Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
²úÆ·Ãû³Æ£º 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
ÐÍ ºÅ£º PCI 264
Æ· ÅÆ£º 1
Pci
Description
  • 64 digital I/O programmed using 8-channel ports
  • High switching power 70V/100mA
  • TTL compatible Inputs / Outputs
  • Protected inputs (70V)
  • Readable by PCI 102
  • Read / Write by PCI DX6
  • Output readback
  • 16 interrupt sources
  • "Photo" and external latch mode
  • High reliability / High density
  • I/O space in 32 bits
  • Support and supply of drivers (option)
Adas board
Description
The PCI 264 provides 64 digital inputs / outputs programmed by 8-channel ports.
The outputs are able to supply the necessary power for items such as: small relays, lamps, displays, etc.
The inputs are protected by diodes (70V max.) and remain TTL compatible.
Interrupt triggering can be defined by a change of front for each of the first 16 channels. These interrupt sources are maskable.
The PCI 264 owns a private bus to be managed by PCI 102 or PCI DX6 boards, this in the case of determinable real time applications.
PCI 164 similar software.
Iqnet
9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
Tél.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
PCI 264
64 DIGITAL INPUTS / OUTPUTS
PCI 264
SPECIFICATIONS (t = 25°C)
TYPE
INPUTS
- Number of channels 64
- Direction
Direction programming in 8 groups of 8 channels
DIGITAL OUTPUTS
- Type OPEN COLLECTOR
- DATA 1 = ON ; 0 = OFF
- Max. sust. voltage. 70V
- Max. current 100mA
- Max. power 2W
- Vce SAT < 300mV at 100mA
- Switching time
T"on" = 500ns T”off” = 2.5μs (RL = 1K Ω )
DIGITAL INPUTS
- Type TTL compatible triggers
- Protection 70V max.
- Impedance ≥ 470K Ω
- Readback These inputs enable automatic readback of the channels programmed as outputs
- Input frequency
100KHz maximum
POWER-UP
  Channels programmed as inputs
Output registers at "0" "off" state
INTERRUPTS
  16 channels can generate an interrupt as can the timers
1 interrupt level on &#171;&#160;INTA&#160;&#187;
PCI INTERFACE
- Bus PCI
- Transfers
32 bits in the Memory space
PRIVATE BUS
- Exchanges 16 bits
- Read PCI 102
- Read / Write
PCI DX6
POWER SUPPLY
- Voltage
&#160; + 5V/2A
PRESENTATION
- Dimensions in mm Short PCI format
- Front panel connector
1 μD 68 pins Female
ENVIRONMENT
- Operating temperature 0°C to + 60°C
- Storage temperature - 10°C to + 70°C
- Relative humidity
90 % (without condensation)
EUROPEAN NORMS &#160;
&#160; EMC - EN 61326
&#160; CE Compliance
&#160; ROHS - 2002/95/EC
HOW TO ORDER?
PCI 264
ACCESSORIES
- BCI Terminal blocks BCI 146
- STB Terminal blocks STB546 or
STB534 + STB532/STB520/STB552, or
STB514 + STB516/STB560/BCI140/BCI160
- Cables
WR368
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÉê¿Ë¹¤ÒµÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83841930 / ÕÔºè±ó
ÊÖ»ú£º 13537649763
µØ Ö·£º ÉîÛÚÊÐ ¸£ÌïÇø ¸£Ç¿Â·32ºÅ
ÓÊ ±à£º 518048
Ö÷ Ò³£º http://www.sz-victory.com.cn
  • 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
  • Î÷ÃÅ×Ó74ϵÁз§Óö¨Î»Æ÷
  • Î÷ÃÅ×ÓÖÇÄÜ·§ÃŶ¨Î»Æ÷
  • Î÷ÃÅ×Ó353¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó352P¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó·§Óö¨Î»Æ÷
  • ADAS ICV726Ä£ÄâÁ¿Êä³ö¿¨
  • ·¨¹úADAS¼ÆÊý¿¨
  • Î÷ÃÅ×Ó73ϵÁз§Óö¨Î»Æ÷
  • 20 Mega Êý¾Ý²É¼¯¿¨
