Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ADAS STB534Á¬½ÓÊÊÅäÆ÷
²úÆ·Ãû³Æ£º ADAS STB534Á¬½ÓÊÊÅäÆ÷
ÐÍ ºÅ£º STB534Á¬½ÓÊÊÅäÆ÷
Stb Adas Electronique
Description
  • STB 512 : 16/32 Modulo adaptator
    STB 514 : 16/64 Modulo adaptator
    STB 534 : 32/64 Modulo adaptator
  • Low footprint and mounting on a DIN RAIL
  • Lets you switch from modulo 16 to modulo 32, modulo 16 to modulo 64 or modulo 32 to modulo 64 for interfacing BCI and STB series to ADAS I/O
  • Adaptator for flat ribbon
Adas board
Description
The STB 512, STB 514 and STB 534 interconnection terminal blocks simplify the connections between conditioners and I/O boards.
The STB 512 terminal block lets us switch from modulo 32 to 2 x 16.
The STB 514 terminal block lets us switch from modulo 32 to 4 x 16.
The STB 534 terminal block lets us switch from modulo 64 to 2 x 32.
They avoid the use of custom cables thus saving time and increasing productivity.
Other terminal blocks are also available to make our products easy to use in the following environments : MBI, VME/VXI, PC ISA, PC/PCI, CompactPCI, etc.
Iqnet
9 rue Georges Besse ¨C BP 47 ¨C 78330 FONTENAY LE FLEURY ¨C FRANCE
T¨¦l.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
STB 512/514/534
MODULO ADAPTATORS
STB 512/514/534
SPECIFICATIONS (t = 25¡ãC)
STB 512
TYPE
ADAPTER TERMINAL BLOCK
PURPOSE
Switching from modulo 8 to modulo 16
Switching from modulo 16 to modulo 32
Avoids re- cabling
INTERFACE
Digital : STB 516 / STB 560 to I/O boards
Analog : STB 582 to one-wire input analog boards
CONNECTIONS
To terminal blocks : 2 x HE10/50 pins
To boards : 1 x HE10/50 pins
PHYSICAL CHARACTERISTICS
- Dimensions in mm (L x W x H) 52 x 125 x 52
- Mounting
On DIN RAIL
STB 514
TYPE
PURPOSE
Routing a µD68 pins through 4 x HE10/50 pins
INTERFACE
Connects the I/O STB 516 ; STB 540 ; STB 560 and BCI 140, BCI 160
To PC PCI and Compact PCI boards
CONNECTIONS
To process : 4 x HE10/50
To boards : 1 x µD68 pins
- Dimensions in mm (L x W x H) 76 x 125 x 52
- Mounting
On DIN RAIL
STB 534
TYPE
PURPOSE
Routing a µD68 pins through 2 x HE10/50 pins
INTERFACE
Connects the I/O STB 552 ; STB 554 ; STB 520 ; STB 532 etc.
CONNECTIONS
To process : 2 x HE10/50
- Mounting
On DIN RAIL
EUROPEAN NORMS
  EMC - EN 61326
  CE Compliance
  ROHS - 2002/95/EC
¹«Ë¾Ãû³Æ£º ÉîÛÚÊÐÉê¿Ë¹¤ÒµÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 0755 83841930 / ÕÔºè±ó
ÊÖ»ú£º 13537649763
µØ Ö·£º ÉîÛÚÊÐ ¸£ÌïÇø ¸£Ç¿Â·32ºÅ
ÓÊ ±à£º 518048
Ö÷ Ò³£º http://www.sz-victory.com.cn
  • 64 Êý×ÖI/OÊäÈëÊä³ö¿¨
  • Î÷ÃÅ×Ó74ϵÁз§Óö¨Î»Æ÷
  • Î÷ÃÅ×ÓÖÇÄÜ·§ÃŶ¨Î»Æ÷
  • Î÷ÃÅ×Ó353¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó352P¿ØÖÆÆ÷
  • Î÷ÃÅ×Ó·§Óö¨Î»Æ÷
  • ADAS ICV726Ä£ÄâÁ¿Êä³ö¿¨
  • ·¨¹úADAS¼ÆÊý¿¨
  • Î÷ÃÅ×Ó73ϵÁз§Óö¨Î»Æ÷
  • 20 Mega Êý¾Ý²É¼¯¿¨
