产品名称:Milmega双频宽带放大器AS0860-150/45 型号:AS0860-150/45 Psat(min):175.0 W (0.8-2.0GHz) 50.0 W (2.0-4.0GHz) Psat(min):52.4 dBm (0.8-2.0GHz) 46.9 dBm (2.0-4.0GHz) P1dB(min):150.0 W (0.8-2.0GHz) 45.0 W (2.0-4.0GHz) P1dB(min):51.8 dBm (0.8-2.0GHz) 46.5 dBm (2.0-4.0GHz) 噪声系数(max):6.0 dB (0.8-2.0GHz) 8.0 dB (2.0-4.0GHz) 增益变化:± 2.5 dB (0.8-2.0GHz) ±3.0 dB (2.0-4.0GHz) 谐波失真(max):-20 dBc 功率损耗:900 W 主电源:85-260 V (50/60 Hz) 连接器形式(Input):Type N female 连接器形式(Output):Type N female 重量:55 kg 尺寸:6U
