Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 20 Mega Êý¾Ý²É¼¯¿¨
²úÆ·Ãû³Æ£º 20 Mega Êý¾Ý²É¼¯¿¨
ÐÍ ºÅ£º PCI 102
Pci StbBciSoftwareAdas Electronique
Description
  • Analog or digital inputs management
  • RAMS BUFFER 512K or 2M meas.
  • 2K-sample measurements table
  • Two operating modes:
    SINGLE-EVENT or FLIP/FLOP
  • Very high acquisition speed up to:
    20.000.000 measurements/s
  • Programmable acquisition rates
  • EXTERNAL/INTERNAL Clocks/triggers/synchronizations
  • Pre and post TRIGGER with timing changes in all three areas
  • Intern./extern. time-stamping of sequences Datation
  • Several coupler boards
  • High transfer rate > 40Mb/s
  • PCI Master/ Slave standard
  • Couplers: PCI 220, PCI 224, PCI 228, PCI 238, PCI 264 (inputs)
  • Support & supply of drivers (option )
Adas board
Description
Designed for rapid acquisition of analog and digital parameters, the PCI 102 provides an acquisition rate of 20 M. measurements/second.
It is a scope-like device, with functions such as: delayed time base / auto mode / TRIGGER / EXTERNAL or INTERNAL sync., etc.
Much attention was paid to event date/time stamping in order to be able to manage acquisition timing in a very accurate way.
The PCI 102 features a very large "measurements" resident BUFFER (512K or 2M.measurements), that frees the PCI bus.
he PCI 102 can be used in various areas such as rapid acquisition processing, imaging, spectrum analysis, transient analysis, radars, medical instruments, etc.
Iqnet
9 rue Georges Besse ¨C BP 47 ¨C 78330 FONTENAY LE FLEURY ¨C FRANCE
T¨¦l.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
PCI 102
20 M. ANALOG AND DIGITAL ACQ. / S
PCI 102
SPECIFICATIONS (t = 25¡ãC)
TYPE
ANALOG AND DIGITAL ACQUISITIONS MANAGEMENT BOARD
MODE
PATTERNS TABLE
- Number of samples 2K samples per pattern, programmable sample depth
- PCI access
16 bits read/written in memory
MEASUREMENTS RAMS
- Number 2 concatenable sets
- Capacity 1 - 4MB
- PC access
32 bits read/written in memory
ACQUISITION RATES
- Number 2 (F1, F2)
- Timers 1 x 32 bits for F1 acquisition rates
1 x 16 bits for F2 acquisition rates
1 x 16 bits for cutoff frequencies
- External frequency 0 - 4MHz
- Storage frequency
20MHz
TIME/DATE STAMPING
- Overall time/date stamping 32-bit counter
- TRIGGER date Storage in 32 bits
- Time/date resolution
Local time/date clock 125ns, / 2 for external date/clock
INTERFACE
PCI 32-bit Master/Slave board
INTERFACE TO COUPLERS
Connection to analog and digital boards through private bus lines.
POWER SUPPLY
- Voltage
+ 5V / 3A
PHYSICAL CHARACTERISTICS
- Format in mm PCI large format
- Front panel connectors
« D » 15 pins connectors
ENVIRONMENT
- Operating temperature 0¡ãC to + 60¡ã C
- Storage temperature - 10¡ãC to + 70¡ã C
- Relative humidity
90 % (without condensation)
NORMES EUROPENNES
  EMC - EN 61326
  CE Compliance
  ROHS - 2002/95/EC
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÉê¿Ë¹¤ÒµÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83841930 / ÕÔºè±ó
ÊÖ»ú£º 13537649763
µØ Ö·£º ÉîÛÚÊÐ ¸£ÌïÇø ¸£Ç¿Â·32ºÅ
ÓÊ ±à£º 518048
Ö÷ Ò³£º http://www.sz-victory.com.cn
  • 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
  • Î÷ÃÅ×Ó74ϵÁз§Óö¨Î»Æ÷
  • Î÷ÃÅ×ÓÖÇÄÜ·§ÃŶ¨Î»Æ÷
  • Î÷ÃÅ×Ó353¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó352P¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó·§Óö¨Î»Æ÷
  • ADAS ICV726Ä£ÄâÁ¿Êä³ö¿¨
  • ·¨¹úADAS¼ÆÊý¿¨
  • Î÷ÃÅ×Ó73ϵÁз§Óö¨Î»Æ÷
  • 20 Mega Êý¾Ý²É¼¯¿¨
