²úÆ·Ãû³Æ£º
FPC-7502: Intel Socket G Core i5/i7 Ç¿¹ÌÐÍ Box PC
ÐÍ ºÅ£º
FPC-7502
ϵͳ
CPU |
Intel Socket G Core i5/i7 ϵÁд¦ÀíÆ÷ |
ÄÚ´æ |
2 x 204-pin ˫ͨµÀ DDR3 SO-DIMM ²å²Û×î´ó 8GB 800/1066MHz |
оƬ×é |
Intel QM57 |
ÏÔʾ¼¯³É |
Intel HD ͼÐοØÖÆÆ÷ |
ATA |
2 x SATA ½Ó¿Ú 300MB/s HDD ´«ÊäËÙÂÊ |
ÍøÂçоƬ |
2 x Intel WG82574IT ǧÕ×Íø¿ØÖÆÆ÷ |
¿´ÃŹ· |
1~255 ¼¶ |
I/O
´®¿Ú |
1 x DB-44 ĸͷ¿ØÖÆÆ÷
Ö§³Ö 4 x RS-232 ½Ó¿Ú (COM3, 4 Ϊ RS-232/485 ¿ÉÑ¡) |
USB ½Ó¿Ú |
8 x USB 2.0 ½Ó¿Ú |
ÍøÂç |
2 x RJ-45 ½Ó¿ÚÓÃÓÚǧÕ×Íø |
ÊÓÆµ½Ó¿Ú |
1 x DB-15 ĸͷ½Ó¿ÚÓÃÓÚ RGB
1 x Displayport |
¿ÉÑ¡½Ó¿Ú |
¿É¶þѡһÊý×Ö I/O »ò LPT
1 x 16-bit Êý×Ö I/O, 8 in/8 out
SPP/EPP/ECP ģʽ LPT |
Âó¿Ë·çÊäÈë/Ïß³ö (6W ǰÖ÷Ŵó) |
¼üÅÌ/Êó±ê |
1 x 6-pin Mini-DIN ÓÃÓÚ¼üÅ̺ÍÊó±ê |
GSM/UMTS |
Up to HSUPA 3.75G (¿ÉÑ¡ Mini-card) |
À©Õ¹×ÜÏß |
1 x PCIe x16 ²å²Û´ø riser ¿¨
1 x PCIe x1 ²å²Û´ø riser ¿¨
1 x Mini-card ²å²Û
1 x SIM ²å²Û |
»·¾³
¹¤×÷ÎÂ¶È |
-20 ~ 55¡ãC (-4 ~ 131¡ãF), ÖÜΧ¿ÕÆøÁ÷ͨ |
´æ´¢ÎÂ¶È |
-40 ~ 85¡ãC (-40 ~ 185¡ãF) |
Ïà¶Ôʪ¶È |
10 ~ 95% @ 40¡ãC (ÎÞÀäÄý) |
¿¹ÕñÐÔ |
3 Grms/5~500Hz/×ÔÓɲÙ×÷ |
¿¹³å»÷Óëײ»Ù |
¹¤×÷ÖÐ 20G (11ms), ·Ç¹¤×÷ 40G ´ø HDD
¹¤×÷ÖÐ 40G (11ms), ·Ç¹¤×÷ 60G ´ø CF/SSD
ײ»Ù 80G (11ms) |
ÈÏÖ¤
µçÔ´ÐèÇó
µçÔ´ÊäÈë |
DC 10~28V ÊäÈë (w/ 4-pin DC ÊäÈë¶Ë×Ӻϲ¢Ô¶³ÌµçÔ´ on/off ¿ª¹Ø) |
µçÔ´¹¦ºÄ |
120W |
´æ´¢É豸
ÀàÐÍ |
1 x 2.5" Çý¶¯Æ÷¼ÜÓÃÓÚ HDD/SSD
1 x CFAST ²å²Û¿É´ÓÍⲿ²å°Î |
»ú¹¹
½á¹¹ |
ÂÁºÏ½ð |
¹Ì¶¨ |
Ö§³Ö±Ú¹Ò¹Ì¶¨/Din µ¼¹ì¹Ì¶¨ |
ÖØÁ¿ |
4.5kg |
³ß´ç(W x D x H) |
195 x 268 x 110 mm (7.68" x 10.55" x 4.33") |
¶©»õÐÅÏ¢
FPC-7502 |
׼ϵͳÎÞ´æ´¢É豸, CPU, ÄÚ´æ |
DRK-001 |
Din µ¼¹ìÅä¼þÓÃÓÚ FPC ϵÁÐ |
WMK-7000 |
±Ú¹ÒÅä¼þÓÃÓÚ FPC-7XXX |
PAC-B120W |
120W AC/DC ÊÊÅäÆ÷ |
SSD-25080 |
Intel 2.5" 80GB SATAII SSD Åä¼þ |
CBL-7100-COM |
COM ת½ÓÏß
(1*44-pin ¹«Í·×ª 4*DB-9 ĸͷ + 1 x DB-9 ĸͷ) L=200mm |
ÍÆ¼ö CPU Áбí:
Core i7-620M PGA ´¦ÀíÆ÷ 2.66GHz ´ø 4M cache
Core i5-520M PGA ´¦ÀíÆ÷ 2.4GHz ´ø 3M cache
P4500 1.86GHz ´ø 2M cache
