免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → SR9000 Smart Star System
产品名称: SR9000 Smart Star System
型 号:
价 格: 0.00
品 牌: rabbit
The Smart Star is a modular and expandable embedded control system designed for demanding real-time control and data acquisition applications. Multiple I/O card options--including digital, A/D, D/A, and relays--allow users to closely match their specific I/O needs. The Smart Star CPU card comes in both Ethernet and non-Ethernet versions, and a cost-effective keypad/display is also available.
Ethernet connectivity—CPU card with or without Ethernet
Flexible functionality—modular configuration to easily interchange or replace individual I/O cards
Multiple I/O card options—digital I/O, A/D, D/A, relay
Expandable—up to 168 I/O
Cost-effective—low cost per I/O
Optional keyboard/display—backlit 122 x 32 pixel graphic LCD with 7 user-relegendable keys, 7 LEDs
To make integration easy, the Smart Star has been designed from the ground up, with careful consideration given to configuration, implementation, and maintenance requirements. Modular expansion allows you to use the same Smart Star architecture in both small or large applications and where cost and physical size are critical. Unprecedented I/O density is provided with up to 168 I/O supported in a panel size less than 27.3 square inches.
The basic Smart Star system consists of a rugged backplane with power supply, a CPU card, and one or more I/O cards of your choice. The Smart Star backplane is available in two models, the 8-slot SR9010 and the 4-slot SR9050. With one slot on the backplane reserved for the CPU, remaining slots can be utilized for any combination of I/O cards, giving designers a customizable platform for their applications. The CPU card is powered by the Rabbit 2000™ microprocessor operating at 22.1 MHz and features 512K of Flash memory and up to 512K of SRAM for program and data storage.
Connections to I/O cards are via pre-assembled flat ribbon-cable assembly or optional field wiring terminals (FWTs). Ribbon-cable provides the lowest cost connection for high-volume applications with no variation in wiring from unit to unit. FWTs provide pluggable or screw-type terminals for discrete, customized connections and easy field maintenance.
Programming the Smart Star
Programs are developed using Z-World's industry-proven Dynamic C® software development system. An extensive library of drivers and sample programs is provided, along with royalty-free TCP/IP stack with source. The Smart Star can be programmed and debugged over Ethernet/Internet using appropriate accessory hardware. For optional keypad/display, software libraries and a built-in converter program facilitate display of international characters, bitmap images, and graphic constructs such as circles, lines, and squares.
公司名称: Digi International(香港)有限公司
电 话: 021 51506898 / 刘浩传
手机:
地 址: 上海市徐汇区零陵路899号飞洲国际广场26L
邮 编: 200030
主 页: http://www.digi.com.cn
  • MiniCore™ RCM5700 体积紧凑的经济型核心模块
  • RCM5400W RabbitCore核心模块
  • Rabbit 5000 微处理器
  • RCM2200 RabbitCore核心模块
  • RCM2100 RabbitCore核心模块
  • RCM2000 RabbitCore核心模块
  • Rabbit 4000微处理器
  • Rabbit 3000 TFBGA 微处理器
  • Rabbit 3000 微处理器
  • Rabbit 2000 微处理器
