ÐͺÅModel
ES-620
ÖáÊýNumber of Axis
6 axes
Ïß¾¶Wire Diameter
Ø0.5mm¡«Ø2.0mm
ËÍÏßÂÖ×éÊýFeeding Roller Pairs
2Pairs
×î´óÏßȦÍâ¾¶Max. Outside Diameter
Φ40mm
×î´óËÍÏßËÙ¶ÈMax. Feeding Speed
130m/min
ËÍÏßÖáµç»ú¹¦ÂÊ
Wire Feeding Axis
2.7kw
Çе¶Öáµç»ú¹¦ÂÊ
Cutter Servo Moter
0.75kw*2
Íâ¾¶Öáµç»ú¹¦ÂÊOD Control Servo Motor
0.75kw
½Ú¾àÖáµç»ú¹¦ÂÊPitch Servo Motor
0.75kw
оÖáǰºóµç»ú¹¦ÂÊMandrel Up/Down Servo Motor
0.75kw
»úÆ÷³ß´çDimension(L*W*H)(mm)
1100*900*1600 (MM3)
»úÆ÷ÖØÁ¿Weight
1100kg
