̨Íå–¥³Ï¶«Ý¸ÔÃÊÆµç×Ó½ðÊô·ÀË®°´Å¥¿ª¹Ø ¸ßÇ¿¶È¿¹ÆÆ»µ°´Å¥¿ª¹Ø,·À»¤µÈ¼¶¸ß´ïIP67,¾ß±¸6·À-----·À³¾,·ÀË®,·ÀÓÍ,·Àײ»÷,·À¸¯Ê´¼°·ÀÀ×»÷.¿ÉÒÔ¶¨×ö²»Ðâ¸Ö »¶ÓÐÂÀϿͻ§Ç°À´×Éѯ,Ǣ̸,Ë÷Ñù,¶©¹º!
±¾³§Ö÷Òª²úÆ·ÓУºIP67·À³¾·ÀË®°´Å¥¿ª¹Ø ½ðÊô°´Å¥¿ª¹Ø¡¢Ðýת¿ª¹Ø ÐýÅ¥¿ª¹Ø¡¢Æû³µ¿ª¹Ø¡¢´øµÆ¿ª¹Ø ζȿª¹Ø KSD301οؿª¹Ø Å¥×Ó¿ª¹Ø¡¢´¬ÐÍ¿ª¹Ø£¬±¾×Å“¿Í»§µÚÒ»£¬³ÏÐÅÖÁÉÏ”µÄÔÔò£¬Óë¶à¼ÒÆóÒµ½¨Á¢Á˳¤ÆÚµÄºÏ×÷¹ØÏµ¡£Èȳϻ¶Ó¸÷½çÅóÓÑǰÀ´²Î¹Û¡¢¿¼²ì¡¢Ç¢Ì¸ÒµÎñ¡£
µØÖ·£º¹ã¶«Ê¡¶«Ý¸ÊÐÌÁÏÃÕòËÄ´å¿ûÇÅ·1ºÅ
ip65×Ô¸´Î»½ðÊô·ÀË®°´Å¥¿ª¹Ø
°²×°¿×³ß´ç£ºMounting hole size£ºΦ12mm
¿ª¹Ø¶î¶¨Öµ£ºSwitch rating :2A/36VDC
¿ª¹Ø×éºÏ£ºSwitch combination :1NO
²Ù×÷ÀàÐÍ£ºOperation types:×Ô¸´Ê½Reesetable
Í·²¿ÐÎ×´£ºHead shape:Ô²ÐÎRound/ƽÐÐflat
Íâ¿Ç²ÄÁÏ£º»ÆÍ¶ÆÄø/²»Ðâ¸Ö
Enclosure material:Nickel piated brass/Stainless stell
·À»¤µÈ¼¶ Degree of protection:IP65,IK08
PYCA12mm²úÆ·ÖÐÎĹæ¸ñ
β²¿ÅäÖ㺽ÓÏ߲寬Connection terminal/½ÓÏßÖùWiring terminal
¿ª¹Ø¹æ¸ñ£º2A/36VDC
½Ó´¥µç×裺≤50mΩ
¾øÔµµç×裺≥ 1000mΩ
¾øÔµÇ¿¶È£º2000VAC
»µ¾³Î¶ȣº-20¡æ—+55¡æ
»úеÊÙÃü:50Íò´ÎÒÔÉÏ500000 cycles
µçÆøÊÙÃü£º5Íò´ÎÒÔÉÏ50000 cycles
Ãæ°åºñ¶È£º1—6mm
ÂÝĸŤ¾Ø£º5-14Nm
²Ù×÷ѹÁ¦£ºÔ¼5N About5N
²Ù×÷Ðг̣ºÔ¼2.0mm About2.0mm
·À»¤µÈ¼¶£ºIP65£¬IK08
²ÄÁÏ
´¥µã£ºÒøºÏ½ðSilver alloy
°´¼ü£º²»Ðâ¸ÖStainess stell
Íâ¿Ç£º»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
»ù×ù£ºPA66
PYCA12mm²úÆ·Ó¢ÎĹæ¸ñ:Specifications
Tail configuration:½ÓÏ߲寬Connection terminal/½ÓÏßÖùWiring terminal
Switch specifications:2A/36VDC
Contact resistance:≤50mΩ
Insulation resistance:≥ 1000mΩ
Dielectric Intensity:2000VAC
Ambient temperature:-20¡æ—+55¡æ
Mechanical life:50Íò´ÎÒÔÉÏ500000 cycles
Electrcal life:5Íò´ÎÒÔÉÏ50000 cycles
Panel thinkness:1—6mm
Nut torque:5-14Nm
Operation pressure:Ô¼5N About5N
Operation stroke:Ô¼2.0mm About2.0mm
Protection level:IP65£¬IK08
Materiai
Contact:ÒøºÏ½ðSilver alloy
Button:²»Ðâ¸ÖStainess stell
Enclosure:»ÆÍ¶ÆÄø/²»Ðâ¸ÖNickel piated brass/stainless stell
Base:PA66
PYCAϵÁзÀ³¾·ÀË®°´Å¥¿ª¹ØÊôÓÚ·ÀË®ÐͽðÊô°´¼ü¿ª¹Ø£¬ÇᴥʽËܽº°´¼ü/½ðÊô°´¼ü,³£¿ª/³£±Õ¹¦ÄÜ¿ÉÑ¡£¬¾«ÖÂÃÀ¹Û£¬²ÉÓ÷¨¹ú°¢±´APEM¹¤ÒÕÉè¼ÆÀíÄî¡¢½áºÏ¹úÄÚÍâÓû§Ê¹ÓÃÌØµã£¬ÕûÌ岿λ´ïµ½·ÀË®¡¢·ÀÓÍ¡¢·À³¾µÈ¼¶IP67¡£¸øº£ÉÏÔËÊ乤¾ßµÈÌṩ¸ßÆ·ÖÊ·ÀË®°´Å¥¿ª¹Ø
Ñ¡ÔñÔÃÊÆµç×Ó·À³¾·ÀË®°´Å¥¿ª¹Ø,·ÀË®¿ª¹Ø,×ÔËø·ÀË®¿ª¹Ø,×ԻطÀË®°´Å¥¿ª¹ØµÄÔÒò£º
ÔÃÊÆ°´Å¥¿ª¹Ø,·À»¤µÈ¼¶¸ß´ïIP67,¾ß±¸6·À-----·À³¾,·ÀË®,·ÀÓÍ,·Àײ»÷,·À¸¯Ê´¼°·ÀÀ×»÷.»¶ÓÐÂÀϿͻ§Ç°À´×Éѯ,Ǣ̸,Ë÷Ñù,¶©¹º!
¿ª¹ØÍâÐÎΪ͹³öʽ £¬Ò»°ã×÷ΪÐźÅÊä³öʹÓ㬵¥ÅÅÇá´¥°´Ñ¹½Óͨ¡£²úÆ·Ö§³ÖIP67µÈ¼¶·À»¤±ê×¼£¨°´ EN60529±ê×¼£©£¬CE¹ú¼Ê±ê×¼¼°ROHS»·±£±ê×¼¡£
´Ë¿î²úÆ·×î´óÌØµãÔÚÓÚ¿ª¹ØÔª¼þÈ«²¿²ÉÓÃÈ䶯ÐͽṹÉè¼Æ£¬Ê¹¿ª¹Ø³ÐÊܸºÔØÄÜÁ¦ÔöÇ¿£¬´¥µã¾ßÓÐ×Խ๦ÄÜ£¬¿É¿¿ÐÔΪ°ÙÍò·Ö¼¶ £¬Ìå»ýСÇÉ£¬Íâ¹Û¾«Ö£¬¾¼ÃÊÊÓã¬ÐԼ۱ȸߡ£´Ë¿î²úÆ·ÁíÒ»ÌØµãÊÇĿǰÐÐÒµÄڳߴç×îСµÄÇᴥʽ½ðÊô°´¼ü¿ª¹Ø£¬±ÜÃâÁ˲¿·Ö¿Í»§Òò¿Õ¼ä²»×ã¶øÎÞ·¨×°ÅäµÄÎÊÌâ¡£±ê×¼²úÆ·ÅäÓй̶¨ÓÃÂÝĸºÍ·ÀË®µæÈ¦¡£ÌØÉ«:°´Ñ¹½Ó´¥Ê½½á¹¹,ÎÞ»úеĥËðÎÊÌâ,ÕûÌåÃÜ·â·ÀË®½á¹¹.·ÀÀ×»÷¿ª¹Ø,¿¹¶ñÁÓ»µ¾³,Íâ¿Ç¿ÉÓÃËܽººÍÂÁ¡£
·ÀË®°´Å¥¿ª¹ØÓ¦ÓÃÓÚ£ºµÆÊÎ,µçÄÔÖܱß,ͨѶÉ豸,¹¤¿Ø,´¬Óà º½¿Õ º½º£É豸£¬Æû³µ£¬ ¾ÆµêÉ豸£¬ÕÕÃ÷µÆ¾ß£¬½¨ÖþÄ£ÐÍ£¬ÒøÐб¨¾¯É豸£¬ÃŽû°²·À£¬µç¶¯³µ£¬µçÄÔ¼°ÖܱßÉ豸£¬Ò½ÁÆÉ豸£¬¹ûÖÒûÁÏ»ú£¬Í¶±Ò»ú£¬¿§·È»ú£¬Õ¥Ö»ú£¬×Ô¶¯ÊÛ»õ»ú£¬³éʪ»ú£¬µç×ÓÃÅËøÏµÍ³£¬µÆ¾ß£¬Ð¡¼Òµç£¬¸ßµµ¼Ò¾ß£¬Çå½àÉ豸µÈ¡£
