ÌØÉ«:°´Ñ¹½Ó´¥Ê½½á¹¹,ÎÞ»úеĥËðÎÊÌâ,ÕûÌåÃÜ·â·ÀË®½á¹¹.
·ÀÀ×»÷¿ª¹Ø,¿¹¶ñÁÓ»µ¾³,Íâ¿Ç¿ÉÓÃËܽººÍÂÁ¡£
Ó¦Ó÷¶Î§£ºµÆÊÎ,µçÄÔÖܱß,ͨѶ,Ò½ÁÆÉ豸,¹¤¿Ø,´¬ÓÃ.
¸´Î»·ÀË®·À³¾°´Å¥¿ª¹ØÖÐÎĹæ¸ñ£º
1£ºµ±Ç°×î´óµçÁ÷/µçѹµÈ¼¶Óë¸ºÔØµç×è:
(³£¿ªÐÍ)
(³£±ÕÐÍ)
400mA 32V AC-100mA 50V DC-125mA 125V AC
500mA 48V AC-200mA 50V DC-200mA 250V AC.½ðÊô²ÄÁÏ
2£º³õ´Î½Ó´¥µçѹ:×î´ó50ºÁÅ·
3£º¾øÔµµç×è:ÔÚ500VDC×îС1000Õ×Å·.
4£º¾øÔµÇ¿¶È: 1,000 VAC rms.
1,500 VAC rms.½ðÊô²ÄÁÏ
5£ºµçÆøÊÙÃü: 500,000´Î.
»úеÊÙÃü:100,0000 ´Î.
6£ºÃæ°åºñ¶È:
{B2ÂÝÎÆ°²×°}1.5 mm (.059) min. -4 mm (.157) max.
{B1Èý½Ç¿¨Èëʽ°²×°}0.8mm (.031) min. -1.8 mm (.071) max.
{B3ǶÈëʽ°²×°}3.0±0.25mm(.118)
7£º×ÜÐгÌ: 1.5 mm(.059).
8£º²Ù×÷Á¦: 2N~5N.
9£º´¥µãµ¯Ìø: 10 ms.
10£ºÅ¤Á¦: 0.5 Nm max. ÊÊÓÃÓÚÂÝĸ.
1.5 Nm max. ½ðÊô²ÄÁÏ
11£ºº¸½Ó: ×î¶à5ÃëÖÓÔÚ×î¸ß350°C
12£º¹¤×÷ζȷ¶Î§:-30¡æµ½85¡æ
13£ºÐͺÅ:
³£¿ªÐÍ SP OFF-MOm
³£±ÕÐÍ DP On-MOm
14£ºÊÖ¹¤º¸½Ó:ÓÃÀÓÌú30Íߣ¬¿ØÖÆÔÚ350¡æ£¬Ô¼5Ã룬ͬʱӦÓú¸ÁÏ¡£
15£º²¨·åº¸:ÍÆ¼öº¸½Óζȣº260±5¡æ
Îý½þÅÝʱ¼ä£º×î¶à5Ãë¡£(PCB°åµÄºñ¶ÈΪ1.6mm)
º¸½Ó£º²¨·å¯
16£º(°´Å¥ÑÕÉ«)
¢Ù°×É«¢ÚºÚÉ«¢ÛºìÉ«¢Ü³ÈÉ«¢Ý»ÆÉ«¢ÞÂÌÉ«¢ßÀ¶É«¢àºÖÉ«¢á»ÒÉ«,ÈÎÑ¡.
17£º(LEDµÆÑÕÉ«)
¢Ù°×É«¢ÛºìÉ«¢Ü³ÈÉ«¢Ý»ÆÉ«¢ÞÂÌÉ«¢ßÀ¶É«,ÈÎÑ¡
¸´Î»Ê½£¨×Իأ© ¸ßÆ·ÖÊ·ÀË®°´Å¥¿ª¹ØÓ¢ÎĹæ¸ñ£º
(IP67)SPECIFICATIONS
Max. current/voltage rating with resistive load:
INITIAL CONTACT RESISTANCE: 50 mΩ max.
INSULATION RESISTANCE: 1 GΩ min. at 500VDC.
DIELETRIC STRENGTH: 1,000 VAC rms.
ELECTRICAL LIFE AT FULL LOAD: 500,000 cycles.
PANEL THICKNESS: Series:1.5 mm (.059) min. - 4 mm (.157) max.
TOTAL TRAVEL: 1.5 mm(.059).
OPERATING FORCE: 2N~5N.
CONTACT BOUNCE: 10 ms.
TORQUE: 0.5 Nm max. applied to nut.
SOLDERING: 350°C max. for 5 seconds.
MECHANICAL LIFE:1000£¬000 cycles
X=CAP COLOR
¢ÙWhite¢ÚBlack¢ÛRed¢ÜOrange¢ÝYellow¢ÞGreen¢ßBlue¢àBrown¢áGray.
MATERIALS:
CASE£ºDially phthalate (DAP)(UL-94V0)
CAP:Polyamide 6/6.
BUSHING:Polyamide 6/6.
TERMINAL/CONTACTS:Gold over silver plated.
ROHS:2002/95/EC
²¿·Ö²úÆ·º¸½Ó×¢ÒâÊÂÏ
Èκβ»ÕýÈ·µÄº¸½Ó²Ù×÷¶¼¿ÉÄܵ¼Ö²úÆ·ËÜÐÔ±äÐΡ¢¿ª¹Ø½Ó´¥²»Á¼µÈ¡£Óû§ÔÚʹÓÃÒý½Åʽ°´Å¥¿ª¹ØÊ±,Òòº¸½Ó²»µ±µ¼Ö²úÆ·Ë𻵵ÄÏÖÏóʱÓз¢Éú,¹Ê¾´Çë¸÷λÓû§ÔÚ½ÓÏß²Ù×÷ʱÎñ±Ø×¢ÒâÒÔϼ¸µã£º
*Ñ¡ÔñºÏÊʵĵçÀÓÌú£¬¼Ó¿ìº¸½ÓËÙ¶È£¬½¨ÒéʹÓÃ20WµçÀÓÌúÔÚ3ÃëÄÚÍê³Éº¸½Ó¡£
*Öúº¸¼Á±ØÐëÊÊÁ¿,º¸½Óʱ¾¡Á¿½«¿ª¹ØÒý½Å³¯Ï¡£
*¾¡Á¿²ÉÓòåÏß¶Ë×ÓÁ¬½Ó,±ÜÃ⺸½ÓÁ¬½Ó¡£
¶©»õÐëÖª£º
*¶©»õʱÇë¶ÔÕÕ"²úÆ·±àÂë"Óë²úÆ·Ìå˵Ã÷ÄÚÈÝÌîд¾ßÐͺŴúºÅ¡£
*ËùÓвúÆ·¾ù¿É¶©Öư´Å¥ÑÕÉ«£¬LEDµÆÑÕÉ«£¡
