ϵͳ
CPU °åÔØ Intel Atom N270 1.6GHz CPU 533MHz FSB
ÄÚ´æ 1 x 200-pin DDR2 SO-DIMM ÄÚ²å²ÛÖ§³Ö 400/533MHz SDRAM ×î´ó 2GB
ÄÚÖà 1 x 512KB SRAM ÓÃÓÚ½ô¼±Êý¾Ý±¸·Ý
оƬ×é Intel 945GSE + ICH7M
ÏÔʾ ¼¯³É Intel GMA950 GFx ºËÐÄÓÚ 945GSE GMCH
ATA 2 x Serial ATA ½Ó¿Ú 150MB/s Ó²ÅÌ´«ÊäËÙÂÊ
ÍøÂçоƬ 1 x Realtek RTL8103EL 10/100Base-T ÍøÂç¿ØÖÆÆ÷
1 x Realtek 8110SCL ǧÕ×ÍøÂç¿ØÖÆÆ÷
¿´ÃŹ· 1~255 ¼¶
I/O
´®¿Ú 1 x DB-44 ĸͷ½Ó¿Ú:
Ö§³Ö 2 x RS-232 ½Ó¿Ú; 2 x RS-232/422/485 ¿ÉÑ¡½Ó¿Ú
USB ½Ó¿Ú 4 x USB 2.0 ½Ó¿Ú
ÍøÂç 2 x RJ-45 ½Ó¿ÚÖ§³Ö
- 1 x 10/100Base-T ÍøÂç
- 1 x ǧÕ×Íø
ÊÓÆµ½Ó¿Ú 1 x DB-15 ĸͷ½Ó¿ÚÓÃÓÚÄ£Äâ RGB
Êý×Ö I/O 1 x 16-bit ¿É±à³ÌÊý×ÖÊäÈë/Êä³ö
ÒôƵ Âó¿Ë·çÊäÈë/Ïß³ö
À©Õ¹×ÜÏß 2 x PC/104-Plus ²å²Û
»·¾³
¹¤×÷ÎÂ¶È -20 ~ 70¡ãC (- 4 ~ 158¡ãF), ÖÜΧ¿ÕÆøÁ÷ͨ
´æ´¢ÎÂ¶È -40 ~ 80¡ãC (-40 ~ 176¡ãF)
Ïà¶Ôʪ¶È 10 ~ 95% @ 40¡ãC (ÎÞÀäÄý)
¿¹ÕñÐÔ 3 Grms/5~500Hz / ×ÔÓɲÙ×÷
³å»÷Óëײ»Ù ¹¤×÷ÖÐ 20G (11ms), ·Ç¹¤×÷ÖÐ 60G ʹÓà HDD
¹¤×÷ÖÐ 40G (11ms), ·Ç¹¤×÷ÖÐ 80G ʹÓà CF/SSD
ײ»Ù 100G (11ms)
ÈÏÖ¤
ÈÏÖ¤ CE, FCC
µçÔ´ÐèÇó
µçÔ´ÊäÈë DC 12 ~ 30V ÊäÈë (w/ 1 x 3-pin DC ÊäÈë½Ó¿Ú¶Ë×Ó)
µçÔ´¹¦ºÄ 21W (19V@1.1A)
´æ´¢É豸
ÀàÐÍ 1 x 2.5" Çý¶¯Æ÷¼ÜÓÃÓÚ HDD/SSD
1 x CF Type II ²å²Û¿É´ÓÍⲿ¶ÁÈ¡
»ú¹¹
½á¹¹ ¸ßÇ¿¸ÖÍâ¿Ç + ÂÁÉ¢ÈÈÆ÷
¹Ì¶¨ ±Ú¹Ò¹Ì¶¨/Din µ¼¹ì¹Ì¶¨
ÖØÁ¿ 1.7 kg (3.74 lb) (׼ϵͳ)
³ß´ç(W x D x H) 130 x 195 x 85 mm (5.12" x 7.68" x 3.35")
¶©»õÐÅÏ¢
EPC-6200 ׼ϵͳ´ø 1GB DRAM
WMK-6X00 ±Ú¹Ò¹Ì¶¨¼ÜÓÃÓÚ EPC - 6X00
PAC-P120W 120W AC/DC ÊÊÅäÆ÷
SSD-25080 Intel 2.5" 80GB SATAII SSD kit
CBL-6X00-COM COM ת½ÓÏß (1 x 44-pin ¹«Í·½Ó¿Úת 4 x DB-9 ĸͷ + 1 x DB-9 ĸͷ) L = 200 mm
