Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú MOXA 1¿Ú RS-232/422/485 ¿É±à³ÌÍ¨Ñ¶Íø¹Ø
²úÆ·Ãû³Æ£º MOXA 1¿Ú RS-232/422/485 ¿É±à³ÌÍ¨Ñ¶Íø¹Ø
ÐÍ ºÅ£º NPort 4511
Æ· ÅÆ£º MOXA
NPort 4511ÊÇÒ»¸öרҵµÄ¿É±à³ÌÍ¨Ñ¶Íø¹Ø£¬¿ÉÒÔÈÃÄúµÄ RS-232/422/485 Á¢¼´ÍøÂ绯, ͬʱËüµÄ¿É±à³ÌÌØÐÔʹËü¶Ô¿ª·¢Æ½Ì¨¸üÓмÛÖµ£¬ÄÜÂú×ãʵʱI/O ¿ØÖƺÍЭÒéµÄת»»Ó¦ÓᣠNPort 4511 ÊÇÁé»îµÄ¡¢¿É¿¿µÄ¡¢ÐԼ۱ȸߵĺͿɿÍÖÆ»¯µÄ½â¾ö·½°¸£¬¸øÏµÍ³µÄÕûºÏÌṩÁ˸ü´óµÄÁé»îÐÔ¡£
NPort 4511¿É±à³ÌÌØÐÔÊÊÓÃËùÓй¤Òµ×Ô¶¯»¯Ó¦ÓÃ
ʵʱ I/O ¿ØÖÆ£¬¿ÉÈ¡´ú´óÁ¿Ç°Öà PC
¿É¿¿µÄϵͳºËÐÄÊÊÓÃÓÚ°²È«ÐԺͳ¤ÆÚÔËÐеÄSCADAÀàÐÍϵͳӦÓÃ
¸ßËÙµÄRS-232/422/485 ºÍÒÔÌ«Íø½Ó¿Ú£¬Èô®¿ÚÉ豸Á¢¼´ÁªÍø
Ìṩ"¿ÍÖÆ»¯"±à³Ì£¬ÎªIA ͨÐÅÌṩ·½±ãµÄЭÒéת»»
¿ÉÔ¶³Ì¿ØÖƺ͹ÜÀí
Ö÷ÒªÊг¡
¹¤Òµ×Ô¶¯»¯
¹¤³§×Ô¶¯»¯
Â¥Óî×Ô¶¯»¯
½»Í¨ÔËÊä
°²·À
SCADA ϵͳ
Ñо¿ÔºËù
Ò½ÁÆ×Ô¶¯»¯
¾ü¹¤
¹æ¸ñ
Ó²¼þ CPU 16-bit, 25 MHz
DRAM 512 KB
Flash 512 KB
¿´ÃŹ· 1
LAN Ethernet 10/100 Mbps, RJ45 x 1
±£»¤ ÄÚ½¨ 1.5 KV µç´Å¸ôÀë
´®¿Ú ½çÃæ RS-232/422/485 Èí¼þÑ¡Ôñ, DB9¿×ʽ x 1
RS-232 ÐźŠTxD, RxD, RTS, CTS, DTR, DSR, DCD, GND
RS-422 ÐźŠTxD+, TxD-, RxD+, RxD-, RTS+, RTS-, CTS+, CTS-, GND
RS-485 ÐźŠData+, Data-, GND
±£»¤ ËùÓÐÐźÅÌṩ15 KV ESD
´®¿ÚͨѶ²ÎÊý ÆæÅ¼Ð£Ñé None, Even, Odd, Space, Mark
Êý¾Ýλ 5, 6, 7, 8
Æðʼλ 1, 1.5, 2
Á÷¿Ø RTS/CTS, XON/XOFF
ËÙÂÊ 50 bps to 230.4 Kbps
LED ָʾµÆ LED ָʾ Power, Link, Ready
»úе¹æ¸ñ »úе¹æ¸ñ ÂÁÖÆ½ðÊôÍâ¿Ç (0.8 mm)
µçÔ´»·¾³ µçÔ´ÊäÈë 9-30 VDC
ÏûºÄ¹¦ÂÊ 300 mA @ 9 VDC (max.)
»·¾³ ¹¤×÷ÎÂ¶È 0 to 55¡ãC(32 ~131 ¡ãC(F), 5 to 95% RH
´¢´æÎÂ¶È -20 to 80¡ãC(C (-4 to 185¡ãC(F), 5 to 95% RH
Mechanical Specifi cations
Agency Approvals EMC FCC Class B, CE Class B
Safety CUL, TUV
Æ·Öʱ£Ö¤ ±£ÐÞ 5ÄêÔ­³§±£ÐÞ
Èí¼þ ÄÚÖòÙ×÷ϵͳ MOXA OS
ÍøÂçЭÒé TCP, UDP, IP, DHCP, ICMP
¿ª·¢»·¾³ ¿ª·¢Æ½Ì¨ Windows 95/98/ME/NT/2000/XP
±àÒëÆ÷/Á¬½ÓÆ÷ Borland Turbo C 2.01 included with license card (SDK is compatible with Borland Turbo C 2.x, Borland C 3.x)
¿ª·¢¿ØÖÆÌ¨ Ethernet
Èí¼þÏÂÔØ¹¤¾ß SDK Manager
µ÷ʽ¹¤¾ß SDK Manager
Library Serial port, Simplified Socket, BSD Socket, System, Flash Access, Debugging, STD C libraries.
Óû§±à³Ì¿Õ¼ä 64 KB¿Õ¼ä
Êý¾Ý´¢´æÁ¿ 32 KB Flash
×î¶àTCPÁ¬½Ó 10 ¸öÁ¬½Ó
×î´óÏß³Ì µ¥Ò»ÈÎÎñ
֪ʶ²úȨ±£»¤ ÌṩÓû§ÖØÒªÈí¼þµÄ±£»¤
¹«Ë¾Ãû³Æ£º Ħɯ¹ú¼ÊóÒ×£¨ÉϺ££©ÓÐÏÞ¹«Ë¾
µç »°£º 021 52589955 / Íõ С ½ã
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÑÓ°²Î÷·1160ºÅÊ×ÐÅÒø¶¼¹ú¼Ê¹ã³¡18²ã
ÓÊ ±à£º 200052
Ö÷ Ò³£º http://www.moxa.com.cn
  • moxa EDR-810ϵÁÐ
  • moxa MD-119ϵÁÐ º£ÊÂרÓÃÏÔʾÆ÷
  • moxa MXview2.3ÍøÂç¹ÜÀíÈí¼þ
  • moxa ioLogik R1241
  • ioLogik R1240
  • moxa ioLogik R1214
  • moxa ioLogik R1212
  • moxa ioLogik R1210
  • moxa IEX-402-VDSL2ϵÁÐ
  • moxa MGate™ 5102-PBM-PNϵÁÐ
