Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ADAS STB532 Êý×ÖÊäÈëÊä³öÖÕ¶Ë¿¨
²úÆ·Ãû³Æ£º ADAS STB532 Êý×ÖÊäÈëÊä³öÖÕ¶Ë¿¨
ÐÍ ºÅ£º STB532
Stb Adas Electronique
Description
  • 32 isolated digital inputs
  • AC or DC signals
  • Adjustable trigger threshold of the 5V level to
    220Vac
  • 2ms input filtering
  • Indicator DELs
  • Galvanic isolation ¡Ý 1.500V from one channel to the other and from the computer
  • Connects directly to ADAS I/O boards
  • Easily mounted on DIN RAIL
  • Small footprint
Description
The STB 532 terminal block is a modular and friendly approach to connecting digital inputs galvanically isolated from each other and from the computer.
Its design makes it directly compatible ADAS I/O boards.
It provides a very attractive price/number of channels ratio.
It has a very small footprint and is easy to mount on DIN RAIL.
Direct outputs to FRONT panel ID 16 indicator.
Iqnet
9 rue Georges Besse ¨C BP 47 ¨C 78330 FONTENAY LE FLEURY ¨C FRANCE
T¨¦l.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
STB 532
32 ISOLATED DIGITAL INPUTS
TERMINAL BLOCK
STB 532
SPECIFICATIONS (t = 25¡ãC)
TYPE
INPUTS
- Number of channels
32
PHOTOCOUPLERS
- Signals AC or DC
- Models H11AA1 (A version)
  HCPL 3700 (B, C, D, E, F versions)
- Levels
Adjustable through injection resistors on 5V contact blocks to 220Vac (trigger threshold to be specified on order)
GALVANIC ISOLATION
- Inter-channel 1.500V
- From the computer
1.500V
CONNECTION
- Type
3 removable screw terminals Ø ¡Ü 1.5 mm2
INDICATORS
- DELs
Inputs are indicated by DELs
FILTERING
- Time constant
2ms
CONNECTIVITY
- Connection to logic input boards By a HE 10 / 50-pt connector
- Connection to remote indicators
By two HE 10 / 20-pt connectors
POWER SUPPLY
- Voltage
+ 5V / 300mA typical
PHYSICAL CHARACTERISTICS
- Dimension in mm (L x W x H) 285 x 125 x 52
- Mounting
On DIN RAIL
ENVIRONMENT
- Operating temperature 0¡ãC to + 60¡ãC
- Storage temperature - 10¡ãC to + 70¡ãC
- Relative humidity
90 % (without condensation)
EUROPEAN NORMS
  EMC - EN 61326
  CE Compliance
  ROHS - 2002/95/EC
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÉê¿Ë¹¤ÒµÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83841930 / ÕÔºè±ó
ÊÖ»ú£º 13537649763
µØ Ö·£º ÉîÛÚÊÐ ¸£ÌïÇø ¸£Ç¿Â·32ºÅ
ÓÊ ±à£º 518048
Ö÷ Ò³£º http://www.sz-victory.com.cn
  • 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
  • Î÷ÃÅ×Ó74ϵÁз§Óö¨Î»Æ÷
  • Î÷ÃÅ×ÓÖÇÄÜ·§ÃŶ¨Î»Æ÷
  • Î÷ÃÅ×Ó353¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó352P¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó·§Óö¨Î»Æ÷
  • ADAS ICV726Ä£ÄâÁ¿Êä³ö¿¨
  • ·¨¹úADAS¼ÆÊý¿¨
  • Î÷ÃÅ×Ó73ϵÁз§Óö¨Î»Æ÷
  • 20 Mega Êý¾Ý²É¼¯¿¨
