产品名称: PROTRONIX-1201(A)功率表台湾
型  号: PROTRONIX-1201(A)
PROTRONIX-1201(A)数字精密功率表
PROTRONIX - Digital Power Meter 1201 (A)
Made in TaiWan(原裝進口)
电流、电压、功率全真有效值
经济超值
NEW - True Voltage Reading is available now! "PROTRONIX" 1201A True Power, Current, Voltage Digital Meter
Features:
· Dual Digital Display Voltage, Ampere, Watt
· **True RMS Current, Voltage, Power Reading
· Range Auto/Manual selectable
· Power Factor Zero to Unity
· Watt Accuracy ±0.3% + 3d
The 1201A standard, The finest quality in AC power line measurement
SPECIFICATION
TRUE POWER
Range
19.99W, 199.9W, 1999W
Accuracy
±(0.3% + 3d)
Freq. Response
40Hz~80Hz
Max. Voltage
299.9V
Max. Current
200mA for 19.99W
2A for 199.9W
20A for 1999W
Power Factor (COSφ)
Zero to Unity Leading or Lagging
Shunt Resistance
0.01 Ω (Current Sense )
AC VOLTAGE
Auto Range
0~299.9V
Accuracy
±(0.25% +2d)
Freq. Response
40Hz~1kHz
Protection
300V
Impedance
Above 200K Ω
AC CURRENT
Range
.1999A, 1.999A, 19.99A
Accuracy
±(0.3% +2d)
Freq. Response
40Hz~200Hz for 1999A
40Hz~1KHz for 1.999~19.99A
Peak over Indication
2.5 times of Range
Shunt Resistance
0.01 Ω
Crest Factor Response
50:1 for Minimum RMS Input,
Linearly decreasing to 3:1 for Full Scale
RMS Input
GENERAL
Displays
DUAL 4 Digits 7-Segment L.E.D.
WATTS/AMPERE Reading
3 Auto Range up at 2000 Counts
                       down at 0.180 Counts
Min. Input
10% of Range for All True RMS Converters
Dimension
260(W)x100(H)X340(D) mm
Weight
4Kgs
Power
115V/230V ±10%, 50/60Hz, 10w
更多PROTRONIX-1201(A)数字精密功率表订购资讯请及时致电本公司业务部
关 键 词: 功率表
公司名称: 深圳市阳宏电源技术有限公司
联 系 人: 汪先生
电  话: 0755-27600601
手  机: 13760302878
地  址: 深圳市龙华新区观澜街道松元成裘工业区8栋
邮  编: 518110
30KV|30KW变频电(SPS3630)
30KVA/30000W(30KVA/30000W/30K变频电源-SPS-3630-变频电源, 单相变频电源, 交流变频电源)
10KVA/10000W(10KVA/10000W/10K变频电源-SPS-6100-变频电源, 单相变频电源, 交流变频电源)
5KVA/5000W/s(5KVA/5000W/5K变频电源-SPS-620-变频电源, 单相变频电源, 交流变频电源)
3000W/3KVA变频(KVA/3000W/3K变频电源-SPS-620-变频电源, 单相变频电源, 交流变频电源)
可编程交直流绝缘耐压测试(YH7122)
500VA|0.5KVA(SPS6005)
1KVA|1OOOW变频(SPS610)
可编程交流绝缘耐压测试仪(YH7112)
可编程YH7120交直流(YH7120)
H-3|6357|600(H-3|6357)
1KW|1KVA晶体管变(YF6010B)
YH7122可编程交直流(YH7122)
500VA|0.5KVA(YF6005B)
单相变频电源(2KVA|2000W|2K)
變頻儀(SPS3610|3620|3630)
LED交直流絕緣耐壓測試(YH7122)
三相10KVA|20K(SPS3100|3200|3300)
2000VA|2KW变频(SPS620)
