MD-119ϵÁÐÊÇÒ»¿î19Ó¢´çµÄº£ÊÂרÓÃÏÔʾÆ÷¡£×÷Ϊһ̨ECDISÏÔʾÉ豸£¬MD-119²ÉÓÃÁË1280 ¡Á 1024ÏñËØ·Ö±æÂÊ£¬³¤¿í±ÈΪ5:4£¬È«·¶Î§µ÷¹â¼°¹âѧճºÏ¹¦ÄÜ¿ÉÑ¡µÈ¹¦ÄÜ£¬Ê¹Æä²»½öÊÊÓÃÓÚ¸÷ÀàECDISÓ¦Óã¬Ò²Í¬ÑùÊÊÓÃÓÚ¸÷ÀརÇÅÓ¦Óá£
MD-119Å䱸ÁËPIP£¨»Öл£©ºÍPBP£¨×Óĸ»£©¹¦ÄÜ£¬¿ÉÌṩ¶àÆÁÄ»ÏÔʾ£¬Âú×ã¸÷ÀàÓ¦Óõ͍֯ÐèÇó¡£²»½öÈç´Ë£¬MD-119Ö§³ÖACºÍDCµçÔ´ÊäÈ룬ʹÆäºÜ·½±ãµÄ°²×°ÔÚÈκν¢ÇÅÓ¦ÓÃÖУ¬¶øÎÞÐè¶îÍâµÄÓ²¼þÖ§³Ö¡£
ÏÔʾ ÆÁÄ»³ß´ç£º19¡±
³¤¿í±È£º5:4
ÏñËØ£º1280 x 1024
ÏñËØ¼ä¾à (RGB)£º0.294 (H) x 0.294 (V) mm
ÏìӦʱ¼ä£º5 ms (gray to gray)
¶Ô±È¶È£º1000:1
¹âÇ¿£º350 cd/m²
¿ÉÊӽǶȣº85 ¡ã x 80 ¡ã (right-left/up-down)
ÓÐЧÏÔÊ¾Çø£º376.32 (H) x 301.06 (V) mm / 14.81 (H) x 11.85 (V) in
×î´óÉ«²Ê£º16.7M (8 bit)
ÏÔʾÆ÷½Ó¿Ú£ºVGA output x 1£¬DVI-I input x 2£¬BNC composite x 3
·Ö±æÂÊ£º
• VGA: 640 x 480
• SVGA: 800 x 600
• XGA: 1024 x 768
• SXGA: 1280 x 1024
´®¿Ú ´®¿Ú±ê×¼£º1¸öRS-232/422/485´®¿Ú (DB9£¬male)£¬Èí¼þ¿ÉÑ¡£¬1¸ö¹¤³§Ô¤ÁôÓÃÓÚˢй̼þ
´®¿ÚͨѶ²ÎÊý Êý¾Ýλ£º5£¬6£¬7£¬8
ֹͣλ£º1£¬1.5£¬2
УÑéλ£ºNone£¬Even£¬Odd£¬Space£¬Mark
Á÷¿Ø£ºXON/XOFF£¬ADDC® (automatic data direction control) for RS-485
²¨ÌØÂÊ£º9600 Kbps
´®¿ÚÐźŠRS-232: TxD£¬RxD£¬DTR£¬DSR£¬DCD£¬GND
RS-422: TxD+£¬TxD-£¬RxD+£¬RxD-£¬GND
RS-485-4w: TxD+£¬TxD-£¬RxD+£¬RxD-£¬GND
RS-485-2w: Data+£¬Data-£¬GND
Ç°Ãæ°å LED£ºStorage£¬Power
OSD£º5 x OSD control USB£º1¸öUSB 2.0¶Ë¿Ú£¬ÓÃÓÚ´¥ÃþÆÁ¹¦ÄÜ£¨¿ÉÑ¡£©
»úÐµÌØÐÔ Íâ¿Ç£ºÂÁÖÆÍâ¿Çv
ÖØÁ¿£º9.7 kg
³ß´ç£º82 x 483 x 444 mm (3.23 x 19.02 x 17.48 in)
°²×°·½Ê½£ºÂñÈë°²×°
¹¤×÷»·¾³ ¹¤×÷ζȣº-15 ~ 55 ¡ãC (5 ~ 131 ¡ãF)
´æ´¢Î¶ȣº-20 ~ 60 ¡ãC (-4 ~ 140 ¡ãF)
Ïà¶Ôʪ¶È£º5 ~ 95% (non-condensing)
¿¹Õñ£º
• IEC 60945
• DNV 2.4£¬Class A/Class C
µçÔ´ÐèÇó ÊäÈëµçѹ£º
• 24 VDC (with tolerance from 18 to 36 VDC£¬2-pin terminal block)
• 115 ~ 230 VAC£¬50/60 Hz
µçÔ´¹¦ºÄ£º42 W
• 1.75 A @ 24 VDC
• 0.38 A @ 110 VAC
°²¹æÈÏÖ¤ Safety: UL/cUL£¬CCC (pending) EMC: EN 55022 Class B£¬EN 55024-4-2£¬EN 55024-4-3£¬EN 55024-4-4£¬FCC Part 15 Subpart B Class A Marine: IEC 60945 4th (pending)£¬DNV (pending)£¬IACS-E10 (pending) Green Product: RoHS£¬cRoHS£¬WEEE ¿É¿¿ÐÔ ×Ô¶¯ÖØÆð´¥·¢Æ÷£ºÄÚ½¨WDT£¨¿´ÃŹ·¶¨Ê±Æ÷£©£¬Ö§³Ö1-255ˮƽµÄʱ¼ä¼ä¸ôϵͳ¸´Î»£¬Èí¼þ¿ÉÑ¡ MTBF (mean time between failures)£º39£¬675 hrs ±£ÐÞ ±£ÐÞÆÚ£º1Äê
