²úÆ·Ãû³Æ£º
ModiconÍøÂç½Ó¿Ú¿¨
ÐÍ ºÅ£º
²úÆ·Ãû³Æ£ºModiconÍøÂç½Ó¿Ú¿¨ ±àºÅ£º0 |
5136-MOD-ISA
Connects your ISA bus computer to Modicon''s Quantum and 800 Series Remote I/O on the S908 network.
Applications
- PC Control
- I/O Monitoring and Simulation using SST''s I/O Simulation Software
- Network Diagnostics
- Custom Driver Development
SST provides an open documented memory map interface with example C source code and Windows 32-Bit DLLs and drivers.
Hardware Specifications
- 16 Mhz NEC V40
- 128 Kbytes of shared memory in 16, 32, 64, or 128 Kbyte windows
- Philips SC26C562 LAN controller
- Half-length, single width ISA card
- Supports 1.544 Megabits/second
- Uses "F" connector to connect to network
- Supports Remote I/O Master Operation (QRIOM)
-Control up to 32 remote I/O drops -I/O data, traffic cop data, and status information maintained by card -Supports any mixture of Quantum and 800 Series Remote I/O drops
- Supports Remote I/O Slave Operation (QRIO)
-Monitors and emulates up to 32 remote I/O drops -I/O data, traffic cop data, and status information maintained by card -Supports any mixture of Quantum and 800 Series Remote I/O drops
- Operational temperature: 0 to 50C
- Storage temperature: -25 to 70C
- Power requirements: +5 V @ 400 mA, +12 V @ 10 mA, -12 V @ 10 mA
5136-MOD-VME-V4
The Modicon VME card interfaces with the host processor through shared memory. A documented host memory interface is provided. The card does not require external libraries, which simplifies custom driver development in your chosen operating system. DOS example programs with C source are included with each card to assist you with your software development.
- 16 Mhz NEC V40
-Standard: 128 Kbytes on any 256 Kbyte boundary -Short: 6 bytes on any 1024 bytes boundary
- IEEE 1014, 6U height, P1 compatible
