Front Panel: Aluminium bezel with strengthened glass
Mounting: Panel mount
Construction:heavy duty steel chassis with VESA 75/ 100mm standard screw holes
Optional: Rack mount; Swivel ARM, Desk Stand
Input signal: VGA
Control: on front panel
Power Supply: External 48W DC 12V power adapter
OS Support: MS DOS, Windows 98/SE, Windows NT4.0, Windows 2000, Windows XP
Dimensions (W x H x D) : 439 x 345.8x 55.2mm
Packing Dimension:530x160x 470mm
NET weight: 7.2KG
Gross weight: 7.7 KG
Response Time: 12ms (Typ.)
Viewing Angle: -70¡ã ~ +70¡ã (H), -70¡ã ~+70¡ã (V)
Signal Connector: 15 Pin D-SUB
Function Control: Power Switch, Menu, Select (+, -), Auto
OSD: Brightness, Contrast, H/V Position, Color, Phase, Clock, Management
LCD
Display Type : 17" SXGA TFT LCD
Resolution : 1280 ¡Á 1024
Max.color : 16M
Luminance : 300 cd/m2
View Angel : 160¡ã(H) , 160¡ã(V)
Pixel Pitch : 0.264 x 0.264 mm
Contrast Ratio : 700 : 1
Response Time : 8 ms
Power Consumption : 22 W
LCD MTBF : 50,000hrs
Touchscreen(optional)
Type: Analog resistive type : 25VDC ¡Ý 20M ¦¸
Resolution: continuous
Light transmission: 80% or more
Controller: RS-232 interface( or USB option)
Power consumption:<5V @1mA
Surface hardness : 3H
Operating force : ¡Ü 100g
Life expectancy : 1 Million
Environmental
Operating temperature: 0¡ãC to 45¡ãC ( 32¡ãF ~ 113¡ãF )
Storage temperature: -20¡ãC to 60¡ãC ( -4¡ãF ~ 140¡ãF )
Storage humidity: 10% to 95%@ 40¡ãC ,non-condensing,
Vibration: 10 ~ 150Hz, 0.15mm 10 cycles 1G
Shock: 30G peak acceleration (11 msec. duration)
Water Proof: Front Panel IP65 Certificated
