²úÆ·Ãû³Æ£º
PLCÍøÂçͨѶģ¿é--DeviceNet½â¾ö·½°¸
ÐÍ ºÅ£º
²úÆ·Ãû³Æ£ºPLCÍøÂçͨѶģ¿é--DeviceNet½â¾ö·½°¸ ±àºÅ£º0 |
SST-DNP-REL
The SST DeviceNet module connects your Reliance AutoMax programmable controller to DeviceNet.
Applications
- scan DeviceNet I/O
- emulate DeviceNet I/O
Features
- two independent DeviceNet connectors
- on board flash for "auto-booting"
- entire DeviceNet protocol is implemented on the module
- UCMM capable, Group 1, 2, and 3 dynamic connections supported
- simultaneous execution of Group 2 Client (master) and Server (slave) operation
- All DeviceNet standard baud rates supported: 125, 250 and 500 Kbaud
- DeviceNet Conformance Tested
Reliance AutoMax Configuration Sample Reliance AutoMax basic software setup and configuration is included with the SST DeviceNet Module.
Certifications
Hardware Specifications
- 40 Mhz AM186EM microprocessor with 512 Kbytes of local RAM
- 512 Kbytes flash allows auto-booting of stored firmware
- DeviceNet compatible 5-pin connector
- DeviceNet compatible network status bicolor LED
- Compatible with CAN specification part A
- Supports standard DeviceNet data rates 125, 250, and 500 Kbaud
- Supports CAN data rates up to 1 Mbaud
- Supports connection to non-powered (3 wire) CAN networks with external 12-24 V supply
- Power requirements: 5 V +/- 5%, 1250 mA
- Operating temperature: 0 to 50C (32 to 122ºF)
- Storage temperature: -25 to 70C (-13 to 158ºF)
Multibus Specifications
- Size: IEEE 796 bus compatible
- Capabilities: memory 8 or 16-bit data width
- Addressing per Channel: memory 20-bit addressing, 64 Kbytes maximum per card
