Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÖ÷»úÄ£¿é6ES7 315-2AH14-0AB0
²úÆ·Ãû³Æ£º Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÖ÷»úÄ£¿é6ES7 315-2AH14-0AB0
ÐÍ ºÅ£º 6ES7 315-2AH14-0AB0
Æ· ÅÆ£º 1
300PLCÑ¡ÐÍ
ÀàÐÍ Ãû³Æ ±¸×¢ ¶©»õºÅ Ìæ´úÀúÊ· ÊýÁ¿
µçÔ´Ä£¿é PS 307 120/230 V AC /24 V DC £» 2 A 6ES7 307-1BA01-0AA0 6ES7 307-1BA00-0AA0
PS 307 120/230 V AC /24 V DC £» 5 A 6ES7 307-1EA01-0AA0 6ES7 307-1EA00-0AA0
PS 307 120/230 V AC /24 V DC £» 10 A 6ES7 307-1KA02-0AA0 6ES7 307-1KA01-0AA0
´æ´¢¿¨ MMC, 64 KB   6ES7 953-8LF20-0AA0
MMC, 128 KB   6ES7 953-8LG20-0AA0
MMC, 512 KB   6ES7 953-8LJ30-0AA0 6ES7 953-8LJ20-0AA0
MMC, 2 MB   6ES7 953-8LL31-0AA0
MMC, 4 MB   6ES7 953-8LM20-0AA0
MMC, 8 MB   6ES7 953-8LP20-0AA0
µ¼¹ì µ¼¹ì160MM   6ES7390-1AB60-0AA0
µ¼¹ì480MM   6ES7390-1AE80-0AA0
µ¼¹ì530MM   6ES7390-1AF30-0AA0
µ¼¹ì650MM   6ES7390-1AF85-0AA0
µ¼¹ì830MM   6ES7390-1AJ30-0AA0
½ô´ÕÐÍ CPU CPU 312C 10 DI/6 DO,2 FAST COUNTERS (10KHZ)£¬(1 X 40PIN) 6ES7 312-5BF04-0AB0 6ES7312-5BE03-0AB0
CPU 313C 24 DI/16 DO, 4AI, 2AO 1 PT100,3 FAST COUNTERS (30 KHZ), (2 X 40PIN) 6ES7 313-5BG04-0AB0 6ES7313-5BF03-0AB0
CPU 313C-2 PtP 16 DI/16 DO,3 FAST COUNTERS (30 KHZ),(1 X 40PIN) 6ES7 313-6BG04-0AB0 6ES7313-6BF03-0AB0
CPU 313C-2 DP 16 DI/16 DO,3 FAST COUNTERS (30 KHZ),(1 X 40PIN) 6ES7 313-6CG04-0AB0 6ES7313-6CF03-0AB0
CPU 314C-2 PtP 24 DI/16 DO, 4AI, 2AO, 1 PT100,4 FAST COUNTERS (60 KHZ),(2 X 40PIN) 6ES7 314-6BH04-0AB0 6ES7314-6BG03-0AB0
CPU 314C-2 DP 24 DI/16 DO, 4AI, 2AO, 1 PT100,4 FAST COUNTERS (60 KHZ), (2 X 40PIN) 6ES7 314-6CH04-0AB0 6ES7314-6CG03-0AB0
±ê×¼ÐÍ CPU CPU 312   6ES7 312-1AE14-0AB0 6ES7312-1AE13-0AB0
CPU 314   6ES7 314-1AG14-0AB0 6ES7314-1AG13-0AB0
CPU 315-2 DP   6ES7 315-2AH14-0AB0 6ES7315-2AG10-0AB0
CPU 317-2 DP   6ES7 317-2AK14-0AB0 6ES7317-2AJ10-0AB0
PN CPU CPU 314C-2PN/DP 24 DI/16 DO, 4AI, 2AO, 1 PT100,4 FAST COUNTERS (60 KHZ), (2 X 40PIN) 6ES7 314-6EH04-0AB0
CPU 315-2 PN/DP   6ES7 315-2EH14-0AB0 6ES7315-2EH13-0AB0
CPU 317-2 PN/DP 1.  MPI/DP 12MBIT/S, 2. ETHERNET PROFINET, 6ES7 317-2EK14-0AB0 6ES7317-2EK13-0AB0
CPU 319-3 PN/DP 1. MPI/DP 12MBIT/S,2. DP-MASTER/SLAVE,3.ETHERNET PROFINET 6ES7 318-3EL01-0AB0 6ES7 318-3EL00-0AB0
DIÊäÈë SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 24VDC¡£ 20ÕëǰÁ¬ 6ES7 321-1BH02-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 24VDC£¬µÍ̬ÓÐЧ¡£ 20ÕëǰÁ¬           6ES7 321-1BH50-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 24VDC£¬ÓÃÓÚµÈʱÏßģʽÏÂÔËÐР0.05msÊäÈëÑÓʱ¡£ 20ÕëǰÁ¬ 6ES7 321-1BH10-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 24-48VDC¡£ 20ÕëǰÁ¬ 6ES7 321-1CH00-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 48-125VDC     20ÕëǰÁ¬ 6ES7 321-1CH20-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 120/230VAC    20ÕëǰÁ¬ 6ES7 321-1FH00-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 16 µãÊäÈ룬 24VDC£¬ÓÃÓÚµÈʱͬ²½Ä£Ê½ÏÂÔËÐУ¬¾ßÓÐÕï¶ÏÄÜÁ¦  20ÕëǰÁ¬ 6ES7 321-7BH01-0AB0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 32 µãÊäÈ룬 24VDC     40ÕëǰÁ¬ 6ES7 321-1BL00-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 32 µãÊäÈ룬 120VAC     40ÕëǰÁ¬ 6ES7 321-1EL00-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 64 µãÊäÈ룬 24VDC£¬µÍ̬ÓÐЧ¡£ÐèÒª¶Ë×Ó°å6ES7392-1 ANDCABLES 6ES7392-4 6ES7 321-1BP00-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬 120/230VAC  20ÕëǰÁ¬ 6ES7 321-1FF01-0AA0
SM321Êý×ÖÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬 120/230VAC£¬¸÷ÊäÈëµã¸ôÀë   40ÕëǰÁ¬ 6ES7 321-1FF10-0AA0
DOÊä³ö SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬ 24VDC£¬ 2A   20ÕëǰÁ¬ 6ES7 322-1BF01-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬ 24VDC£¬ 0.5A£¬Õï¶ÏÄÜÁ¦    20ÕëǰÁ¬ 6ES7 322-8BF00-0AB0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬ 48-125VDC£¬ 1.5A   20ÕëǰÁ¬ 6ES7 322-1CF00-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 16 µãÊä³ö£¬ 24VDC£¬ 0.5A      20ÕëǰÁ¬ 6ES7 322-1BH01-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 16 µãÊä³ö£¬ 24VDC£¬ 0.5A£¬¸ßËÙ 20ÕëǰÁ¬ 6ES7 322-1BH10-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 16 µãÊä³ö£¬ 24/48VDC£¬ 0.5A    40ÕëǰÁ¬ 6ES7 322-5GH00-0AB0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 32 µãÊä³ö£¬ 24VDC£¬ 0.5A      40ÕëǰÁ¬ 6ES7 322-1BL00-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 32 µãÊä³ö£¬ 120VAC£¬ 1A       20ÕëǰÁ¬2¸ö 6ES7 322-1FL00-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 64 µãÊä³ö£¬ 24VDC£¬ 0.3A 6ES7 322-1BP00-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 64 µãÊä³ö£¬ 24VDC£¬ 0.3A 6ES7 322-1BP50-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬ 120/230VAC£¬ 1A   ¿É¿Ø¹è ½»Á÷   20ÕëǰÁ¬ 6ES7 322-1FF01-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬ 120/230VAC£¬ 2A   ¿É¿Ø¹è ½»Á÷   40ÕëǰÁ¬ 6ES7 322-5FF00-0AB0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 16 µãÊä³ö£¬ 120/230VAC£¬ 1A  ¿É¿Ø¹è ½»Á÷   20ÕëǰÁ¬ 6ES7 322-1FH00-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬¼ÌµçÆ÷£¬ 2A    20ÕëǰÁ¬ 6ES7 322-1HF01-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬¼ÌµçÆ÷£¬ 5A    40ÕëǰÁ¬ 6ES7 322-1HF10-0AA0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 8 µãÊä³ö£¬¼ÌµçÆ÷£¬ 5A£¬´ø¹ýѹRC Â˲¨Æ÷±£»¤  40ÕëǰÁ¬ 6ES7 322-5HF00-0AB0
SM322Êý×ÖÁ¿Êä³öÄ£¿é 16 µãÊä³ö£¬¼ÌµçÆ÷£¬ 8A     20ÕëǰÁ¬ 6ES7 322-1HH01-0AA0
DI/DO SM323Êý×ÖÁ¿ÊäÈëÊä³öÄ£¿é 8ÊäÈ룬8Êä³ö     20ÕëǰÁ¬ 6ES7 323-1BH01-0AA0
SM323Êý×ÖÁ¿ÊäÈëÊä³öÄ£¿é 16ÊäÈ룬16Êä³ö   40ÕëǰÁ¬ 6ES7 323-1BL00-0AA0
SM327Êý×ÖÁ¿ÊäÈëÊä³öÄ£¿é 8 µãÊäÈ룬 8 µãÊäÈë»òÊä³ö( ¿ÉÉèÖÃ)   20ÕëǰÁ¬ 6ES7 327-1BH00-0AB0
AI SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬 13 Î»·Ö±æÂÊ    40ÕëǰÁ¬ 6ES7 331-1KF02-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬 9/12/14 Î»·Ö±æÂÊ    20ÕëǰÁ¬ 6ES7 331-7KF02-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 2 µãÊäÈ룬 9/12/14 Î»·Ö±æÂÊ    20ÕëǰÁ¬ 6ES7 331-7KB02-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬ÔöÇ¿ÐÍ16 Î»·Ö±æÂÊ    40ÕëǰÁ¬ 6ES7 331-7NF00-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬ÔöÇ¿ÐÍ16 Î»·Ö±æÂÊ£¬ 4 Í¨µÀģʽ    40ÕëǰÁ¬ 6ES7 331-7NF10-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬 14 Î»·Ö±æÂÊ£¬ÓÃÓÚµÈʱģʽÏÂÔËÐР  20ÕëǰÁ¬ 6ES7 331-7HF01-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬ÓÃÓÚÈȵç×è    40ÕëǰÁ¬ 6ES7 331-7PF01-0AB0
SM331 Ä£ÄâÁ¿ÊäÈëÄ£¿é 8 µãÊäÈ룬ÓÃÓÚÈȵçż    40ÕëǰÁ¬ 6ES7 331-7PF11-0AB0
AO  SM332 Ä£ÄâÁ¿Êä³öÄ£¿é 4 Â·Êä³ö       20ÕëǰÁ¬ 6ES7 332-5HD01-0AB0
SM332 Ä£ÄâÁ¿Êä³öÄ£¿é 4 Â·Êä³ö£¬ 16 Î»   20ÕëǰÁ¬ 6ES7 332-7ND02-0AB0
SM332 Ä£ÄâÁ¿Êä³öÄ£¿é 2 Â·Êä³ö    20ÕëǰÁ¬ 6ES7 332-5HB01-0AB0
SM332 Ä£ÄâÁ¿Êä³öÄ£¿é 8 Â·Êä³ö    40ÕëǰÁ¬ 6ES7 332-5HF00-0AB0
AI/AO SM335 ¿ìËÙÄ£ÄâÁ¿ÊäÈë/Êä³öÄ£¿é Õï¶Ï£»Öжϣ¬ 4 Â·ÊäÈ룬 14 Î»·Ö±æÂÊ£¬ 4 Â·Êä³ö£¬ 11/12 Î» 6ES7 335-7HG01-0AB0
  IM 174 PROFIBUS ½Ó¿ÚÄ£¿é IM 174 6ES7 174-0AA10-0AA0
¹¦ÄÜÄ£¿é FM 350-1 ¼ÆÊýÆ÷Ä£¿é µ¥Í¨µÀ£¬×î´ó500 kHz £»ÓÃÓÚÔöÁ¿Ê½±àÂëÆ÷ 6ES7 350-1AH03-0AE0
FM 350-2 ¼ÆÊýÆ÷Ä£¿é 8 Í¨µÀ£¬×î´ó20 kHz £»ÓÃÓÚ 24 V ÔöÁ¿Ê½±àÂëÆ÷ºÍNAMUR ´«¸ÐÆ÷ 6ES7 350-2AH00-0AE0
FM 351 ¶¨Î»Ä£¿é ÓÃÓÚ¿ìËÙÒÆ¶¯ºÍÂýËÙÇý¶¯ 6ES7 351-1AH01-0AE0
FM 352 µç×Ó͹ÂÖ¿ØÖÆÆ÷   6ES7 352-1AH02-0AE0
FM 352-5 ¸ßËÙ²¼¶û´¦ÀíÆ÷ ´øÓЩÐÍÊä³ö 6ES7 352-5AH00-0AE0
FM 352-5 ¸ßËÙ²¼¶û´¦ÀíÆ÷ ´øÓÐÔ´ÐÔÊä³ö 6ES7 352-5AH10-0AE0
FM 355 ±Õ»·¿ØÖÆÄ£¿é FM 355 C ¿ØÖÆÆ÷Ä£¿é£¬´ø4 ¸öÄ£ÄâÁ¿Êä³ö£¬ÓÃÓÚ4 ¸öÁ¬Ðø¶¯×÷¿ØÖÆÆ÷ 6ES7 355-0VH10-0AE0
FM 355 ±Õ»·¿ØÖÆÄ£¿é FM 355 S ¿ØÖÆÆ÷Ä£¿é£¬´ø8 ¸öÊý×ÖÁ¿Êä³ö£¬ÓÃÓÚ4 ²½½ø»òÂö³å¿ØÖÆÆ÷ 6ES7 355-1VH10-0AE0
FM 355-2 ±Õ»·Î¶ȿØÖÆÄ£¿é FM 355-2 C Î¶ȿØÖÆÆ÷£¬´ø4 ¸öÄ£ÄâÁ¿Êä³ö£¬ÓÃÓÚ4 ¸öÁ¬Ðø¶¯×÷¿ØÖÆÆ÷ 6ES7 355-2CH00-0AE0
FM 355-2 ±Õ»·Î¶ȿØÖÆÄ£¿é FM 355-2 S Î¶ȿØÖÆÆ÷Ä£¿é£¬´ø8 ¸öÊý×ÖÁ¿Êä³ö£¬ÓÃÓÚ4 ²½½ø»òÂö³å¿ØÖÆÆ÷ 6ES7 355-2SH00-0AE0
SM 338 POS ÊäÈëÄ£¿é ʹÓôøÆð/ Í£½Ó¿ÚµÄ³¬Éù²¨±àÂëÆ÷½øÐÐλÖüì²â 6ES7 338-4BC01-0AB0
ÌØÊâÄ£¿é SM 374 ·Âտģ¿é   6ES7 374-2XH01-0AA0
DM 370 Õ¼Î»Ä£¿é   6ES7 370-0AA01-0AA0
ͨѶģ¿é CP 340 ´øÒ»¸öRS 232C(V.24) ½Ó¿Ú 6ES7 340-1AH02-0AE0
CP 340 ´øÒ»¸ö20mA(TTY) ½Ó¿Ú 6ES7 340-1BH02-0AE0
CP 340 ´øÒ»¸ö RS 422/485 (X.27) ½Ó¿Ú 6ES7 340-1CH02-0AE0
CP 341 ´øÒ»¸öRS 232C(V.24) ½Ó¿Ú 6ES7 341-1AH01-0AE0
CP 341 ´øÒ»¸ö20mA(TTY) ½Ó¿Ú 6ES7 341-1BH01-0AE0
CP 341 ´øÒ»¸ö RS 422/485 (X.27) ½Ó¿Ú 6ES7 341-1CH01-0AE0
MODBUS ´ÓÕ¾    6ES7870-1AB01-0YA0
MODBUS ´ÓÕ¾  ²»º¬Èí¼þ 6ES7870-1AB01-0YA1
MODBUS Ö÷Õ¾    6ES7870-1AA01-0YA0
MODBUS Ö÷Õ¾  ²»º¬Èí¼þ 6ES7870-1AA01-0YA1
CP 343-2 AS-Interface 6GK7 343-2AH00-0XA0
CP 343-2 P AS-Interface 6GK7 343-2AH10-0XA0
CP 342-5 PROFIBUS£¬µç¿Ú 6GK7 342-5DA02-0XE0
CP 342-5 FO PROFIBUS£¬¹â¿Ú 6GK7 342-5DF00-0XE0
CP 343-5 PROFIBUS£¬ FMS£¬ S7 /PG/OP Í¨Ñ¶£¬ 6GK7 343-5FA01-0XE0
CP 343-1 Lean Ö§³ÖTCP/IP ¡¢ UDP 6GK7343-1CX10-0XE0 6GK7343-1CX00-0XE0
CP 343-1 Ö§³ÖTCP/IP ºÍ UDP 6GK7343-1EX30-0XE0 6GK7343-1EX21-0XE0 6GK7-343-1EX00-0XE0
CP 343-1 IT Ö§³Ö Ind.Ethernet,FTP£¬ e-mail ,WWW server 6GK7343-1GX21-0XE0 6GK7343-1GX20-0XE0
CP 343-1 PN Ö§³ÖPN,PROFINET,TCP/IP 6GK7 343-1HX00-0XE0
½Ó¿ÚÄ£¿é IM 360 ½Ó¿ÚÄ£¿é ÓÃÓÚʹÓà3 ¸öÀ©Õ¹µ¥ÔªÀ©Õ¹ S7-300£¬¿É²åÈëÖÐÑë¿ØÖÆÆ÷ 6ES7 360-3AA01-0AA0
IM 361 ½Ó¿ÚÄ£¿é ÓÃÓÚʹÓà3 ¸öÀ©Õ¹µ¥ÔªÀ©Õ¹ S7-300£¬¿É²åÈëÀ©Õ¹µ¥Ôª 6ES7 361-3CA01-0AA0
Á¬½ÓµçÀ 2.5Ã× 6ES7368-3BC51-0AA0
Á¬½ÓµçÀ 1Ã× 6ES7368-3BB01-0AA0
Á¬½ÓµçÀ 5Ã× 6ES7368-3BF01-0AA0
Á¬½ÓµçÀ 10Ã× 6ES7368-3CB01-0AA0
IM 365 ½Ó¿ÚÄ£¿é 2Ä£¿é + Á¬½ÓµçÀ 1M À©Õ¹1ÅÅÓà 6ES7365-0BA01-0AA0
UÐÍÁ¬½Ó UÐͱ³°å×ÜÏßÁ¬½ÓÆ÷ I/OÄ£¿éUÐͱ³°å×ÜÁ¬½ÓÆ÷ 6ES7390-0AA00-0AA0
ǰÁ¬½ÓÆ÷ 20 F-C ǰÁ¬½ÓÆ÷ 6ES7392-1AJ00-0AA0
40 F-C ǰÁ¬½ÓÆ÷ 6ES7392-1AM00-0AA0
°²È«F CPU CPU 315F-2 PN/DP 1. INTERFACE MPI/DP 12MBIT/S,2. INTERFACE ETHERNET PROFINET, 6ES7 315-2FJ14-0AB0 6ES7315-2FH13-0AB0
CPU 315F-2DP   6ES7 315-6FF04-0AB0 6ES7315-6FF01-0AB0
CPU317F-2 PN/DP 1. INTERFACE MPI/DP 12MBIT/S,2. INTERFACE ETHERNET PROFINET, 6ES7 317-2FK14-0AB0 6ES7317-2FK13-0AB0
CPU 317F-2DP 1. INTERFACE MPI/DP 12MBIT/S,2. INTERFACE DP-MASTER/SLAVE, 6ES7 317-6FF04-0AB0 6ES7317-6FF03-0AB0
CPU319F-3 PN/DP 1. MPI/DP 12MBIT/S,2. DP-MASTER/SLAVE,3.  ETHERNET PROFINET, 6ES7 318-3FL01-0AB0 6ES7318-3FL00-0AB0
F Êý×ÖÁ¿/
Ä£ÄâÁ¿Ä£¿é
SM 326 F Êý×ÖÁ¿ÊäÈëÄ£¿é- °²È«¼¯³É 24 µãÊäÈ룬 24V DC           40Õë 6ES7 326-1BK02-0AB0 6ES7 326-1BK01-0AB0
SM 326 F Êý×ÖÁ¿ÊäÈëÄ£¿é- °²È«¼¯³É 8 µãÊäÈ룬 24V DC£¬ NAMUR    40Õë 6ES7 326-1RF00-0AB0
SM 326 F Êý×ÖÁ¿Êä³öÄ£¿é- °²È«¼¯³É 10 µãÊä³ö£¬ 24 V DC£¬ 2 A 6ES7 326-2BF10-0AB0 6ES7 326-2BF01-0AB0
SM 326 F Êý×ÖÁ¿Êä³öÄ£¿é- °²È«¼¯³É 10 µãÊä³ö£¬ 24 V DC£¬ 2 A 6ES7 326-2BF41-0AB0 6ES7 326-2BF40-0AB0
SM 336 F Ä£ÄâÁ¿Êä³öÄ£¿é- °²È«¼¯³É 6 Â·ÊäÈ룬 14 Î»             20Õë 6ES7 336-4GE00-0AB0 6ES7 336-1HE00-0AB0
SM 336 F Ä£ÄâÁ¿Êä³öÄ£¿é- °²È«¼¯³É 6 Â·ÊäÈ룬 16 Î»£¬ HART 6ES7 336-1GE00-0AB0 6ES7 336-1GE00-0AB0
Ô˶¯T CPU CPU 315T-2 DP 1. INTERFACE MPI/DP 12MBIT/S 2. INTERFACE DP(DRIVE), 6ES7 315-6TH13-0AB0
CPU 317T-2 DP 1. INTERFACE MPI/DP 12MBIT/S 2. INTERFACE DP(DRIVE), 6ES7 317-6TK13-0AB0
TF CPU  CPU 317TF-2 DP 1. INTERFACE MPI/DP 12MBIT/S 2. INTERFACE DP(DRIVE), 6ES7 317-6TF14-0AB0
TÈí¼þ°ü S7 Technology V3.0 SIMATIC S7 CPU 315T/317T-2DP£¬¼¼ÊõÈÎÎñ×é̬ºÍ±à³ÌÈí¼þ°ü£¬ STEP7 5.3 SP3 ÒÔÉÏ 6ES7864-1CC42-0YA5 6ES7864-1CC30-0YX0
Êý×ÖÁ¿Èë 4 µãÊäÈë µçÆø¸ôÀ룬 NAMUR 6ES7 321-7RD00-0AB0
Ä£ÄâÁ¿³ö 4 Â·Êä³ö µçÆø¸ôÀ룬 24VDC£¬ 10Ma 6ES7 322-5SD00-0AB0
4 Â·Êä³ö µçÆø¸ôÀ룬 15VDC£¬ 20mA 6ES7 322-5RD00-0AB0
Ä£ÄâÁ¿Èë 4 Â·ÊäÈë µçÆø¸ôÀ룬 0/4-20mA£¬ 15 Î» 6ES7 331-7RD00-0AB0
8/4 Â·ÊäÈë µçÆø¸ôÀ룬ÓÃÓÚÈȵçżºÍPt100£¬ Pt200£¬ Ni100 6ES7 331-7SF00-0AB0
Ä£ÄâÁ¿³ö 4 µãÊä³ö µçÆø¸ôÀ룬ÓÃÓÚÈȵçżºÍPt100£¬ Pt200£¬ Ni100 6ES7 332-5RD00-0AB0
¿íΠ  300ÓпíεIJúÆ·£¬¶©»õºÅ6AG1312-5BE03-2AB0¶ÔÓ¦³£¹æµÄ6ES7312-5BE03-0AB0
¹«Ë¾Ãû³Æ£º ÉîÛÚÊоýöÎÔ´¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 22951149 / ÌÆì¿ì¿
ÊÖ»ú£º 13713800051
µØ Ö·£º ÉîÛÚÊÐÂÞºþÇøËñ¸ÚÀæÔ°Â·44ºÅµÚÒ»ÉÌÎñ´óÏÃ513
ÓÊ ±à£º 518055
Ö÷ Ò³£º http://www.zgzuoke.com.cn
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÄ£¿é6ES72151AG400XB0
  • Î÷ÃÅ×Óпî7´ç´¥ÃþÆÁ6AV6648-0BC11-3AX0
  • Î÷ÃÅ×Ó200½ø¿ÚPLC
  • Î÷ÃÅ×Ó300CPUÖ÷»ú
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÖ÷»úÄ£¿é6ES72881ST400AA0
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÄ£¿é6EP1336-3BA10
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÖ÷»úÄ£¿é6ES7 315-2AH14-0AB0
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×Ó´¥ÃþÆÁ6AV21240GC010AX0
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÄ£¿é6ES71326BF000BA0
  • Á¿¶à¼ÛÓÅÎ÷ÃÅ×ÓÄ£¿é6ES72881SR200AA0
