Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ¸ßѹ¼ÌµçÆ÷
²úÆ·Ãû³Æ£º ¸ßѹ¼ÌµçÆ÷
ÐÍ ºÅ£º GRL-1201/GRL-2401
¸ßѹ¼ÌµçÆ÷ÓÖÃû¸É»Éʽ¼ÌµçÆ÷ºÍ¸ßѹ´Å»É¼ÌµçÆ÷»ò´Å»Éʽ¼ÌµçÆ÷: ÊDzÉÓýø¿Ú¸ßѹ¸É»É¹Ü¡¢»·ÑõÊ÷Ö¬¡¢Õë½ÇÒÔ¼°12 VDCÏßȦ»ò24 VDCÏßȦºÍ¸ßѹÏß²Ä×é³É£¬ÄÍѹ¿É´ïµ½10000VDC-15000VDC.£¬¹ã·ºÓÃÓÚÄÍѹ²âÊÔÒÇ,µç»ú²âÊÔÉ豸,Ò½ÁÆÉ豸µÈÒÇÆ÷ÒDZíÁìÓò,¾ÓÁìµ¼ÕßµØÎ»£¬»¶Ó­À´µç×Éѯ£¡
¼ÌµçÆ÷µÄ³ß´çΪ³¤70mm*¿í20mm*¸ß19.86mm
¸ßѹ¼ÌµçÆ÷£¨¸É»Éʽ¼ÌµçÆ÷£©GRL-1201  GRL-1202
Rated Coil Voltage      ¶î¶¨ÏßȦµçѹ£º  12 VDC
Max. Pull-in Voltage   £¨ÎüºÏÉÏÏÞ£©×î´óÆð¶¯µçѹ  £º 8.5 VDC
Min. Drop-out Voltage   £¨ÎüºÏÏÂÏÞ£©×îСÊͷŵçѹ£º  2 VDC
Rated Coil Resistance    ¶î¶¨ÏßȦµç×裺   190¡À5% ¦¸
Wire Ï߲ģº               UL3239 AWG22# 150O ¶È RedºìÉ«
Contact Form             ½Ó´¥·½Ê½£º      A £¨³£¿ª£©
Min. Breakdown Voltage  ×îС±ÀÀ£µçѹ£º  10000  VDC
Switchin Voltage        ¿ª¹Øµçѹ£º 7500 VDC
Max. Switching Power    ×î´ó¹¦ÂÊ£º  50 W
Max. Switching Current   ×î´ó¿ª¹ØµçÁ÷£º3A
Max. Initial Contact Resistance  ×î´ó½Ó´¥µç×裺  100 m¦¸
Insulation resistance    ¾øÔµµç×裺1*1010
Min. Breakdown Voltage Coil-Contact  ×îСÏßȦ´¥µã±ÀÀ£µçѹ£¨¸ºÔصçѹ£©15000 VDC
Operating Temperature Range  ²Ù×÷ζȷ¶Î§£º   -40~+85 ¡æ
¸ßѹ¼ÌµçÆ÷£¨¸É»Éʽ¼ÌµçÆ÷£©GRL-1210  GRL-1212  GRL-1213
Min. Breakdown Voltage  ×îС±ÀÀ£µçѹ£º  15000  VDC
Switchin Voltage        ¿ª¹Øµçѹ£º 10000 VDC
¹«Ë¾Ãû³Æ£º ¶«Ý¸Êи»Åôµç×ÓÖÆÆ·ÓÐÏÞ¹«Ë¾
µç »°£º 0769 83829262 / Ïò·¼Ã·
ÊÖ»ú£º 13798756616
µØ Ö·£º ³£Æ½ÕòÑØºÓ¶«¶þ·20ºÅ
ÓÊ ±à£º 523560
Ö÷ Ò³£º http://www.dgfupeng.com
  • ÅçÂë»úרÓÃҺλ¼Æ
  • PP¸¡Çò
  • ½Ó½ü¿ª¹Ø
  • ²»Ðâ¸ÖË®Á÷¿ª¹Ø
  • ²»Ðâ¸Ö¸¡Çò
  • ¸É»É¹Ü
  • PPҺλ¿ª¹Ø ¸¡Çò¿ª¹Ø
  • ²»Ðâ¸ÖҺλ¿ª¹Ø
  • ¸¡Çò¿ª¹Ø
  • ¸ßѹ¼ÌµçÆ÷
