Flowserve logix3200系列数字定位器
Logix 3200IQ 利用先进的压电技术和内回路反馈提供优越的性能、控制和可靠性,同时采用紧凑、轻型和模设计最大程度地降低耗气量。Logix 3200IQ 用于采用控制阀的行业,例如油气生产和提炼、化学加工以及纸浆和造纸行业。它将继续在全球范围内的新兴市场和地区获得认可
Flowserve logix3200系列数字定位器技术参数:
电源供给Power supply |
Two-wire, 4-20 mA input |
通讯Communications |
HART Protocol |
线性度Linearity |
≤0.5% full scale |
迟滞Hysteresis |
≤0.5% full scale |
重复精度Repeatability |
≤0.1% full scale |
死区Deadband |
≤0.1% full scale |
工作温度 Operating temperature range |
Standard: -4°F to 176°F (-20°C to 80°C) Low: -40°F to 176°F (-40°C to 80°C) |
外壳Housing |
Cast, powder-painted aluminum or stainless steel |
重量Weight |
Aluminum: 8.5 lb. (3.9 kg) Stainless steel: 20.5 lb. (9.3 kg) |
Flowserve logix3200系列数字定位器选型表:
Selection |
Code |
Example |
3 |
3 |
协议Protocol |
HART |
2 |
2 |
特征Diagnostics |
Standard |
0 |
1 |
Advanced |
1 |
材质Material |
Aluminum, White Paint (Valtek) |
0 |
0 |
Stainless Steel, No Paint (Valtek) |
1 |
Aluminum, Black Paint (Automax) |
2 |
Aluminum, Food-Grade White Paint (Automax) |
3 |
Aluminum, Black Paint (Accord) |
4 |
Aluminum, Food-Grade White Paint (Accord) |
5 |
设计版本
Design Version |
IQ |
IQ |
认证Certifications |
Explosionproof EEx d IIB + H2, ATEX II 2 G (CENELEC) |
07 |
10 |
Explosionproof Class I, Div 1, Groups B, C, D Intrinsically Safe Class I, Div 1, Groups A through G (FM, CSA) FM Nonincendive. CSA Class I, Div 2, Class I, Zone 1, Group IIB + H2 and Exia Class 1, Zone 0, Group IIC (CSA Only) |
10 |
General Purpose |
14 |
Intrinsically Safe EEx ia IIC T4, Standard Temp: -40°F (-40°C) ≤ Ta ≤ 176°F (80°C)/131°F (55°C), ATEX II 1 G (CENELEC) |
15 |
IECEx Ex d IIB + H2 |
16 |
轴Shaft |
DD 316 Stainless Steel Shaft (Valtek Standard) |
D6 |
D6 |
NAMUR 316 Stainless Steel (VDI/VDE 3845) |
N6 |
电气接口Conduit Connections |
1/2" NPT |
E |
E |
M20 |
M |
方式Action |
Four-way (Double-Acting) |
04 |
04 |
Three-way (Single-Acting) |
03 |
Four-way Vented (Double-Acting) |
4V |
Three-way Vented (Single-Acting) |
3V |
温度Temperature |
Operating Temperature (-40°F to 176°F; -40°C to 80°C) |
40 |
40 |
压力表Gauges |
Gauges (Valtek standard) |
OG |
OG |
Stainless Steel Gauges |
OS |
Stainless Steel with Brass Internals (kg/cm2) |
KG |
Stainless Steel with Stainless Steel Internals (kg/cm2) |
KS |
No Gauges |
OU |
特殊选项
Special Options |
4-20 mA Position Feedback |
OF |
OF |
No Specials |
OO |
