Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú MOXA Ö÷¶¯Ê½ÒÔÌ«ÍøI/O·þÎñÆ÷ ioLogik E2214
²úÆ·Ãû³Æ£º MOXA Ö÷¶¯Ê½ÒÔÌ«ÍøI/O·þÎñÆ÷ ioLogik E2214
ÐÍ ºÅ£º ioLogik E2214
6¸öDI£¬Ö§³ÖPNP£¬NPNºÍ¸É½áµã
6¸öAÐͼ̵çÆ÷Êä³ö£¨³£¿ª£©
¼ÌµçÆ÷¹æ¸ñ£º5A/250 VAC£¬5A/30 VDC
ͨ¹ýTCP£¬UDP£¬e-mailºÍSNMP trapÁ¢¼´±¨¸æÊ¼þ
µçÔ´¶Ïµçʱ±£´æDIºÍ¼ÌµçÆ÷Êä³ö״̬
ͨ¹ýUtilityºÍWebÁ½ÖÖ·½Ê½½øÐÐÅäÖÃ
¸ù¾ÝÉ趨³õʼ»¯¼ÌµçÆ÷ÉϵçʱµÄ״̬
¼òµ¥Ò×ÓõÄClick&Go™ Logic£¬ÊµÏÖ±¾µØ¿ØÖÆ
Ö§³ÖWinCE VB/VCºÍLinux C API
ͨ¹ýModubs/TCPºÍSNMPЭÒé¿ØÖÆI/O
¸ÅÊö
¹©µçʧ°ÜµÄÇé¿öϱ£´æ¼ÌµçÆ÷¼ÆÊý
ioLogik E2214Éè¼ÆÓÃÓڼǼÄÚÖü̵çÆ÷Êä³öµÄ´ÎÊý¡£¼´±ãÔÚµçÔ´¹©µçʧ°ÜµÄÇé¿öÏ£¬E2214ÈÔ¿ÉÒԼǼϼ̵çÆ÷µÄ×îºóÒ»´Î¶¯×÷¡£
ÌØµã
¹æ¸ñ
LAN
ÒÔÌ«Íø
10/100 Mbps, RJ45
1.5 KV µç´Å¸ôÀë±£»¤
ЭÒé
Modbus/TCP, TCP/IP, UDP, DHCP, Bootp, SNMP (MIB for I/O and Network), HTTP, Active I/O Messaging, IP filtering
´®¿Ú
½Ó¿Ú
RS-485 (2Ïß): Data+, Data-, GND
´®¿Ú±£»¤
15 KV ESD
´®¿ÚͨѶ²ÎÊý
ÆæÅ¼Ð£Ñé
ÎÞ
Êý¾Ýλ
8
ֹͣλ
1
Á÷Á¿¿ØÖÆ
ÎÞ
ͨѶËÙÂÊ
1200 bps ~ 115200 bps
ЭÒé
Modbus/RTU
µçÔ´ÒªÇó
ÊäÈëµçÔ´
24 VDC 񈏄, 12 ~ 48 VDC
ÏÖ³¡µçÔ´
24 VDC ±êÅä, ×î¸ß 36 VDC
»úе¹æ¸ñ
½ÓÏß
I/O cable max. 14 AWG
¹¤×÷»·¾³
²Ù×÷ζÈ
-10 to 60¡æ (14 to 140¨H), 5 ~ 95% RH
´¢´æÎ¶È
-2-6-20 to 85¡æ (-4 to 185¨H), 5 ~ 95%RH
Êý×ÖÊäÈë
ÊäÈëͨµÀ
6¸ö
´«¸ÐÆ÷ÀàÐÍ
NPN£¬PNPºÍ¸É½áµã
I/Oģʽ
DI»ò¼ÆÊýÆ÷(×î¸ß¿É´ï900 Hz)
¸É½Úµã
Logic 0£ºshort to GND
Logic 1£ºopen
ʪ½Úµã
Logic 0£º0 ~ 3 VDC
Logic 1£º10 ~ 30 VDC
¹²µØÀàÐÍ
6µã/2 COM
¸ôÀë±£»¤
2 K VDC»ò3 K Vrms
¼ÆÊýÆ÷ƵÂÊ
900 Hz
Êý×ÖÐźŹýÂ˼ä¸ô
10 ms
¹ýѹ±£»¤
+36 VDC
´æ´¢¼ÌµçÆ÷¼ÆÊý
ÊÇ
Êý×ÖÊä³ö
ͨµÀ
6ͨµÀ£¬5A£¬AÐͼ̵çÆ÷Êä³ö£¨³£¿ª£©
´¥µãÈÝÁ¿
5A @ 30 VDC£¬5A @ 240 VAC£¬5A @ 110 VAC
¸ÐÐÔ¸ºÔØ
2A
µç×è¸ºÔØ
5A
»÷´©µçѹ
500 VAC
¼ÌµçÆ÷±ÕºÏ/¶Ï¿ªÊ±¼ä
10ms£¬5ms (×î´ó)
¾øÔµµç×è
1G min.@ 500 VDC
ʹÓÃÊÙÃü
100,000 times (³£¹æ)
´¥µç×迹
30 m Ohm (×î´ó)
Âö³åÊä³ö
20´Î/·ÖÖÓ£¨ÏßÐÔ¸ºÔØ£©
¸ôÀë±£»¤
3 K VDC»ò2 K Vrms
°²¹æÈÏÖ¤
EMI
FCC Part 15, CISPR(EN55022) Class A
EMS
IEC 61000-4, IEC 61000-6
³å»÷
IEC60068-2-27
µøÂä
IEC60068-2-32
Õñ¶¯
IEC60068-2-6
±£ÐÞÆÚ
2Äê
¶©¹ºÐÅÏ¢
ioLogik E2214
Ö÷¶¯Ê½ÒÔÌ«ÍøI/O·þÎñÆ÷£¬Å䱸6¸öDIºÍ6¸ö¼ÌµçÆ÷Êä³ö
LDP1602
LCDÏÔʾÆÁ£¬5¸ö°´Å¥£¬16x2Îı¾ÏÔʾ
¹«Ë¾Ãû³Æ£º Ħɯ¹ú¼ÊóÒ×£¨ÉϺ££©ÓÐÏÞ¹«Ë¾
µç »°£º 021 52589955 / Íõ С ½ã
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÑÓ°²Î÷·1160ºÅÊ×ÐÅÒø¶¼¹ú¼Ê¹ã³¡18²ã
ÓÊ ±à£º 200052
Ö÷ Ò³£º http://www.moxa.com.cn
  • moxa EDR-810ϵÁÐ
  • moxa MD-119ϵÁÐ º£ÊÂרÓÃÏÔʾÆ÷
  • moxa MXview2.3ÍøÂç¹ÜÀíÈí¼þ
  • moxa ioLogik R1241
  • ioLogik R1240
  • moxa ioLogik R1214
  • moxa ioLogik R1212
  • moxa ioLogik R1210
  • moxa IEX-402-VDSL2ϵÁÐ
  • moxa MGate™ 5102-PBM-PNϵÁÐ
