产品名称:BLACK BOX切换器ACS4001A-T
型号:ACS4001A-T
品牌:BLACK BOX
描述:
BLACK BOX切换器ACS4001A-T;BLACK BOX延长器ACS4001A-T;BLACK BOX KVM延长器;ACS4001A-T
ServSwitch? DKM KVM Switch
CATx- or fibre-based DVI-D and USB KVM control for up to 16 Users and 32 PCs
Built-in extension using CATx or fibre.
Multiple control options for versatile usage — not just KVM.
Redundant power supplies for mission-critical environments.
Modular architecture for flexible configuration.
Supports DVI-D video resolutions up to 1920 x 1200 at 60Hz over the full distance.
Real-time video and keyboard/mouse operation.
规格:
Maximum Distances - CATx: 140m Black Box recommends solid wire shielded CAT5e or higher CATx cables for maximum distances! Multimode: 200m @ 62.5/125μ; 400m @ 50/125μ; Single-mode: 10km @ 9/125μ
Maximum Resolution - W-UXGA 1920 x 1200 at 60Hz, up to 24-bit colour depth
Indicators - 2.5" LCD Display
Connectors - (1) IEC-320 per Power Supply 100-240VAC; (1) USB Type B F; (1) RJ-45 F TCP/IP RJ-11 RS-232/V.24. Pre-configured unit also have: ACX0808: (16) RJ-45 F; ACX0816: (24) RJ-45 F; ACX0832: (40) RJ-45 F; ACX1616: (32) RJ-45 F; ACX1632: (48) RJ-45 F
Dimensions - 4.4(H) x 43.5(W) x 8.4(D) cm
Weight - 8.25kg
