º«¹úÆðÑÇVX380T|VX420T·¢Ã÷Tapping CenterרÓÃSpecialÖ÷Öá(12,000 rpm)¡£ÅäÖøßÊä³ö¹¦ÂÊÖ±Á¬½á¹¹Ö÷ÖáÂí´ï(11kW)(VX380T)¡£Rigid Tapping 6,000 rpmÒÔ¼°Ö÷Öá´óÈÝÁ¿Amp´îÔØ(VX380T)¡£Ö÷Öá¼Ó¼õËÙ´ï0 ? 12,000 rpmʱΪ0.6 Sec¡£ÅäÖÃBall ScrewÒÔ¼°L/M(NHK)£¬ÒÔʵÏÖ¾²Òô¡¢¶¨ËÙ¡¢Compact»¯¡£¾ßÓÐͬ¼¶²úÆ·ÖÐ×î´óµÄ¼±ÒÆËÍËÙ¶È (56m/min)¡£¼±Çãб´²Éí½á¹¹¿É½øÐÐÁé»î³©Í¨µÄChip´¦Àí¡£
VX380Ti×ê¿×¹¥Ë¿¼Ó¹¤ÖÐÐÄÊÇÔÚVX380T|VX420T»úÐÍÉϵĸĽøÐÍ¡£¡¡¡¡¡¡¡¡
¼¼Êõ¹æ¸ñ²ÎÊý£º
ÏîÄ¿ X-axis Y-axis Z-axis Ö÷Öá¶Ëµ½¹¤×÷̨ÉÏÃæ Ö÷ÖáÖÐÐĵ½Á¢Öù Ë¿¸Ë(Ö±¾¶xÂݾà ) ËÅ·þµç»ú ¿ìÒÆËÙ¶È(X/Y/Z) µ¼¹ìÀàÐÍ(X/Y/Z) ¹¤×÷̨³ß´ç ¹¤×÷̨¸ºÔØ Ö÷Öá×¶¶È Ö÷Öáµç»ú¹¦ÂÊ Ö÷Öá´«¶¯ÐÎʽ Ö÷ÖáתËÙ Ö÷ÖáÀäÈ´ Ö÷Öá×î´óŤ¾Ø/Rpm Ö÷ÖáÖá³ÐÄÚ¾¶ ATCµ¶±ÛÀàÐÍ µ¶¾ßÊýÁ¿ ×î´óµ¶¾ßÖ±¾¶ ×î´óµ¶¾ßÖØÁ¿ Ñ¡µ¶·½Ê½ »»µ¶Ê±¼ä£¨µ¶¶Ôµ¶£© »»µ½Ê±¼ä£¨ÇжÔÇУ© ·À»¤ÕÖ ÀäÈ´ÒºÏäÈÝÁ¿ ´óÁ÷Á¿ÀäÈ´ ´²ÉíÀäÈ´ Optional T-S-C ¾«¶È¶¨Î» ÖØ¸´¶¨Î»¾«¶È Pendant µçÔ´ÈÝÁ¿ ÆøÑ¹ Õ¼µØ³ß´ç(L x W) ¸ß¶È ÖØÁ¿(std.M/C) ¿ØÖÆÏµÍ³NC Unit ÏÔʾÆ÷ ÄÚ´æ »ú´²ÍâÐγߴç(std.M/C) |
µ¥Î» mm mm mm mm mm mm KW m/min - mm kg.f NT Kw - Rpm - Kgf.m/rpm mm Armless ea mm Kg - Sec Sec - liter ?/min ?/min Bar mm mm - V / KVA Kgf/? mm mm Kg - - M mm(W¡ÁL¡ÁH)" |
¹æ¸ñ 520 380 350 480 150~500 150~630 474 X,Y=?25X16, Z=?32¡Á16 1.5/1.5/2.0 60/60/60 Ball L.M 25/30/35 600 X 380 150 #30 3.7/5.5 Ö±Á¬ 10000 / (12000) Ñ¡Ïî 3.4/1500 ?50 ÎÞ±Ûʽ µ¶±Ûʽ 14 20 / 24 ?80 ?65 / (?80) 3 2.8 Ëæ»ú 1.1 0.9 1.9 1.8 ±ê×¼ 200 90 200 20 bar ¡À0.005 ¡À0.002 ÎÞ 220 / 10 5 1720 x 2500 2500 2700 Mitsubishi : M70-B 8.4" Colar TFT 600 1720x2375x2500 |
ÏëÁ˽â¸ü¶àÆðÑǼ°·¢Äǿơ¢´óÍè¡¢Ðֵܡ¢¹þͦµÈ¹úÄÚ×é×°×ê¿×¹¥Ë¿¼Ó¹¤ÖÐÐIJúÆ·ÐÅÏ¢£¬Çë·ÃÄúÎÊÀ¼ÉúÊý¿Ø»ú´²ÓªÏú·þÎñÍøÕ¾£ºwww.lanshengcnc.com £¡
¹«Ë¾µç»°£º0519-88113113/88116544/88101023 ´«Õ棺0519-85104040
ÓÊÏ䣺sale@lanshengcnc.com
×ܾÀí·¶çù£º13306110090 ¡¡¡¡fq@lanshengcnc.com
¹«Ë¾µØÖ·£º³£ÖÝÊÐб±Çøºº½Â·368ºÅ½ð³Ç´óÏÃ1206ÊÒ Óʱࣺ213022
