£¨×Իأ© ¸ßÆ·ÖÊ·ÀË®´øµÆ°´Å¥¿ª¹Ø¼¼Êõ²ÎÊý¼ò½é
1£º–¥³Ï·ÀË®´øµÆ°´Å¥¿ª¹Ø,µçÆøÊÙÃü50Íò´Î,»úеÊÙÃü100Íò´Î,¾¾ÃÄÍÓã¡
2£º–¥³Ï·ÀË®¿ª¹Ø,¾ßÓзÀË®·À³¾IP67µÈ¼¶,ÊôÓÚ¾ü¹¤µÈ¼¶,²»½öÊÇ·À³¾·ÀË®µÄµÈ¼¶,²¢ÇÒ·À±¬£¡
3£º–¥³Ï·ÀË®¿ª¹Ø,²ÉÓýø¿ÚÁÏ,Æ·Öʿɿ¿±£ÕÏ,²»½ö¾ßÓпìËÙ½»»õµÄ½»ÆÚ,²¢ÇÒ·þÎñµ½Î»£¡
4£º–¥³Ï·ÀË®¿ª¹Ø¶àÖÖ¶àÑù,¸ù¾Ý¿Í»§Ï²ºÃ½øÐÐÉè¼Æ,ÒÑÓв»Éٺð¸Àý,×öµ½¿Í»§·ÅÐÄ,¿Í»§ÂúÒâÊÇÎÒÃǾӪµÄÀíÄ
Ô²ÐηÀË®°´Å¥¿ª¹ØÊǾɱê×¼ÓÃÊõÓбê×¼£¨GB2900·18£©Öмò³ÆÎª°´Å¥¡£°´Å¥Óж¯ºÏ(³£¿ª)ºÍ¶¯¶Ï(³£±Õ)Ö®·Ö.΢ÐͰ´Å¥Óõ¼µçÏ𽺻ò½ðÊôƬµÈ×÷µ¼Ìå,¿É×÷Ϊ״̬ѡÔñ¿ª¹Ø,ÓÃÓÚСÐͰ뵼ÌåÊÕÒô»ú/Ò£¿ØÆ÷/Ñé³®Æ÷µÈ²úÆ·ÖС£
ÌØÉ«:°´Ñ¹½Ó´¥Ê½½á¹¹,ÎÞ»úеĥËðÎÊÌâ,ÕûÌåÃÜ·â·ÀË®½á¹¹.
·ÀÀ×»÷¿ª¹Ø,¿¹¶ñÁÓ»µ¾³,Íâ¿Ç¿ÉÓÃËܽººÍÂÁ¡£
Ó¦Ó÷¶Î§£ºµÆÊÎ,µçÄÔÖܱß,ͨѶ,Ò½ÁÆÉ豸,¹¤¿Ø,´¬ÓÃ.
£¨IP67£©SPECIFICATIONS
Max. current/voltage rating with resistive load: 400mA 32VAC-100mA 50VDC-125mA 125VAC
NITIAL CONTACT RESISTANCE: 50 mΩ max.
INSULATION RESISTANCE: 1 GΩ min. at 500VDC.
DIELETRIC STRENGTH: 1,000 VAC rms.
ELECTRICAL LIFE AT FULL LOAD: 500,000 cycles.
PANEL THICKNESS: Series:1.5 mm (.059) min. - 4 mm (.157) max.
TOTAL TRAVEL: 1.5 mm(.059).
OPERATING FORCE: 2N~5N.
CONTACT BOUNCE: 10 ms.
TORQUE: 0.5 Nm max. applied to nut.
SOLDERING: 350°C max. for 5 seconds.
–¥³Ïµç×Ó ·ÀË®IP67°´Å¥¿ª¹Ø ¸ßÆ·ÖÊ·ÀË®´øµÆ°´Å¥¿ª¹Ø£¨IP67£©
°´Å¥¿ª¹ØÊǾɱê×¼ÓÃÊõÓбê×¼£¨GB2900?18£©Öмò³ÆÎª°´Å¥¡£
°´Å¥¿ª¹ØÊÇÓÃÀ´ÇжϺͽÓͨ¿ØÖƵ緵ĵÍѹ¿ª¹ØµçÆ÷¡£°´Å¥¿ª¹ØµÄ´¥Í·µÄ¶î¶¨µçÁ÷Ϊ0.5A¡£ËùÒÔ£¬
²Ù×÷°´Å¥¿ª¹ØËù¿ØÖƵĵç·ÊôÓÚСµçÁ÷µç·¡£
°´Å¥Óе¥¼«Ë«Î»¿ª¹Ø»òË«¼«Ë«Î»¿ª¹Ø£¬Ëü°´¶¯ÄÜÓëÓÃ;ÓÖ·ÖΪÆð¶¯°´Å¥¡¢¸´Î»°´Å¥¡¢¼ì²é°´Å¥¡¢
¿ØÖư´Å¥¡¢ÏÞλ°´Å¥µÈ¶àÖÖ¡£
°´Å¥Óж¯ºÏ£¨³£¿ª£©ºÍ¶¯¶Ï£¨³£±Õ£©Ö®·Ö¡£
΢ÐͰ´Å¥Óõ¼µçÏ𽺻ò½ðÊôƬµÈ×÷µ¼Ì壬¿É×÷Ϊ״̬ѡÔñ¿ª¹Ø£¬ÓÃÓÚСÐͰ뵼ÌåÊÕÒô»ú¡¢
Ò£¿ØÆ÷¡¢Ñé³®Æ÷µÈ²úÆ·ÖС£
ÎÒ¹«Ë¾Éú²úµÄ¸÷·ÀË®¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹Ø£¬×ÔËø·ÀË®°´Å¥¿ª¹Ø£¬´øµÆ·ÀË®°´Å¥¿ª¹Ø¾ù¿ÉÔÚË®ÖÐÕý³£¹¤×÷£¡
µçÆøÊÙÃü50Íò´Î£¬»úеÊÙÃü100Íò´Î
·À³¾£¡·ÀË®£¡·À±¬£¡
̨Íå–¥³Ï¹«Ë¾¶«Ý¸–¥³Ïµç×Óרҵ´Óʸ÷ϵÁзÀË®¿ª¹ØµÄÉú²úÒÑÓÐ20¶àÄêµÄÀúÊ·£¬
ÎÒ˾·ÀË®¿ª¹ØµÄÊÙÃüÓëÐÔÄÜÒѾ×ßÉϹú¼Ê·Ïߣ¬Ö÷Òª²úÆ·ÓУ¬
12MM·ÀË®¿ª¹Ø£¬¸´Î»·ÀË®¿ª¹Ø£¬´øµÆ·ÀË®¿ª¹Ø£¬×ÔËø·ÀË®¿ª¹Ø£¬Îª¸ö¾ü¹¤ÆóÒµ£¬Æû³µÖÆÔìÉÌ£¬
º£ÉÏÔËÊ乤¾ßµÈÌṩ¸ßÆ·ÖÊ·ÀË®°´Å¥¿ª¹Ø£¬
¸÷¿ª¹Ø¾ù²»½öͨ¹ýIP67·ÀË®·À³¾²âÊÔ£¬²¢ÇÒͨ¹ýÎÒ˾¾ü¹¤ÆóÒµ¿Í»§×ö¹ý·À±¬²âÊÔ£¬¾ùͨ¹ý¿¼Ñ飡
̨Íå–¥³Ï¹É·Ý¶«Ý¸–¥³Ïµç×Ó³§ÔÚ20¶àÄêµÄÉú²ú·ÀË®¿ª¹ØµÄʱ¼äÀ³ÖÐøÑз¢³ö²»Í¬Àà±ðµÄ·ÀË®¿ª¹Ø£¬
ÀýÈç´øµÆ·ÀË®¿ª¹Ø£¬¸´Î»·ÀË®¿ª¹Ø£¬×ÔËø·ÀË®¿ª¹Ø£¬Ô²ÐηÀË®¿ª¹Ø£¬·ÀË®°´¼ü¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹ØµÈµÈ£¬
ÔÚ²»¶ÏµÄÃþË÷ÖУ¬Ê¹ÎÒ˾·ÀË®¿ª¹Ø¾ù´ïµ½·À³¾·ÀË®·À±¬µÄЧ¹û£¡
Double Credit·ÀË®¿ª¹Ø/¾üÓ÷ÀË®¿ª¹Ø/¾ü¹¤IP67·ÀË®°´Å¥¿ª¹Ø/°´¼ü¿ª¹Ø£¬Ì¨Íå–¥³Ïµç×ÓרҵÉú²ú·ÀË®¿ª¹Ø
ÒÑÓÐ20¶àÄêµÄÀúÊ·£¬¸÷ϵÁа´Å¥¿ª¹Ø£¬°´¼ü¿ª¹ØÖÖÀàÆëÈ«£¬
ËùÓвúÆ·¾ùͨ¹ýIP67µÄ·À³¾·ÀË®µÈ¼¶£¬¹¤×÷»·¾³Î¶ÈÔÚ-30µ½85µÄÄÚ£¬µçÆøÊÙÃü¸ß´ï50Íò´Î¡£»úеÊÙÃü100Íò´Î£¡
²¢Éú²ú³ö´óÁ¿´øµÆ°´Å¥¿ª¹Ø£¬´øµÆ°´¼ü¿ª¹Ø£¬Ð¡Ìå»ý·ÀË®¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹Ø£¡·ÀË®¿ª¹Ø¡£
·ÀË®°´Å¥¿ª¹Ø¾ùͨ¹ýUL VDE CQC TUV ROHS SGS REACHµÈ»·±£
