²úÆ·Ãû³Æ£º
¸ß¾«¶ÈζÈÒÇζÈÏÔʾÒÇ:DP3-T200P,DP3-T200K,DP3-T499P,DP3-T499K,DP3-T800P,DP3-T800K
ÐÍ ºÅ£º
DP3-T200P,DP3-T200K,DP3-T499P,DP3-T499K,DP3-T800P,DP3-T800K,DP3-T1200P,DP3-T1200K
¸ß¾«¶ÈζÈÒÇζÈÏÔʾÒÇ:DP3-T200P,DP3-T200K,DP3-T499P,DP3-T499K,DP3-T800P,DP3-T800K,DP3-T1200P,DP3-T1200K,ÌØµã ¡ÑÊÊÓÃζȲâÁ¿¼°ÏÔʾ:¿Í·þרÏߣº13977225107 ¡Ñ ¶àÏîÄ£ÄâÔËËã,¼ì²â¾«¶È¸ß ¡Ñ ÓÐÀä¶Ë²¹³¥×°ÖÃ,¿ÉÅäKÐÍÈȵçż»òÈȵç×èPT100
¡Ñ ÍâÐγߴç48H¡Á96W ¡Ñ ¹¤×÷µçÔ´AC 110/220V 50/60Hz Ðͺż°¼¼Êõ²ÎÊý:ÍпËÖÇÄÜÒDZí(ÁøÖÝ)ÓÐÏÞ¹«Ë¾ ÐͺŠ´«¸ÐÆ÷ ²âÁ¿·¶Î§ ·Ö±çÂÊ ²âÁ¿¾«¶È DP3-T200P Pt100 -100.0¡æ¡«199.9¡æ 0. 1¡æ ¡À0.5%F.S+2digit DP3-T499P Pt100 -100¡æ¡«499¡æ 1¡æ ¡À0.5%F.S+2digit DP3-T499K K 0¡æ¡«499¡æ 1¡æ ¡À0.5%F.S+2digit DP3-T800K K 0¡æ¡«800¡æ 1¡æ ¡À0.5%F.S+2digit DP3-T1200K K 0¡æ¡«1200¡æ 1¡æ ¡À0.5%F.S+2digit ¸ß¾«¶ÈÊý×Ö¹âµç²âËÙ±íתËÙ¼Æ×ªËÙÒDzâËÙ±í²âËÙÒDzâËÙ¼Æ,Êý×ÖʽÊýÂë¹Üµç×Ó½ø¿Ú¼ÆÊýÒǼÆÊý±í013737247708:TCN-P41A,TCN-P61A,TCN-P41B,TCN-P61B,TCN-P41C,TCN-P61C
¶þ¡¢¼¼Êõ²ÎÊý SPECIFICATION T:13737247708 |
¼¼Êõ²ÎÊý Specification \ÐͺÅModel |
Dp3-T200P |
Dp3-T499P |
Dp3-T800K |
Dp3-T1200K |
²âÁ¿·¶Î§ Measuring range |
-199~+199.9¶È |
-199~+499¶È |
0~800¶È |
0~1200¶È |
ÊäÈ뷽ʽ Input mode |
pt100 |
pt100 |
K |
K |
²âÁ¿¾«¶È Measuring accuracy |
¡À0.5%FS¡À2Digit |
¡À2%FS¡À2Digit |
A/Dת»» A/D converter |
¶þ»ýÖØ·Ö Dual slope |
²ÉÑùËÙ¶È Sampling speed |
2.5´Î/Ãë 2.5/sec |
ÏÔʾ Display |
ºìÉ«ÊýÂë¹Ü 14.2mmH LED red 14.2mmH |
µç Ô´ Aux.Power supply |
AC 110V/220V 50/60Hz |
ÍâÐγߴç Outside dimension |
48H£ª96W£ª100D |
¹¤×÷»·¾³ Operating temperaturehumidity |
0~50¶È 45-85%RH |
ÄÍѹǿ¶È Insulation strength |
AC 1500V 1min µçÔ´¶Ë×ÓÓëÍâ½Ó¶Ë×ÓÖ®¼ä |
¾øÔµ×迹 Insulation impedance |
¡ÝDC500V 100M Å· µçÔ´¶Ë×ÓÓëÍâ½Ó¶Ë×ÓÖ®¼ä | ÁøÖÝÍпËÒDZíÌṩ | | |
Èý¡¢¶Ë×ÓÁ¬½Ó CONNECTION :13737247708 |
ËÄ¡¢×¢ÒâÊÂÏî CAUTIONS :13737247708 |
1¡¢¹¤×÷»·¾³Î¶È0~50¶È£¬Ïà¶ÔζÈ85%ÒÔÏ Operate in ambient temperatures of 0 to 50,humidifies of less than 85%R.H. |
2¡¢·ÀֹǿÁÒÕ𶯺ͳå»÷¡£ Avoid operating in an area surrounded by vibrations or shock. |
3¡¢·ÀÖ¹´óÁ¿»Ò³¾ÒÔ¼°Óꦻ¯Ñ§Ò©Æ·ÇÖÈë . Avoid operating in an area surrounded by dust or corrosive materials. |
4¡¢Ê¹ÓÃʱӦԶÀë¸ÉÈÅÔ´. Operationinstallation should be far away from the generating devices. |
5¡¢ÊäÈëµ¼Ïß²»Ò˹ý³¤£¬Ê¹ÓÃÆÁ±ÎÏ߽ϺᣠInput wire should not be too long,use the shielded wire. | | |
