NPH7 series Non-Polarized Miniaturized 7mm height 105℃超小型品
1. 本体之高度缩短至7m/m,适用于轻薄小型化之电子产品.
Developed short body length to 7m/m, for the demand of smaller and thinner electronic equipment.
2. 适用于极性反转回路,例如:信号交连或HI-FI高级音响设备如喇叭等。
NP series capacitors are suitable for crossover network for HI-FIequipment’s and speakers, etc.
3. 具容量误差小,频率响应高之特质。
Have excellent frequency characteristic and small deviation of Capacitance.
Specifications
No. |
Item |
Performance |
1 |
使用温度范围
Operating Temperature Range |
-40℃ to +105℃ |
2 |
定格电压范围
Rated Working Voltage Range |
6.3-63V.DC |
3 |
静电容量范围
Capacitance Tolerance |
0.1-47µF |
4 |
静电容量容许差
±20% (at+25℃,120Hz) |
5 |
泄漏电流
Leakage Current |
I≤0.03CV or 3(µA) after five minutes |
6 |
损失角
Dissipation Factor(tanδ)
(120Hz\+25℃) |
Working Voltage (v) |
6.3 |
10 |
16 |
25 |
35 |
50 |
63 |
tanδ max. |
0.30 |
0.25 |
0.20 |
0.15 |
0.15 |
0.13 |
10 |
7 |
温度特性(at 120 Hz)
Characteristics at low temperature (stability at 120Hz) |
Working Voltage (V) |
6.3 |
10 |
16 |
25 |
35 |
50 |
63 |
-25℃/+20℃ |
4 |
3 |
2 |
2 |
2 |
2 |
2 |
-40/℃+20℃ |
8 |
6 |
4 |
4 |
3 |
3 |
3 |
8 |
高温负荷特性
High Temperature Loading |
After1000 hrs. application of DC rated working voltage at +105℃.
The capacitor shall meet the following limits:
Post test requirements at + 25℃
Leakage current |
≤ the Initial specified value |
Capacitance change |
≤±20% of initial measured value |
Dissipation Factor(tanδ) |
≤200% of initial specified value |
9 |
高温无负荷特性
Shelf Life |
After storage for 500hrs. at+105℃ with no voltage applied.
Post test requirements at+25℃
Same limits for high temperature lading.
