Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Ƥ¶û´Å¼ÌµçÆ÷
²úÆ·Ãû³Æ£º Ƥ¶û´Å¼ÌµçÆ÷
ÐÍ ºÅ£º 787585 PZE X4P C 24VDC 4n/o
  µÂ¹úPilz¹«Ë¾³ÉÁ¢ÓÚ1948Äê¡£PilzÓÐ50¶àÄêÑо¿ºÍÖÆÔ칤ҵ×Ô¶¯»¯²úÆ·µÄ¾­Ñ飬ÓÈÆäÊǰ²È«ÏµÁвúÆ·£¬ÒÔÆä¾«Õ¿µÄ¼¼ÊõºÍ¸ßÖÊÁ¿µÄ²úÆ·£¬¹ã·ºÓ¦ÓÃÓÚÊÀ½ç¸÷¸ö°²È«ÁìÓò£¬PilzËùÌṩµÄ²úÆ·¾ùͨ¹ýISO9001ºÍ¶àÏî¹ú¼Ê±ê×¼ÈÏÖ¤¡£
  Ó¦ÓÃÁìÓò£º
  Pilz×Ô¶¯»¯²úÆ·¼°ÏµÍ³µÃµ½Á˹㷺µÄÓ¦Ó㬿ÉÒÔ ÓÃÔÚ¹¤³§ºÍ»úе¹¤³ÌµÄËùÓÐÁìÓòÖС£ Pilz ²»½ö½ö ÓÃÔÚÒ»Á÷µÄ×Ô¶¯»¯ÁìÓò £¨Æû³µ,ʳÎï
ºÍľ²Ä¼Ó¹¤£¬ °ü×°ÒµµÈ)£¬»¹ÓÃÔÚÁËÆäËûÐí¶àÁìÓò£¬È磺»ú³¡£¬ Ó°Ôº,µç¶¯À³µµÈһЩÓÎÀÖ³¡Ëù¡£
  751177 PNOZ s7.2 C 24VDC 4 n/o 1 n/c expand
751185 PNOZ s5 C 24VDC 2 n/o 2 n/o t coated
773050 PNOZmulti Systemhandbuch D
773100 PNOZ m1p base unit
773105 PNOZ m1p base unit coated version
773110 PNOZ m0p base unit not expandable
773120 PNOZ m2p base unit press function
773200 PNOZ pps1p 100-240VAC
773300 PNOZ p1p 24VDC 2so
773400 PNOZ mi1p 8 input
773405 PNOZ mi1p 8 inputs coated version
773410 PNOZ mi2p 8 standard input
773500 PNOZ mo1p 4 so
773505 PNOZ mo1p 4so coated version
773510 PNOZ mo3p 2so
777582 PZE X4VP 2/24VDC 4n/o fix
777583 PZE X4VP 3/24VDC 4n/o fix
777584 PZE X4VP8 24VDC 4n/o
777585 PZE X4P 24VDC 4n/o
777586 PZE X4VP4 24VDC 4n/o
777587 PZE X4.1P 24VDC 4n/o
777588 PZE X4.1P 24-240VAC/DC 4n/o
777600 PNOZ X2.1VP 0.75/24VDC 1so 2n/o fix
777601 PNOZ XV1P 3/24VDC 2n/o 1n/o t
777602 PNOZ XV1P 30/24VDC 2n/o 1n/o t
777606 PNOZ X9P 24VDC 100-240VACDC 7no 2nc 2so
777607 PNOZ X9P 12VDC 7n/o 2n/c 2so
777609 PNOZ X9P 24VDC 7n/o 2n/c 2so
777750 PNOZ X10.11P 24VDC 6n/o 4n/c 6LED
777760 PNOZ X8P 24 VDC 3n/o 2n/c 2so
777764 PNOZ X8P 110VAC 3n/o 2n/c 2so
777765 PNOZ X8P 115VAC 3n/o 2n/c 2so
777766 PNOZ X8P 120VAC 3n/o 2n/c 2so
777768 PNOZ X8P 230VAC 3n/o 2n/c 2so
777770 PNOZ X8P 24VAC 3n/o 2n/c 2so
777949 PSWZ X1P 0,5V /24-240VACDC 2n/o 1n/c 2so
777950 PSWZ X1P 3V /24-240VACDC 2n/o 1n/c 2so
777951 PSWZ X1P 0,0075-0,5V/24-240VACDC
778010 PMUT X1P 24VDC 3n/o 1n/c 5so
779000 PNOZmulti Tool-Kit
  787355 P2HZ X4P C 24VDC 3n/o 1n/c
787434 P2HZ X1P C 110VAC 3n/o 1n/c 2so
787435 P2HZ X1P C 115VAC 3n/o 1n/c 2so
787436 P2HZ X1P C 120VAC 3n/o 1n/c 2so
787438 P2HZ X1P C 230VAC 3n/o 1n/c 2so
787439 P2HZ X1P C 240VAC 3n/o 1n/c 2so
787500 PNOZ XV2P C 30/24VDC 2n/o 2n/o t
787502 PNOZ XV2P C 3/24VDC 2n/o 2n/o t
787503 PNOZ XV2P C 1/24VDC 2n/o 2n/o fix
787504 PNOZ XV2P C 0.5/24VDC 2n/o 2n/o fix
787510 PNOZ XV3P C 30/24 VDC 3n/o 2n/o t
787511 PNOZ XV3.3P C 30/24VDC 3n/o 2n/o t
787512 PNOZ XV3P C 3/24 VDC 3n/o 2n/o t
787518 PNOZ XV3P C 300/24VDC 3n/o 2n/o t
787520 PNOZ XV3.1P C 30/24VDC 3n/o 1n/c 2n/o t
787522 PNOZ XV3.1P C 3/24VDC 3n/o 1n/c 2n/o t
787530 PNOZ XV3.1P C 30/24-240VACDC 3no 1nc 2no
787532 PNOZ XV3.1P C 3/24-240VACDC 3no 1nc 2no
787538 PNOZ XV3.1P C300/24-240VACDC 3no 1nc 2no
787540 PNOZ XV2.1P C 30/24-240VACDC 2n/o 2n/o t
787542 PNOZ XV2.1P C 3/24-240VACDC 2n/o 2n/o t
787548 PNOZ XV2.1P C 300/24-240VACDC 2n/o 2n/o
787580 PZE X4VP C 0,5/24VDC 4n/o fix
787581 PZE X4VP C 1/24VDC 4n/o fix
787582 PZE X4VP C 2/24VDC 4n/o fix
787583 PZE X4VP C 3/24VDC 4n/o fix
787584 PZE X4VP8 C 24VDC 4n/o
787586 PZE X4VP4 C 24VDC 4n/o
787587 PZE X4.1P C 24VDC 4n/o
787588 PZE X4.1P C 24-240VAC/DC 4n/o
787600 PNOZ X2.1VP C 0.75/24VDC 1so 2n/o fix
787601 PNOZ XV1P C 3/24VDC 2n/o 1n/o t
787602 PNOZ XV1P C 30/24VDC 2n/o 1n/o t
787606 PNOZ X9P C 24VDC 100-240VACDC 7no 2nc2so
787609 PNOZ X9P C 24VDC 7n/o 2n/c 2so
787750 PNOZ X10.11P C 24VDC 6n/o 4n/c 6LED
pilzƤ¶û×Ȱ²È«¼ÌµçÆ÷
787760 PNOZ X8P C 24 VDC 3n/o 2n/c 2so
787764 PNOZ X8P C 110VAC 3n/o 2n/c 2so
787765 PNOZ X8P C 115VAC 3n/o 2n/c 2so
773520 PNOZ mo2p 2n/o
773525 PNOZ mo2p 2n/o coated version
773536 PNOZ mo4p 4n/o
773537 PNOZ mo4p 4n/o coated version
773540 PNOZ ml1p safe link
773630 PNOZ po3.1p 8n/o
773631 PNOZ po3.2p 4n/o
773632 PNOZ po3.3p 3n/o
773634 PNOZ po3p 3n/o 1n/c
773635 PNOZ po4p 4n/o
773700 PNOZ mc1p
773705 PNOZ mc1p coated version
773720 PNOZ mc0p Powersupply
773721 PNOZ mc3p Profibus
773722 PNOZ mc4p DeviceNet
773723 PNOZ mc5p INTERBUS
773724 PNOZ mc6p CANopen
773725 PNOZ mc7p CC-Link coated version
773726 PNOZ mc7p CC-Link
773727 PNOZ mc6p CANopen coated version
773728 PNOZ mc5.1p Interbus LWL / Fiberoptic
773729 PNOZ mc4p DeviceNet coated version
773730 PNOZ mc8p Ethernet IP / Modbus TCP
773731 PNOZ mc9p Profinet IO
779110 PNOZmulti Bus-Terminator
779112 PNOZmulti Bus-Terminator coated
779120 PNOZpower Bus-Terminator
779125 PNOZ pe2p Bus-Interface
779200 PNOZmulti Chipcard Set 10 pieces 8kB
779201 PNOZmulti Chipcard 1 piece 8kB
779211 PNOZmulti Chipcard 1 piece 32kB
779212 PNOZmulti Chipcard Set 10 pieces 32kB
779230 Chip Card Reader
779240 PNOZmulti Chipcard Holder (Sparepart)
779250 PNOZmulti Seal 10 pieces
783100 Set spring terminals PNOZ m0p/m1p/m2p
783400 Set spring term mi1p/mi2p/mo1p/mo3p/ml1p
783520 Set spring terminals PNOZ mo2p
783536 Set spring terminals PNOZ mo4p/mo5p
783537 10 Set spring terminals PNOZ mo4p/mo5p
783700 Set spring terminals PNOZ mc1p/ma1p
783800 Set spring terminals PNOZms1p/ms2p
784130 PNOZ e1p C 24VDC 2so
784131 PNOZ e1vp C 10/24VDC 1so 1so t
784132 PNOZ e1vp C 300/24VDC 1so 1so t
784133 PNOZ e1.1p C 24VDC 2so
784135 PNOZ e2.2p C 24VDC 2so
784136 PNOZ e2.1p C 24VDC 2so
784137 PNOZ e3vp C 10/24VDC 1so 1so t
784138 PNOZ e3vp C 300/24VDC 1so 1so t
784139 PNOZ e3.1p C 24VDC 2so
784180 PNOZ e4.1p C 24VDC 2so
784181 PNOZ e4vp C 10/24VDC 1so 1so t
784190 PNOZ e5.11p C 24VDC 2so
784191 PNOZ e5.13p C 24VDC 2so
784192 PNOZ e6.1p C 24VDC 4n/o 2so
784193 PNOZ e6vp C 24VDC 4n/o 1so 1so t
787053 PNOZ X7P C 110-120VAC 2n/o
787056 PNOZ X7P C 230-240VAC 2n/o
787059 PNOZ X7P C 24VAC/DC 2n/o
787070 PNOZ 16SP C 24VAC 24VDC 2n/o
787071 PNOZ 16SP C 42VAC 24VDC 2n/o
787072 PNOZ 16SP C 48VAC 24VDC 2n/o
787073 PNOZ 16SP C 110VAC 24VDC 2n/o
787074 PNOZ 16SP C 115VAC 24VDC 2n/o
787075 PNOZ 16SP C 120VAC 24VDC 2n/o
787076 PNOZ 16SP C 230VAC 24VDC 2n/o
787077 PNOZ 16SP C 240VAC 24VDC 2n/o
787080 PNOZ X11P C 24VAC 24VDC 7n/o 1n/c 2so
787083 PNOZ X11P C 110-120VAC 7n/o 1n/c 2so
787086 PNOZ X11P C 230-240VAC 7n/o 1n/c 2so
787100 PNOZ X1P C 24VDC 3n/o 1n/c
787140 PZE 9P C 24VACDC 8n/o 1n/c
787148 PZE 9P C 24VACDC 100-240VACDC 8n/o 1n/c
787150 PZE X5P C 24VDC 5n/o 2so
787250 DUMMY MODULE PNOZ DM X2.7P/X2.8P C
787251 DUMMY MODULE PZE DM 9P C
787252 DUMMY MODULE PZE DM X4P C
787253 DUMMY MODULE PNOZ DM XV3.1P C
787254 DUMMY MODULE PZE DM X4VP C
787300 PNOZ X2.9P C 24VDC 3n/o 1n/c
787301 PNOZ X2.8P C 24VACDC 3n/o 1n/c
787302 PNOZ X2.8P C 24-240VAC/DC 3n/o 1n/c
787303 PNOZ X2P C 24VACDC 2n/o
787304 PNOZ X2.3P C 24VACDC 3n/o
787305 PNOZ X2.7P C 24VACDC 3n/o 1n/c
787306 PNOZ X2.7P C 24-240VAC/DC 3n/o 1n/c
787307 PNOZ X2P C 48-240VACDC 2n/o
787308 PNOZ X2.5P C 24VDC 2n/o 1so
787310 PNOZ X3P C 24VDC 24VAC 3n/o 1n/c 1so
787313 PNOZ X3P C 24-240VACDC 3n/o 1n/c 1so
787314 PNOZ X3.10P C 24VACDC 3n/o 1n/c 1so
787330 P2HZ X1P C 24VAC 3n/o 1n/c 2so
787331 P2HZ X1P C 42VAC 3n/o 1n/c 2so
787332 P2HZ X1P C 48VAC 3n/o 1n/c 2so
787340 P2HZ X1P C 24VDC 3n/o 1n/c 2so
787341 P2HZ X1.10P C 24VDC 3n/o 1n/c 2so
787354 P2HZ X4P C 24VAC 3n/o 1n/c
773800 PNOZ ms1p standstill / speed monitor
773810 PNOZ ms2p standstill / speed monitor
773812 PNOZ ma1p 2 Analog Input
773839 PNOZ msi1Bp Adapter Si/Ha 25/25 5m
773840 PNOZ msi1Ap Adapter Si/Ha 25/25 2,5m
773841 PNOZ msi1Bp Adapter Si/Ha 25/25 2,5m
773842 PNOZ msi3Ap Adapter Si/Ha 15/15 2,5m
773843 PNOZ msi3Bp Adapter Si/Ha 15/15 2,5m
773850 PNOZ msi1p Adapter Si/Ha 25/25 2,5m
773844 PNOZ msi1AP Adapter Si/Ha 25/25 5m
773854 PNOZ msi10p adapter cable 2,5m
773855 PNOZ msi11p adapter cable 1,5m
773856 PNOZ msi 9p adapter cable 5m
774131 PNOZ e1vp 10/24VDC 1so 1so t
774132 PNOZ e1vp 300/24VDC 1so 1so t
774133 PNOZ e1.1p 24VDC 2so
774135 PNOZ e2.2p 24VDC 2so
774136 PN
OZ e2.1p 24VDC 2so
774137 PNOZ e3vp 10/24VDC 1so 1so t
774138 PNOZ e3vp 300/24VDC 1so 1so t
774139 PNOZ e3.1p 24VDC 2so
774140 PZE 9 24VAC 8n/o 1n/c
774141 PZE 9 42VAC 8n/o 1n/c
774142 PZE 9 48VAC 8n/o 1n/c
774143 PZE 9 110-120VAC 8n/o 1n/c
774144 PZE 9 120 Vac 8n/o 1n/c
774148 PZE 9 230-240VAC 8n/o 1n/c
774150 PZE 9 24VDC 8n/o 1n/c
774180 PNOZ e4.1p 24VDC 2so
774181 PNOZ e4vp 10/24VDC 1so 1so t
774190 PNOZ e5.11p 24VDC 2so
774191 PNOZ e5.13p 24VDC 2so
774192 PNOZ e6.1p 24VDC 4n/o 2so
774193 PNOZ e6vp 24VDC 4n/o 1so 1so t
774195 Terminal block filter 1
774196 Terminal block filter 2
774300 PNOZ X1 24VAC/DC 3n/o 1n/c
774303 PNOZ X2 24VAC/DC 2n/o
774304 PNOZ X2C 24VAC/DC 2n/o
774305 PNOZ X2.1C 24VAC/DC 2n/o
774306 PNOZ X2.1 24VAC/DC 2n/o
774309 PNOZ X3.2 230VAC 24VDC 3n/o 1n/c 1so
774310 PNOZ X3 24VAC 24VDC 3n/o 1n/c 1so
774311 PNOZ X3 42VAC 24VDC 3n/o 1n/c 1so
774312 PNOZ X3 48VAC 24VDC 3n/o 1n/c 1so
774314 PNOZ X3 110VAC 24VDC 3n/o 1n/c 1so
774315 PNOZ X3 115VAC 24VDC 3n/o 1n/c 1so
774316 PNOZ X3 120VAC 24VDC 3n/o 1n/c 1so
774318 PNOZ X3 230VAC 24VDC 3n/o 1n/c 1so
774319 PNOZ X3 240VAC 24VDC 3n/o 1n/c 1so
774321 PNOZ X3.1 230VAC 24VDC 3n/o 1n/c 1so
774322 PNOZ X3.1 240VAC 24VDC 3n/o 1n/c 1so
774323 PNOZ X5J 24VDC 2n/o
774324 PNOZ X5.1 24VDC 2n/o
774325 PNOZ X5 24VACDC 2n/o
774326 PNOZ X5 12VDC 2n/o
774327 PNOZ X5 12VDC 2n/o coated version
774330 P2HZ X1 24VAC 3n/o 1n/c
774331 P2HZ X1 42VAC 3n/o 1n/c
774332 P2HZ X1 48VAC 3n/o 1n/c
774340 P2HZ X1 24VDC 3n/o 1n/c
774341 P2HZ X1 26VDC 3n/o 1n/c
774345 P2HZ X2 24VAC 2n/o
774350 P2HZ X3 24VDC 2n/o 1n/c
774360 P1HZ X1 24VDC 2n/o
774400 PDZ 24VDC 2n/o 2n/c
774401 PAD/BO 512/6/5VDC
774402 PAD/SI 800/512I/5VDC
774403 PAD/SI 800/1024I/5VDC
774404 PAD/SI 800/2048I/5VDC
774405 PAD/SI 800/4096I/5VDC
774406 PAD/SI 840/512I/5VDC
774407 PAD/SI 840/1024I/5VDC
774408 PAD/SI 840/2048I/5VDC
774409 PAD/SI 840/4096I/5VDC
774410 PAD/SI 800/32I/5VDC
774411 PAD/SI 840/256I/5VDC
774412 PAD/SI 840/128I/5VDC
774413 PAD/SI 840/64I/5VDC
774414 PAD/SI 840/32I/5VDC
774415 PAD/SI 840/16I/5VDC
774420 PDZK WDP3-01 1000/20 24 Vdc
µÂ¹úpilz°²È«¼ÌµçÆ÷
777301 PNOZ X2.8P 24VACDC 3n/o 1n/c
777302 PNOZ X2.8P 24-240VAC/DC 3n/o 1n/c
777303 PNOZ X2P 24VACDC 2n/o
777304 PNOZ X2.3P 24VACDC 3n/o
777305 PNOZ X2.7P 24VACDC 3n/o 1n/c
777306 PNOZ X2.7P 24-240VAC/DC 3n/o 1n/c
777307 PNOZ X2P 48-240VACDC 2n/o
777308 PNOZ X2.5P 24VDC 2n/o 1so
777310 PNOZ X3P 24VDC 24VAC 3n/o 1n/c 1so
777313 PNOZ X3P 24-240VACDC 3n/o 1n/c 1so
pilzƤ¶û×Ȱ²È«¼ÌµçÆ÷
777314 PNOZ X3.10P 24VACDC 3n/o 1n/c 1so
777330 P2HZ X1P 24VAC 3n/o 1n/c 2so
777331 P2HZ X1P 42VAC 3n/o 1n/c 2so
777332 P2HZ X1P 48VAC 3n/o 1n/c 2so
793520 Set screw terminals PNOZ mo2p
793536 Set screw terminals PNOZ mo4p/mo5p
793537 10 Set screw terminals PNOZ mo4p/mo5p
793631 PNOZ po3.2p Set plug in screw terminals
793700 Set screw terminals PNOZ mc1p/ma1p
793800 Set screw terminals PNOZms1p/ms2p
874640 PDIA 1 24VDC RS-232
874645 PDIA 2 24VDC PLC-Interface
874646 PDIA 2 - HB
874130B PNOZelog Driver CD
¹«Ë¾Ãû³Æ£º ÏÃÃűò˶¿Æ¼¼×Ô¶¯»¯ÓÐÏÞ¹«Ë¾
µç »°£º 0592 5588163 / СÀî
ÊÖ»ú£º 13358385993
µØ Ö·£º ÏÃÃÅÊкþÀïÇø¼ÎºÌ·545ºÅ302ÊÒ
ÓÊ ±à£º 361006
Ö÷ Ò³£º http://binsuk.com
  • Î÷ÃÅ×Ó3UF7013-1AU00-0
  • 6RY1807-0AP00
  • 6SB2073-3EA00-0AA0
  • 6RY1703-1HD06
  • Î÷ÃÅ×Ó6DDÄ£¿é
  • Ƥ¶û´Å¼ÌµçÆ÷
  • ÌØ¼ÛÎ÷ÃÅ×Ó3TH¼ÌµçÆ÷
  • Î÷ÃÅ×ÓµçÔ´Ä£¿é
  • Î÷ÃÅ×Óпî¼ÌµçÆ÷
  • Î÷ÃÅ×Ó6GT
