¼ò½é
ioLogik R12012ÖÇÄÜRS-485´®¿ÚÔ¶³ÌI/OÊÇÒ»¿î¾ßÓиßÐԼ۱ȡ¢Éè¼Æ¿É¿¿ÇÒÒ×ÓÚά»¤µÄÔ¶³ÌI/O¡£¶Ô¹¤³Ìʦ¶øÑÔ£¬²¼ÏßÒ²±äµÃ·Ç³£¼òµ¥£¬Ö»ÐèÒªÁ½¸ùÏ߾ͿÉÒÔ½«´®¿ÚI/OÓë¿ØÖÆÆ÷»òÆäËûRS-485É豸½øÐÐÁ¬½Ó¡£´®¿ÚÔ¶³ÌI/O²ÉÓÃEIA/TIA RS-485ͨѶÐÒ飬¿ÉÒÔÌṩ³¤¾àÀëµÄ¸ßËÙÊý¾ÝÊÕ·¢¡£MoxaÖÇÄÜ´®¿ÚÔ¶³ÌI/OÖ§³Öͨ¹ýÈí¼þ»òUSB½øÐÐͨѶÅäÖ㬶ÀÌØµÄË«RS-485´®¿ÚÉè¼ÆÃâ³ýÁ˹¤³Ìʦ¶ÔÊý¾Ý²É¼¯ºÍ¿ØÖÆÏµÍ³µÄÅäÖúÍά»¤¹¤×÷¡£²»½öÈç´Ë£¬MoxaÌṩÁ˲»Í¬µÄI/O×éºÏ£¬Îª²»Í¬Ó¦ÓÃÌṩÁ˸ü´óµÄÁé»îÐÔ¡£
ÌØµã
- Á½¸öRS-485´®¿Ú£¬ÄÚÖÃÖÐ¼ÌÆ÷
- Ö§³Ö¶àµãͨÐŲÎÊý°²×°
- °²×°Í¨Ñ¶²ÎÊý£¬²¢Í¨¹ýUSBÉý¼¶¹Ì¼þ
- ͨ¹ýRS-485Á¬½ÓÉý¼¶¹Ì¼þ
- Ö§³Ö¿íÎÂÐͺţ¨-40 ~ 85 ¡æ£©
ÊäÈëºÍÊä³ö Êý×ÖÊäÈ룺8¸öͨµÀ
¿ÉÅäÖÃDIO£º8¸öͨµÀ
¸ôÀë±£»¤£º3K VDC »ò 2K Vrms
Êý×ÖÊäÈë ´«¸ÐÆ÷ÀàÐÍ£ºÊª½Óµã (NPN or PNP)£¬¸É½Óµã
I/OÀàÐÍ£ºDI»òʱ¼ä¼ÆÊýÆ÷
¸É½Óµã£º
• On: short to GND
• Off: open
ʪ½Óµã (DI to GND)£º
• On: 0 to 3 VDC
• Off: 10 to 30 VDC
¹²½ÓÀàÐÍ£º8µã/COM
¼ÆÊýÆ÷ƵÂÊ£º2.5 kHz£¬¶Ïµç´æ´¢
Êý×Ö¹ýÂËʱ¼ä¼ä¸ô£ºÈí¼þ¿ÉÑ¡
Êý×ÖÊä³ö ÀàÐÍ£ºSink
I/OÀàÐÍ£ºDO»òÂö³åÊä³ö
Âö³åÊä³öƵÂÊ£º5 kHz
¹ýѹ±£»¤£º45 VDC
¹ýÁ÷±£»¤£º2.6 A (4 channels @ 650 mA)
¹ýιرձ£»¤£º175 ¡ãC (typical)£¬150 ¡ãC (min.)
¶î¶¨µçÁ÷£º200 mA per channel
µçÔ´ÐèÇó ÊäÈëµçѹ£º24 VDC nominal£¬12 ~ 48 VDC
´®¿ÚͨѶ ½çÃæ£ºRS-485-2w: Data+£¬Data-£¬GND (5-contact terminal block)
´®¿ÚÊý¾ÝÏß±£»¤£º15 kV ESDÈ«Ðźű£»¤
´®¿ÚͨѶ²ÎÊý УÑéλ£ºNone£¬Even£¬Odd (default = None)
Êý¾Ýλ£º8
ֹͣλ£º1£¬2 (default = 1)
²¨ÌØÂÊ£º1200 ~ 921.6 kbps (default = 9600)
RS-485ÉÏÀ/ÏÂÀµç×裺1 k¦¸£¬150 k¦¸
ÐÒ飺Modbus RTU
»úÐµÌØÐÔ ²¼ÏߣºI/O cable max. 16 AWG
³ß´ç£º27.8 x 124 x 84 mm (1.09 x 4.88 x 3.31 in)
¹¤×÷»·¾³ ¹¤×÷ζȣº
±ê×¼Ðͺţº-10 ~ 70 ¡ãC (14 ~ 158 ¡ãF)
¿íÎÂÐͺţº-40 ~ 85 ¡ãC (-40 ~ 185 ¡ãF)
´æ´¢Î¶ȣº-40 ~ 85 ¡ãC (-40 ~ 185 ¡ãF)
Ïà¶Ôʪ¶È£º5 ~ 95% (non-condensing)
°²¹æÈÏÖ¤ Safety: UL 508
EMI:
EN 55022£¬EN 61000-3-2£¬EN 61000-3-3£¬
FCC Part 15 Subpart B Class A
EMS:
EN 55024£¬IEC 61000-4£¬IEC 61000-6
Shock: IEC 60068-2-27
Freefall: IEC 60068-2-32
Vibration: IEC 60068-2-6
±£ÐÞ ±£ÐÞÆÚ£º5Ä꣨ioLogik R1214³ýÍ⣩
