMD13/15KVAR 400V 50Hz
65100014 CLMD63/50KVAR 400V 50Hz
65100025 CLMD43/18KVAR 460V 50Hz
10095201 CLMD43/25KVAR 525V 50HZ
10095176 CLMD33/20KVAR 260V 50HZ
10095507 CLMD53/30KVAR 600V 50HZ
10099355 CLMD83/80KVAR 460V 60HZ
10099257 CLMD53/30KVAR 525V 50HZ
10099460 CLMD63/25KVAR 200V 50HZ
10000242 CLMD63/53KVAR 550V 50Hz
10025116 CLMD83/100KVAR 525V 50Hz
10001394 CLMD43/15KVAR 220V 50Hz
10028323 CLMD43/32KVAR 415V 50Hz
10034775 CLMD53/40KVAR 440V 50Hz
10034870 CLMD53/44KVAR 500V 60Hz
10036337 CLMD43/30KVAR 690V 50Hz
10036711 CLMD43/16KVAR 230V 50Hz
10036712 CLMD43/19KVAR 250V 50Hz
10071980 CLMD53/25KVAR AC500V 50HZ
10071503 CLMD53/45KVAR 460V 50HZ
10058979 CLMD63/80KVAR 400V 50Hz
10069583 CLMD43/29KVAR 440V 50Hz
10054542 CLMD53/50KVAR 525V 50HZ
10054540 CLMD43/20KVAR 525V 50HZ
10050907 CLMD33/26.8KVAR 430V 50Hz(600mm)
10091231 CLMD33/15KVAR 400V 50HZ
10079811 CLMD53/15VAR 270V 50HZ(Y)
10079878 CLMD53/15KVAR 200V 50Hz
10090145 CLMD53/53.7KVAR 430V 50HZ
10092317 CLMD43/30KVAR 440V 50HZ(1 PH)
10077032 CLMD63/68.5KVAR 440V 50Hz
10083851 CLMD33/25KVAR 400V 50HZ(16)
10090535 CLMD53/40.8 KVAR 480V 50Hz
65100016 CLMD63/70KVAR 400V 50Hz
65100017 CLMD13/16KVAR 415V 50Hz
10095202 CLMD53/40KVAR 525V 50HZ
10096043 CLMD33/27KVAR 719V 50HZ
10096943 CLMD53/30KVAR 250V 50HZ
10099354 CLMD43/10KVAR 250V 50HZ(1PH)
10099828 CLMD63/80KVAR 440V 50HZ
10099750 CLMD43/15KVAR 420V 50HZ
10099674 CLMD53/53KVAR 720V 50HZ(Y)
10099897 CLMD53/30KVAR 280V 50HZ(1PH)
10011300 CLMD83/90KVAR 480V 50Hz
10034972 CLMD53/30KVAR 230V 50Hz
10066183 CLMD53/30KVAR 550V 60Hz
10058515 CLMD53/38KVAR 250V 50HZ
10063287 CLMD53/30KVAR 480V 50HZ
10058722 CLMD83/100KVAR 440V 50Hz
10054543 CLMD63/50KVAR 525V 50HZ
10054699 CLMD53/35KVAR 460V50HZ
10065620 CLMD13/18KVAR 415V 50Hz
10065619 CLMD13/11KVAR 415V 50Hz
10059271 CLMD63/50KVAR 480V 60HZ
10059512 CLMD63/50KVAR 480V50Hz
10057535 CLMD63/84KVAR 550V 50HZ
10085297 CLMD53/30KVAR 460V 50HZ
10091722 CLMD43/26.8KVAR 430V 50HZ
10078455 CLMD13/16.5KVAR 400V 50Hz 1phs
10086024 CLMD43/18KVAR 500V50Hz
10080466 CLMD43/15KVAR 500V50HZ
10090326 CLMD13/2.7KVAR 415V 50HZ
10091975 CLMD43/10KVAR 200V 50HZ
10090538 CLMD53/44.9 KVAR 525V 50Hz
10078493 CLMD13/15KVAR 400V 50HZ (1PH)
10074278 CLMD63/70KVAR 460V 50HZ
10090933 CLMD63/80KVAR 460V 50Hz
65100001 CLMD53/24KVAR 230V50Hz
65100032 CLMD63/67KVAR 480V 50Hz
65100031 CLMD83/120KVAR 480V50Hz
65100002 CLMD63/40KVAR 230V 50Hz
65100004 CLMD63/57KVAR 250V 50Hz
65100023 CLMD63/60KVAR 440V 50Hz
65100013 CLMD53/45KVAR 400V 50Hz
10094483 CLMD43/4.5KVAR 500V 50HZ
10094949 CLMD53/45KVAR 440V 50HZ
10095506 CLMD43/25KVAR 600V 50HZ
10095744 CLMD63/62KVAR 460V 50HZ
10099353 CLMD53/30KVAR 400V 50HZ(Y)
10099352 CLMD43/10KVAR 230V 50HZ(1PH)
10099348 CLMD33/28KVAR 480V 50HZ
10099831 CLMD63/40KVAR 480V 60HZ
10099749 CLMD63/60KVAR 790V 50HZ
10099466 CLMD63/60KVAR 430V 50HZ(Y)
10099685 CLMD13/16.6KVAR 690V 50HZ
10010846 CLMD33/25KVAR 400V 50HZ
10034973 CLMD53/36.8KVAR 450V 50Hz
10039540 CLMD53/32KVAR 660V 50Hz
10061000 CLMD63/50KVAR 660V 60Hz
10063046 CLMD13/16KVAR 400V 50Hz
10072561 CLMD83/100KVAR 400V 50HZ
10069287 CLMD33/20KVAR 400V 50Hz
10062111 CLMD13/8KVAR 230V 50HZ
10055562 CLMD63/85KVAR 600V 50Hz
10050509 CLMD13/15KVar 440V 50Hz
10081887 CLMD43/30KVAR 415V 50Hz
10084997 CLMD63/57KVAR 460V 50HZ
10083842 CLMD13/15KVAR 690V 50HZ(Y)
10085740 CLMD13/9.5KVAR 250V 50HZ
10079867 CLMD43/25KVAR 720V 50Hz
10086025 CLMD43/27KVAR 500V50HZ
10091945 CLMD53/40KVAR 690V 50HZ
10081082 CLMD83/65KVAR 480V60HZ
10074014 CLMD83/440V 90KVAR 50HZ
65100024 CLMD63/70KVAR 440V 50Hz
65100009 CLMD43/25KVAR 400V 50Hz
65100012 CLMD53/40KVAR 400V 50Hz
65100022 CLMD53/50KVAR 440V 50Hz
10094407 CLMD43/30KVAR 400V 60HZ
10095732 CLMD63/70KVAR 790V 50HZ
10099808 CLMD53/45KVAR 690V 50HZ
10096013 CLMD63/60KVAR 720V 50HZ
10099684 CLMD13/13.8KVAR 690V 50HZ
10099651 CLMD63/47KVAR 250V 50HZ
10099461 CLMD53/20KVAR 250V 50HZ
10099896 CLMD53/30KVAR 250V 50HZ(1PH)
