²úÆ·Ãû³Æ£º
ARBOR Rigid-732 ¿íÎÂÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷
ÐÍ ºÅ£º
Rigid-732
ϵͳ
CPU |
Intel® Core8482; 2 Duo P8400 2.26GHz 1066MHz FSB, 3M cache |
ÄÚ´æ |
2 x 200-pin ˫ͨµÀ DDR2 SO-DIMM ²å²Û×î´ó 4GB 667/800MHz (ĬÈϰ²×° 2GB WT DDR2-800 SDRAM) |
оƬ×é |
Intel® GM45 + ICH9M |
ÏÔʾ |
Intel® GM45 ¼¯³É GMA X4500, Ö§³Ö DirectX 10, Shader Model 4.0 |
ATA |
2 x SATA ½Ó¿Ú 300MB/s HDD ´«ÊäËÙ¶È |
ÍøÂçоƬ |
2 x Realtek RTL8111C ǧÕ×Íø¿ØÖÆÆ÷ |
¿´ÃŹ· |
1~255 ¼¶ |
I/O
´®¿Ú |
1 x DB-44 ĸͷ½Ó¿Ú |
3 x RS-232 ½Ó¿Ú
1 x RS-232/422/485 ¿ÉÑ¡½Ó¿Ú |
USB ½Ó¿Ú |
8 x USB 2.0 ½Ó¿Ú |
ÍøÂç |
2 x RJ-45 ½Ó¿ÚÓÃÓÚǧÕ×ÍøÂç |
ÊÓÆµ½Ó¿Ú |
1 x DB-15 ĸͷ½Ó¿ÚÓÃÓÚÄ£Äâ RGB |
1 x Displayport |
TV-out |
1 x 6-pin Mini-DIN ½Ó¿ÚÖ§³Ö S-Video Ö±½ÓÊä³ö»òͨ¹ýÍⲿÏ߲ĵĸ´ºÏÊÓÆµ½Ó¿Ú |
¿ÉÑ¡½Ó¿Ú |
DVI »òÊý×Ö I/O »ò LPT |
1 x DVI-D ĸͷ½Ó¿ÚÓÃÓÚÊý×ÖÊÓÆµÊä³ö
1 x 16-bit Êý×Ö I/O, 8 in/8 out
SPP/EPP/ECP ģʽ LPT |
Âó¿Ë·çÊäÈë/Ïß³ö (6W ǰÖ÷Ŵó) |
KB/MS |
1 x 6-pin Mini-DIN ÓÃÓÚ¼üÅ̺ÍÊó±ê |
À©Õ¹×ÜÏß |
2 x PCI ²å²Ûͨ¹ý riser card |
1 x Mini-card ²å²Û |
»·¾³
¹¤×÷ÎÂ¶È |
-40 ~ 70¡ãC (-40 ~ 158¡ãF), ÖÜΧ¿ÕÆøÁ÷ͨ |
´¢´æÎÂ¶È |
-40 ~ 85¡ãC (-40 ~ 185¡ãF) |
Ïà¶Ôʪ¶È |
10 ~ 95% @ 40¡ãC (ÎÞÀäÄý) |
¿¹Õñ¶¯ |
3 Grms /5~500Hz /Ëæ»ú²Ù×÷ |
¿¹³å»÷ |
¹¤×÷ÖÐ 20G (11ms), ·Ç¹¤×÷ 40G Óà HDD |
¹¤×÷ÖÐ 40G (11ms), ·Ç¹¤×÷ 60G Óà CF/SSD |
ײ»Ù 80G (11ms) |
ÈÏÖ¤
µçÔ´ÐèÇó
µçÔ´ÊäÈë |
DC 10V~28V ÊäÈë (´ø 4-pin DC ÊäÈë¶Ë×Ӻϲ¢Ô¶³ÌµçÔ´ on/off ¿ª¹Ø) |
µçÔ´¹¦ºÄ |
60W (Max.) |
µçÔ´ÊÊÅäÆ÷ |
120W AC/DC ÊÊÅäÆ÷ |
´æ´¢
ÀàÐÍ |
1 x 2.5" Çý¶¯Æ÷Ö§¼ÜÓÃÓÚ HDD/SSD |
1 x CF Type II ²å²Û¿É´ÓÍⲿ¶ÁÈ¡ |
»ú¹¹
½á¹¹ |
ÂÁºÏ½ð |
¹Ì¶¨ |
±Ú¹Ò¹Ì¶¨ (ĬÈϼ¯³É) / Din ¹ìµÀ¹Ì¶¨ |
ÖØÁ¿ |
4.2 kg (9.24 lb), ÎÞ´æ´¢É豸 |
³ß´ç (W x D x H) |
195 x 268 x 100 mm (7.68" x 10.55" x 3.93") |
¶©»õÐÅÏ¢
Rigid-732 |
ÎÞ·çÉÈǶÈëʽ¿ØÖÆÆ÷ |
DRK-001 |
FPC ϵÁÐ Din µ¼¹ìÅä¼þ |
SSD-25080 |
Intel® 2.5¡± 80GB SATAII SSD Åä¼þ |
