嵌入式无风扇主板 ECS TIGD-CI3 (双核D525 CPU)
(具体价格请与客服联系)
TIGD-CI3精英主机板属于系列 17 x 17 公分的小型规格最新产品,沿袭INTEL一贯的外型轻薄、最低噪音及低功率等特色,是创造先进数字多媒体娱乐的最佳解决方案。
TIGD-CI3系列有超强的多媒体信息处理能力,支持最新的MPEG4功能,可轻松提供全方位的数字多媒体娱乐应用,无论是有机顶盒(Set-Top-Box)、家庭多媒体中心(Home Media Center)、液晶多媒体电视与计算机(LCD PC)等应用都是最佳的选择。
规格说明
| ECS TIGD-CI3 MINI-ITX 嵌入式主板规格 |
| 型号 |
• ECS TIGD-CI3 |
| 处理器 |
• Onboard Intel Dual Core Atom D525 processor
• DMI 667Mb/s |
| 芯片组 |
• Intel® NM10 Express |
| 系统内存 |
• Single-channel DDR3 memory architecture
• 2 x 204-pin DDR3 DIMM socket support up to 4GB
• Support DDR3 800 SO DIMM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation |
| 图形显示 |
• Integrated Intel® Graphics Media Accelerator 3150(GMA3150)
• Integrated DirectX 9 graphics processor
• Max DVMT Graphics Memory up to 384MB |
| 扩展插槽 |
• 1 x PCI Solt |
| 板载串行 ATA |
• Support by Intel® NM10 Express
• 2 x Serial ATA 3.0Gb/s devices |
| 板载 LAN |
• Realtek 8105E 10/100 Lan
• Realtek 8111E Giga Lan (Optional) |
| 板载音效芯片 |
• Realtek ALC662 6-channel HD audio CODEC
• Compliant with HD audio specification |
| 内部 I/O 接口 |
• 1 x 24-pin ATX Power Supply connector
• 1 x 4-pin CPU_FAN connector
• 1 x Front panel switch/LED header
• 1 x Front panel audio header
• 1 x Clear CMOS header
• 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
• 1 x 4-pin SYS_FAN connector
• 2 x SATA 3Gb/s connectors |
| 后面板 I/O 接口 |
• 1 x PS/2 keyboard & PS/2 mouse connectors
• 1 x D-sub(VGA)
• 1 x Serial port (COM1)
• 1 x Parallel Port
• 1 x RJ45 LAN connector
• 1 x Audio port (Line-in, Line-out, Mic-in)
• 4 x USB 2.0 Ports |
| BIOS |
• AMI BIOS with 8Mb SPI Flash ROM
• Supports Plug and Play, STR (S3) / STD (S4) , Hardware monitor, Multi Boot
• Audio, LAN, can be disabled in BIOS
• F11 hot key for boot up devices option
• Support eJIFFY |
| 系统监控和管理 |
• CPU 电压监控
• 网络唤醒(Wake-on-LAN)、键盘开机(Keyboard-Power-on)、定时开机(Timer-Power-on)
• 系统电源管理
• AC 断电恢复机制 |
| 操作系统 |
• Windows 2000/XP
• Linux
• Win CE
• XPe |
| 工作环境温度 |
0°C~ 60°C |
| 工作环境湿度 |
0% ~ 93%(相对湿度;无冷凝) |
| 板型 |
• Mini-ITX
• 17 cm x 17 cm |
