2A/36VDC×Ô¸´Î»´øµÆ½ðÊô·ÀË®°´Å¥¿ª¹Ø
̨Íå–¥³Ï¶«Ý¸ÔÃÊÆµç×Ó½ðÊô·ÀË®°´Å¥¿ª¹Ø ¸ßÇ¿¶È¿¹ÆÆ»µ°´Å¥¿ª¹Ø,·À»¤µÈ¼¶¸ß´ïIP67,¾ß±¸6·À-----·À³¾,·ÀË®,·ÀÓÍ,·Àײ»÷,·À¸¯Ê´¼°·ÀÀ×»÷.¿ÉÒÔ¶¨×ö²»Ðâ¸Ö »¶ÓÐÂÀϿͻ§Ç°À´×Éѯ,Ǣ̸,Ë÷Ñù,¶©¹º!
°²×°¿×³ß´ç£ºMounting hole size£ºΦ12mm
¿ª¹Ø¶î¶¨Öµ£ºSwitch rating :2A/36VDC
¿ª¹Ø×éºÏ£ºSwitch combination :1NO
²Ù×÷ÀàÐÍ£ºOperation types:×Ô¸´Ê½Reesetable
Í·²¿ÐÎ×´£ºHead shape:ƽÐÐflat/¸ßƽÐÐHigh flush
´øµÆ·½Ê½£ºLamp type£º»·ÐδøµÆRing llluminated
Íâ¿Ç²ÄÁÏ£º»ÆÍ¶ÆÄø/²»Ðâ¸Ö
Enclosure material:Nickel piated brass/Stainless stell
·À»¤µÈ¼¶ Degree of protection:IP67,IK08
PYCA12mm²úÆ·ÖÐÎĹæ¸ñ
β²¿ÅäÖ㺽ÓÏ߲寬Connection terminal£¨2.0*0.5£©
¿ª¹Ø¹æ¸ñ£º2A/36VDC
½Ó´¥µç×裺≤50mΩ
¾øÔµµç×裺≥ 1000mΩ
¾øÔµÇ¿¶È£º2000VAC
»µ¾³Î¶ȣº-20¡æ—+55¡æ
»úеÊÙÃü:50Íò´ÎÒÔÉÏ500000 cycles
µçÆøÊÙÃü£º5Íò´ÎÒÔÉÏ50000 cycles
Ãæ°åºñ¶È£º1—6mm
ÂÝĸŤ¾Ø£º5-14Nm
²Ù×÷ѹÁ¦£ºÔ¼5N About5N
²Ù×÷Ðг̣ºÔ¼2.5mm About2.5mm
·À»¤µÈ¼¶£ºIP67£¬IK08
²ÄÁÏ
´¥µã£ºÒøºÏ½ðSilver alloy
°´¼ü£º»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
Íâ¿Ç£º»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
»ù×ù£ºPA66
µÆÖé²ÎÊý
µÆÖéÀàÐÍ£º»·ÐδøµÆRing llluminated£¨LED)
¶î¶¨µçѹ£º6V/12V/24V/110V/22OV
µÆÖéÑÕÉ«£ººìÉ« ³ÈÉ« »ÆÉ« ÂÌÉ«À¶É« °×É«
µÆÖéÊÙÃü£º40000Сʱhours
PYCA12mm²úÆ·Ó¢ÎĹæ¸ñ:Specifications
Tail configuration:½ÓÏ߲寬Connection terminal£¨2.0*0.5£©
Switch specifications:2A/36VDC
Contact resistance:≤50mΩ
Insulation resistance:≥ 1000mΩ
Dielectric Intensity:2000VAC
Ambient temperature:-20¡æ—+55¡æ
Mechanical life:50Íò´ÎÒÔÉÏ500000 cycles
Electrcal life:5Íò´ÎÒÔÉÏ50000 cycles
Panel thinkness:1—6mm
Nut torque:5-14Nm
Operation pressure:Ô¼5N About5N
Operation stroke:Ô¼2.5mm About2.5mm
Protection level:IP67£¬IK08
Materiai
Contact:ÒøºÏ½ðSilver alloy
Button:»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
Enclosure:»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
Base:PA66
LEDParameters
LEDtype£º»·ÐδøµÆRing llluminated£¨LED)
Rated voltage£º6V/12V/24V/110V/22OV
LED color£ºred Orange yellow Green blue white
LED life£º40000Сʱhours
