²úÆ·Ãû³Æ£º
ARBOR Ò½ÁƵçÄÔ M1725
ÐÍ ºÅ£º
M1725
ÌØµã:
. Ò½ÁÆ»ò²¡´²±ßÓéÀÖϵͳӦÓÃ
. Ö§³Ö Intel Core8482; 2 Duo CPU×î¸ß T7400 2.16GHz
. ¿ÉÑ¡ Celeron M 423 1.06GHz CPU
. ÎÞ·çÉÈϵͳ
. Ç°Ãæ°å IP-54ÆÃ½¦, »Ò³¾·À»¤
. ËùÓд®¿Ú¸ôÀëµçÁ÷·À»¤
. ¸ßÈÝÁ¿ï®µç³Ø (7,200mAh)
. ¶àÖÖͨѶ½ÓÈ뷽ʽ (À¶ÑÀ/ÎÞÏß¾ÖÓòÍø/ǧÕ×Íø)
ϵͳ
CPU |
Intel Celeron M ULV 423 1.06GHz (ÎÞ·çÉÈ) »ò Intel Core8482; 2 Duo ´¦ÀíÆ÷×î¸ßT7400 2.16GHz, 4MB L2 Unified, FSB667/533MHz |
ͼÐοØÖÆÆ÷ |
Intel GMA950ÊÓÆµ¿ØÖÆÆ÷, ×î´ó 192MB ¹²ÏíÄÚ´æ |
ÄÚ´æ |
2 x 200 pin SO-DIMM, ×î´ó 4GB˫ͨµÀ DDRII 667/533/400MHz SDRAM |
оƬ×é |
Intel 945GME + Intel ICH7M |
I/O оƬ |
Fintek F81216D + 1 x EC¿ØÖÆÆ÷ |
BIOS |
AMI PnP Flash BIOS |
HDÒôƵ¿ØÖÆÆ÷Ö§³ÖÂó¿Ë·çÊäÈë/Ïß³ö Á½¸öÄÚ²¿ÑïÉùÆ÷(1.5W), Âó¿Ë·çÄÚÖà |
ÍøÂç¿ØÖÆÆ÷ |
1 x Realtek 8111B 1000 base-T PCIeǧÕ×Íø¿¨ |
SATA |
1 x SATA 300MB/s HDD´«ÊäËÙÂÊ |
À¶ÑÀ |
1 x USB½Ó¿ÚÀ¶ÑÀÄ£¿é (¿ÉÑ¡) |
µç³Ø |
7200mAhÄÚÖÃï®µç³Ø (¿ÉÑ¡) |
À©Õ¹×ÜÏß |
1 x PCIe Mini-card (USB »ò PCIe½Ó¿Ú) |
I/O
´®¿Ú |
4 x RS-232´ø¸ôÀë |
USB ½Ó¿Ú |
4 x USB 2.0½Ó¿Ú |
¼üÅÌ/Êó±ê |
1 x PS2¼üÅ̺ÍÊó±ê Mini-DINÁ¬½ÓÆ÷ |
ÍøÂç |
1 x RJ45½Ó¿Ú |
1 x Ïß³ö, 1xÂó¿Ë·çÊäÈë |
VGA |
1 x DB15ĸͷ½Ó¿Ú |
DVI |
1 x DVI½Ó¿Ú |
RJ11 |
1 x RJ11ÊäÈë, 1 x RJ11Êä³ö |
Wi-Fi |
1 x ÎÞÏßÍø¿¨ 802.11b/g/n (¿ÉÑ¡) |
ÖÇÄÜ¿¨¶Á¿¨Æ÷ |
1 x ÖÇÄÜ¿¨¶Á¿¨Æ÷ |
¿ª¹Ø¼°°´¼ü
¹¦Äܼü |
8 x ¿É±à³Ì¹¦Äܼü (F1 ~ F8) |
µçÔ´°´Å¥ |
On/Off¿ª¹Ø |
µç³Ø×´Ì¬ |
µç³ØµÆ (ºì/»Æ) |
µçԴ״̬ |
µçÔ´µÆ (ºì/À¶) |
IDE ״̬ |
IDEµÆ (ºì/ÂÌ) |
LCD ÏÔʾ
³ß´ç/ÀàÐÍ |
17" TFT²Êɫ˫ͨµÀ 24-bit LVDS |
×î´ó·Ö±æÂÊ |
1280(H) x 1024(V), SXGA |
µã¾à |
0.264mm x 0.264mm |
×î¶àÉ«²ÊÊý |
16.7M É« |
ÊÓ½Ç |
140 |
¶Ô±È¶È |
1000:1(Typ) |
ÁÁ¶È |
300 cd/m² |
±³¹â MTBF |
50,000Сʱ |
´¥ÃþÆÁ
ÀàÐÍ |
5ÏßÄ£Äâµç×èʽ |
×î´ó·Ö±æÂÊ |
2048 x 2048 |
¿ØÖÆ½Ó¿Ú |
USB ½Ó¿Ú |
µçÔ´¹¦ºÄ |
5V/70mA (µäÐÍÖµ) |
Çý¶¯Ö§³Ö |
Windows/Linux/MS-DOS/iMac |
ÄÍÓÃÐÔ |
35 Million |
´æ´¢
µçÔ´ÊÊÅäÆ÷
ACÊäÈë |
100 ~ 240VAC (È«·¶Î§) |
ƵÂÊ |
47 ~ 63Hz |
DCÊä³ö |
100W (Max.), 20V@5A |
ÊäÈëµçÁ÷ (rms) |
1.25A@115VAC, 0.5A@230VAC (Max.) |
ЧÂÊ |
88%@ÂúÔØ, 230VAC, Max. |
»ú¹¹Óë»·¾³
¹¤×÷ÎÂ¶È |
0 ~ 40ºC (32 ~ 104ºF) |
´æ´¢Êª¶È |
5 ~ 95% (ÎÞÀäÄý) |
¿¹ÕñÐÔ |
17 to 500Hz, 1G PTP |
¿¹³å»÷ÐÔ |
10G/peak (11m sec) |
»ú¹¹²ÄÖÊ |
ËÜÁÏ |
¹Ì¶¨ |
VESA-75 ¼æÈÝ»ò VESA-100 |
·À»¤µÈ¼¶ |
Ç°Ãæ°å: IP54ÆÃ½¦, »Ò³¾·À»¤ |
³ß´ç (LxHxD) |
454 x 66.5 x 393mm (17.87" x 2.62" x 15.47") |
¶©»õÐÅÏ¢
M1725/T2500-B22 |
17" Ò½ÁÆÆ½°åµçÄÔ(»ÒÉ«)´ø Core8482; 2 Duo T2500 2GHz/ 160GB HDD/ 2GB RAM/ÎÞÏßÍø¿¨/À¶ÑÀ |
ARM-150 |
VESA-75/100×ÀÃæ LCD¼àÊÓÆ÷Ö§±Û |
