Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ·ÀË®°´Å¥¿ª¹Ø¹úÄÚ×î´óµÄÉú²úÉÌ
²úÆ·Ãû³Æ£º ·ÀË®°´Å¥¿ª¹Ø¹úÄÚ×î´óµÄÉú²úÉÌ
ÐÍ ºÅ£º PYCA
̨Íå–¥³Ï·½Ðΰ´Å¥¿ª¹ØÅú·¢ ·½Ðΰ´Å¥¿ª¹ØÖÆÔìÉÌ ·½Ðΰ´Å¥¿ª¹Øµ¥¼ÛÅú·¢ ·ÀË®°´¼ü¿ª¹ØIP67 waterproof Push
 button switch ·ÀË®¿ª¹Ø¹©Ó¦ÉÌ ·ÀË®°´Å¥¿ª¹Ø ·ÀË®°´¼ü¿ª¹ØÅú·¢´øµÆ·ÀË®°´Å¥¿ª¹Ø Ô²ÐηÀË®¿ª¹Ø
·ÀË®°´Å¥¿ª¹Ø IP67·ÀË®°´Å¥¿ª¹Ø ·ÀË®¿ª¹ØUL-VDE-CQC-ENEC-TUV-ROHS-REACH
̨Íå–¥³Ïµç×Ó ·ÀË®IP67°´Å¥¿ª¹ØIP67 waterproof Push button switch ·ÀË®°´¼ü¿ª¹Ø   ¸´Î»·ÀË®°´¼ü¿ª¹Ø
´øµÆ·ÀË®°´¼ü¿ª¹Ø
£¨×ÔËø£© ¸ßÆ·ÖÊ·ÀË®´øµÆ°´Å¥¿ª¹Ø¼¼Êõ²ÎÊý¼ò½é
£¨IP67£©SPECIFICATIONSMax.
current/voltage rating with resistive load: 100mA 24VDC/2A 125V INITIAL
 CONTACT RESISTANCE:  100 mΩ max.
INSULATION RESISTANCE: 1 GΩ min. at 500VDC.DIELETRIC
STRENGTH: 1,000 VAC rms.
ELECTRICAL LIFE AT FULL LOAD: 200,000 cycles.
PANEL THICKNESS: Series:1.5 mm (.059) min.
 - 4 mm (.157) max.
TOTAL TRAVEL: 2.5 mm(.098).
 OPERATING FORCE: 4.5N~6.5N.
CONTACT BOUNCE: 10 ms.
TORQUE: 0.5 Nm max. applied to nut.SOLDERING:
350°C max. for 5 seconds.
µçÆøÊÙÃü50Íò´Î,»úеÊÙÃü100Íò´Î
·À³¾£¡·ÀË®£¡·À±¬£¡
̨Íå–¥³Ï¹«Ë¾¶«Ý¸–¥³Ïµç×Óרҵ´Óʸ÷ϵÁзÀË®¿ª¹ØµÄÉú²úÒÑÓÐ20¶àÄêµÄÀúÊ·£¬ÎÒ˾·ÀË®¿ª¹ØµÄÊÙÃüÓë
ÐÔÄÜÒѾ­×ßÉϹú¼Ê·Ïߣ¬Ö÷Òª²úÆ·ÓУ¬12MM·ÀË®¿ª¹Ø£¬¸´Î»·ÀË®¿ª¹Ø£¬´øµÆ·ÀË®¿ª¹Ø£¬×ÔËø·ÀË®¿ª¹Ø£¬
Ϊ¾ü¸÷¹¤ÆóÒµ£¬Æû³µÖÆÔìÉÌ£¬º£ÉÏÔËÊ乤¾ßµÈÌṩ¸ßÆ·ÖÊ·ÀË®°´Å¥¿ª¹Ø£¬
¸÷¿ª¹Ø¾ù²»½öͨ¹ýIP67·ÀË®·À³¾²âÊÔ£¬²¢ÇÒͨ¹ýÎÒ˾¾ü¹¤ÆóÒµ¿Í»§×ö¹ý·À±¬²âÊÔ£¬¾ùͨ¹ý¿¼Ñ飡
̨Íå–¥³Ï¹É·Ý¶«Ý¸–¥³Ïµç×Ó³§ÔÚ20¶àÄêµÄÉú²ú·ÀË®¿ª¹ØµÄʱ¼äÀ³ÖÐøÑз¢³ö²»Í¬Àà±ðµÄ·ÀË®¿ª¹Ø£¬
ÀýÈç´øµÆ·ÀË®¿ª¹Ø£¬¸´Î»·ÀË®¿ª¹Ø£¬×ÔËø·ÀË®¿ª¹Ø£¬Ô²ÐηÀË®¿ª¹Ø£¬·ÀË®°´¼ü¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹ØµÈµÈ£¬
ÔÚ²»¶ÏÃþË÷ÖУ¬Ê¹ÎÒ˾·ÀË®¿ª¹Ø¾ù´ïµ½·À³¾·ÀË®·À±¬µÄЧ¹û£¡
Our company are specialized in making IP67 Push button switch,which is mainly used in  ships,
motor boats, military products and so on.
Double Credit·ÀË®¿ª¹Ø/½ðÊôÍâ¿ÇIP67·ÀË®¿ª¹Ø/–¥³Ï·ÀË®¿ª¹Ø²ÉÓÃÃÜ·âʽÉè¼Æ£¬·ÀË®¿ª¹ØÄÚ²¿²»½øË®£¬
·ÀË®¿ª¹ØÄÚ²¿²ÄÁϲ»Ñõ»¯£¬Ê¹·ÀË®¿ª¹ØÊÙÃüÌá¸ß£¬
–¥³Ï·ÀË®¿ª¹ØÊÇ·ÀË®ÐÔÄÜ×îºÃµÄ·ÀË®¿ª¹Ø³§¼Ò£¬IP67·ÀË®¿ª¹ØÏµÁÐÆ·ÖÖÆëÈ«£¬·ÀË®¿ª¹ØÌ¨Íå–¥³Ïµç×Ó
¶«Ý¸–¥³Ïµç×Ó³§£¬1985¿ªÊ¼´ÓÊ·ÀË®¿ª¹ØµÄÉú²úÓëÏúÊÛ£¬ÏÖ³ÉΪ×î´ó£¬¿îʽ×î¶àµÄ·ÀË®°´Å¥¿ª¹Ø³§ÉÌ£¡
   DOUBLE CREDIT·ÀË®°´Å¥¿ª¹Ø½»ÆÚ5-7Ì죬·ÀË®ÐÔÄÜ×îºÃµÄ°´Å¥¿ª¹Ø£¬
½ðÊôÍâ¿Ç·ÀË®¿ª¹Ø·ÀË®µÈ¼¶×î¸ßµÄ¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹ØÊ×Ñ¡–¥³Ï£¡
    ·½ÐνðÊôÍâ¿Ç·ÀË®¿ª¹Ø³§ÉÌ£¬¹ã¶«Î¨Ò»µÄ¾ü¹¤·ÀË®¿ª¹Ø³§ÉÌ--–¥³Ï¹É·Ý·ÀË®¿ª¹Ø-SGS IP67·À³¾·ÀË®£¡
·ÀË®°´Å¥¿ª¹ØÌØÕ÷:¿ª¹Ø¾øÔµÐÔÇ¿£¬·À»¤µÈ¼¶´ïIP67£¬ÊÊÓÃÓÚÓÐË®½¦È÷»ò·Û³¾½Ï´óµÄ»·¾³Ê¹Óã¬
ÊǹúÄÚ×î´óµÄÉú²ú¹©Ó¦ÉÌ.
¹«Ë¾Ãû³Æ£º ̨Íå–¥³Ï¶«Ý¸ÔÃÊÆµç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 0769 33379516 / ·½Ãô
ÊÖ»ú£º 13544928349
µØ Ö·£º ÌÁÏÃÕòËÄ´å¿ûÇÅ·1ºÅ
ÓÊ ±à£º 523723
Ö÷ Ò³£º http://www.yeswitch.com
  • LEDµÆÃÜ·âʽ·ÀË®°´Å¥¿ª¹Ø
  • ·ÀÆÆ»µÃÜ·âʽ·ÀË®°´Å¥¿ª¹Ø
  • ³£¿ªÐÍÕûÌå·ÀË®°´Å¥¿ª¹Ø
  • ÃÜ·âʽ·ÀË®°´Å¥¿ª¹Ø
  • 16mmÕûÌå·ÀË®°´Å¥¿ª¹Ø
  • 2A/36VDC´øµÆ½ðÊô·ÀË®°´Å¥¿ª¹Ø
  • ̨Íå×îºÃµÄÐýת¿ª¹Ø
  • º½¿ÕÉ豸·ÀË®·À³¾°´Å¥¿ª¹Ø
  • ÔÃÊÆ²»Ðâ¸Ö16mmƽÐа´Å¥¿ª¹Ø
  • 2A/36VDC×Ô¸´½ðÊô°´Å¥¿ª¹Ø16mm
