²úÆ·Ãû³Æ£º
Flowserve EP5ϵÁÐµçÆø¶¨Î»Æ÷
ÐÍ ºÅ£º
EP5ϵÁÐµçÆø¶¨Î»Æ÷
EP5 µç¶¯Æø¶¯¶¨Î»Æ÷ÓÉ PMV P5 Æø¶¯¶¨Î»Æ÷¸ÄÔì¶ø³É¡£ Õâ¸ö½ô´Õ¶ø¼á¹ÌµÄµ¥ÔªÖ¼ÔÚ×î´ó³Ì¶ÈµØÌá¸ßÆäÔÚ¸÷Àà»·¾³ÖеÄÐÔÄÜ¡£ EP5 Óбê×¼¡¢ÕæÕý°²È«ºÍ·À±¬Èý¸ö°æ±¾¡£
Flowserve EP5ϵÁÐµçÆø¶¨Î»Æ÷¼¼Êõ²ÎÊý£º
ÊäÈëÐźÅInput signal |
4¨C20 mA |
ÏßÐÔ¶ÈLinearity |
< 1% |
³ÙÖÍHysteresis |
< 0.75% |
ÖØ¸´¾«¶ÈRepeatability |
< 0.5% |
ËÀÇøDeadband |
< 0.15% |
ÆøÌ幩¸øAir supply |
Max. 1 MPa/150 Psi, Oil, water and dustfree Min. 0.14
MPa/21 Psi |
Á¬½ÓÂÝÎÆConnector threads |
1/4" NPT or G (BSP) |
ѹÁ¦±íÂÝÎÆGauge threads |
1/8" NPT or G (BSP) |
µçÆø½Ó¿ÚCounduit entry |
1/2" NPT or M20 |
½ÓÏß¶ËTerminals |
2.5 mm2 (AWG 14) Screw terminals |
Flowserve EP5ϵÁÐµçÆø¶¨Î»Æ÷Ñ¡ÐÍ±í£º
ÐͺÅModel |
EP5XX |
EP5 Double acting pneumatic |
EP5FS |
Fail freeze function |
EP5IS |
Intrinsically safe, ATEX, FM, CSA |
EP5EU |
Explosion proof ATEX |
EP5US |
Explosion proof CSA, FM |
»¬·§Spool valve |
HP |
High performance |
LB |
Normal Gain |
½Ó¿ÚConnections |
N |
1/4"NPT , El. 1/2" NPT |
G |
1/4"G air, M20 x 1,5 electric |
M |
1/4"NPT1/4 air, M20 x 1,5 electric |
±íÃæ´¦ÀíSurface treatment |
U |
Epoxy coating |
M |
Tufram |
תÖáSpindle |
01, 23 etc |
01 to 39. See dwg SPNDLS_P5 |
͹ÂÖCam |
K01, K08 etc |
K01 to K34 |
É϶˸ÇFront cover |
PV9DA |
90¡ã, Direct, arrow indicator |
4 |
4¨C20 input |
ζÈTemperature |
N |
Nitrile seals ¨C20¡ãC to +85¡ãC |
Q |
Silicon seals, ¨C40¡ãC to +85¡ãC |
¾ÙÀýExample£ºEP5XX-HPNU-23K01-PV9DA-4Z |
