Ìæ´ú¹¤Òµ¼ÆËã»úµÄ¾¼ÃÐÍ·½°¸ ÊʺϹ¤ÒµÓ¦ÓõÄÉè¼Æ ÊÊÓÃÓÚ¶àÖÖÓ¦ÓÃ: ÐÒéת»»£¬Ô¶³Ì·ÃÎÊ£¬Event Handling¼°ÆäËü
UC-7408ÊÇרΪǶÈëʽӦÓöøÉè¼ÆµÄǶÈëʽ¹¤Òµ¼ÆËã»ú£¬¾ß±¸8¸öRS-232/422/485´®¿Ú£¬Ë«10/100 MbpsÒÔÌ«ÍøÂç¶Ë¿Ú£¬PCMCIA×÷ÎÞÏßͨѶ£¬ÒÔ¼°À©³äÓõÄCompactFlash½Ó¿Ú¡£
Ëæ»úÔ¤ÏȰ²×°Linux²Ù×÷ϵͳ£¬ÈÃÈí¼þ¹¤³Ìʦ¿ÉÑ¡Ôñ×ÔÐпª·¢Ó¦ÓóÌÐò£¬»òÕßÊÇÇáËÉÇÒÃâ·ÑµØÊ¹Óÿª·Å³ÌÐò´úÂë¡£ÕâÒâζ×ÅΪÕë¶Ô×ÀÉÏÐÍPCËùдµÄÈí¼þ²»ÐèÒª×÷ÈκγÌÐò´úÂëµÄÐÞÕý¾Í¿ÉÒÔÇáÒ×µØÍ¸¹ýGNU cross compilerÒÆµ½UC-7408ƽ̨ÉÏ¡£
8-chÊý×ÖÊäÈ룬8-chÊý×ÖÊä³ö UC-7408¾ß±¸8¸öRS-232/422/485´®¿Ú£¬Ôö¼Ó8-chÊý×ÖÊäÈ룬8-chÊý×ÖÊä³ö£¬Ê¹UC-7408³ÉΪרΪÊý¾ÝÌáÈ¡¶øÉè¼ÆµÄǶÈëʽ¹¤Òµ¼ÆËã»ú¡£
UC-7408ǶÈëʽ¹¤Òµ¼ÆËã»ú¾ß±¸8-chÊý×ÖÊäÈ룬8-chÊý×ÖÊä³ö£¬ÈÃÊý×ÖI/OÉ豸¿ÉÒÔÇáËÉÁ¬½ÓÒÔÌ«ÍøÂç¡£UC-7408¿É×÷ΪÊý×ÖÊäÈë/Êä³öµÄÏà¹ØÐźſØÖÆ¡£¾ÓÉUC-7408µÄÊý×ÖÊäÈëÐŵÀ£¬¿ÉÒÔÁ¬½Ó²¢Õì²âÍⲿÊý×ÖI/OÉ豸µÄÊý×ÖÊä³öѶºÅ±ä»¯£¬¶ø¾ÓÉUC-7408µÄÊý×ÖÊä³öÐŵÀ´«ËÍÊý×ÖѶºÅ£¬½«¿ÉÇáÒ׿ØÖÆÍⲿÊý×ÖI/OÉ豸¡£
Å䱸Êý×ÖÊäÈë/Êä³ö×°Öü°RS-232/422/485´®¿ÚµÄUC-7408½«ÄܽøÒ»²½µÄ¼ò»¯ÏµÍ³£¬ÇáËɽøÐÐÕûºÏÐԵĿØÖÆ, ÊÇרΪÊý¾ÝÌáÈ¡¼°ÐÒéת»»¶øÉè¼ÆµÄǶÈëʽ¹¤Òµ¼ÆËã»ú¡£
Ó¦ÓÃ
- ¾ß±¸8¸öRS-232/422/485´®¿Ú¿É×÷Êý¾ÝÌáÈ¡
- Êý×ÖÊäÈë/Êä³öµÄÏà¹ØÐźſØÖÆ
- ÐÒéת»»
- ¿É͸¹ýWeb Browser½øÐÐÔ¶³Ì·ÃÎÊ¼à¿Ø
- Ðè±£ÕÏÍøÂ簲ȫµÄÉ豸Á¬Íø¿ØÖÆÓ¦ÓÃ
Ä¿±êÊг¡
- ¹¤Òµ×Ô¶¯»¯
- ´óÂ¥×Ô¶¯»¯
- ½»Í¨×Ô¶¯»¯
- »·¾³¼à¿Ø
- Ò½ÁÆ×Ô¶¯»¯
ǶÈëʽϵͳ·¢Õ¹Ç÷ÊÆ£¨PDF£¬180KB£© ¹¤ÒµÁìÓòÖÐÒѽøÐвÉÓà RISC-based ¡¢ all-in-one ¼ÆËã»úÇÒʹÓÃÄÚ½¨ Linux ²Ù×÷ϵͳ¡£ÕâÀàÐ͵ļÆËã»úÔÚǰ¶Ë´¦ÀíÖÐ±ÈÆð´«Í³µÄ IPC £¬¹¦ÄÜÇ¿´ó¡¢Ò²½Ï¼á¹ÌÄÍÓò¢ÇÒÓÐЧµÄ½ÚÊ¡³É±¾¡£ | |
Ó²¼þ | |
| Intel Xscale IXP-422 266 MHz | | |
| ×Ô¶¯Õì²âË«10/100 MbpsÒÔÌ«ÍøÂç¶Ë¿Ú | | |
| DI x 8, DO x 8, TTL (3.3V) | | |
| None, Even, Odd, Space, Mark | | |
| P1-P8 (Tx/Rx), LAN1, LAN2, ¿ØÖÆÌ¨, Ready | | |
| Cardbus card and 16-bit PCMCIA 2.1/JEIDA 4.2 card ** | | |
| CF x 1, full function *** | | |
| -10 ÖÁ 60¡ãC (14ÖÁ140¡ãF), 5 ÖÁ 95% RH | | |
| -20 ÖÁ 80¡ãC (-4ÖÁ176¡ãF), 5 ÖÁ 95% RH | | |
| CE, FCC, Class A, TÜV, UL | | |
*USB HostºÍClient¹¦Äܱ£Áô×÷ΪδÀ´É豸Éý¼¶Ö®Óà *PCMCIA ×÷ΪÎÞÏßͨѶ֮Óà *CompactFlash ×÷ΪÀ©³ä½éÃæ | | | | |
Linux |
| TCP, UDP, IPv4, SNMP V1/V3, ICMP, IGMP, ARP, HTTP, CHAP, PAP, SSH 1.0/ 2.0, SSL, DHCP, NTP, NFS, SMTP, Telnet, FTP, PPP, PPPoE | | |
| bash, busybox, tinylogin, telnet, ftp, scp | | |
telnetd: Telnet Server daemon ftpd: FTP server daemon sshd: Secure shell server Apache: Web server daemon, supports PHP and XML MySQL: Database Server and Client OpenVPN: Virtual private network service manager iptables: Firewall service manager pppd: dial in/out over serial port daemon & PPPoE snmpd: snmpd agent daemon inetd: TCP server manager program | | |
Moxa Linux API Library Linux Tool Chain: Gcc, Glibc, GDB Windows Tool Chain: Gcc, Glibc, Insight (Windows-based source level debug utility) UC Finder: UCs LAN IP broadcast search utility for Windows and Linux | | |
| PCMCIA CardBus (supports 802.11b/g wireless LAN Card), CF Card, Watchdog Timer (WDT), UART, RTC, Buzzer Moxa 2G NPort Real TTY Driver | | | |
Windows CE 5.0 |
| TCP, UDP, IPv4, SNMP, ICMP, IGMP, ARP, HTTP, CHAP, PAP, SSL, DHCP, SNTP, SMTP, Telnet, FTP, PPP | | |
| ϵͳӦÓóÌÐò |
Windows command shell, telnet, ftp, web-based administration manager |
Telnet Server: Allows remote administration through a standard telnet client FTP Server: Used for transferring files to and from remote computer systems via a network. Web Server (httpd): WinCE IIS, offer ASP, ISAPI Secure Socket Layer support, SSL 2, SSL 3, and Transport Layer Security (TLS/SSL 3.1) public key-based protocols, and Web Administration ISAPI Extensions. Dial-up Networking Service: RAS client API and PPP, support Extensible Authentication Protocol (EAP) and RAS scripting | | |
Moxa WinCE 5.0 SDK C Libraries and Run-times Component Services (COM and DCOM) Microsoft Foundation Classes (MFC) Microsoft? .NET Compact Framework XML, including DOM, XQL, XPATH, XSLT, SAX2 SOAP Toolkit Winsock 2.2 | | |
| PCMCIA CardBus, CF Card, Watchdog Timer (WDT) API, UART, RTC, Buzzer | | | |
UC-7408-LX | |
| »ùÓÚRISC¼Ü¹¹£¬¿ÉʵÏÖÊý¾Ý²É¼¯µÄÖÇÄÜͨѶ·þÎñÆ÷£¬Å䱸8¸ö´®¿Ú£¬8¸öDI/DOͨµÀ£¬2¸öÍø¿Ú£¬PCMCIA£¬CompactFlash£¬Linux 2.4²Ù×÷ϵͳ | |
UC-7408-LX Plus | |
| »ùÓÚRISC¼Ü¹¹£¬¿ÉʵÏÖÊý¾Ý²É¼¯µÄÖÇÄÜͨѶ·þÎñÆ÷£¬Å䱸8¸ö´®¿Ú£¬8¸öDI/DOͨµÀ£¬2¸öÍø¿Ú£¬PCMCIA£¬CompactFlash£¬Linux 2.6²Ù×÷ϵͳ | |
UC-7408-CE | |
| »ùÓÚRISC¼Ü¹¹£¬¿ÉʵÏÖÊý¾Ý²É¼¯µÄÖÇÄÜͨѶ·þÎñÆ÷£¬Å䱸8¸ö´®¿Ú£¬8¸öDI/DOͨµÀ£¬2¸öÍø¿Ú£¬PCMCIA£¬CompactFlash£¬WinCE 5.0²Ù×÷ϵͳ | |
1̨UC-7408
¿ìËÙ°²×°ÊÖ²á
±Ú¹Ò°²×°Ì×¼þ
µ¼¹ì°²×°Ì×¼þ
°üº¬Èí¼þºÍ˵Ã÷ÊéµÄCD
ÍøÏߣºRJ45-RJ45½»²æÍøÏߣ¬100cm
ConsoleÏߣºCBL-RJ45F9-150 8-pin RJ45 to female DB9 cable£¬150cm
´®¿ÚÏߣºCBL-RJ45M9-150 8-pin RJ45 to male DB9 cable£¬150cm
µçÔ´ÊÊÅäÆ÷£¨°üÀ¨¶Ë×ÓÅŵ½µçÏß²åÍ·µÄת»»Æ÷£©
²úÆ·±£ÐÞÊÖ²á | | | |
