免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → machine vision software of china
产品名称: machine vision software of china
型 号: ckvisionV2.0
价 格:
品 牌: 3185
    CkVision machine vision software development package is the development of Techtronic a companys own high-performance machine vision software development kit, is characterized by high accuracy, recognition speed, full-featured, light and other disturbances on the environment is not sensitive to detect extremely high reliability.
CkVision design philosophy is to provide a simple and easy application development function, package, interface, function-rich (up to more than 400 functions), providing DLL and OCX. Support the VB, VC and other development tools. In the OCX menu, each function has a coordinate link between the interface and improve the integration between functional performance. While providing a large number of examples of code to help developers speed the development of image recognition. In the software simply calls the corresponding function on the function you want can be done. Also according to customers request for the corresponding example.
    CkVision integrated BLOB analysis, object counting, geometric matching, gray level matching, color matching, character recognition, barcode recognition, measurement round, looking round, caliper measurement, diameter diameter measurement, color recognition, image basic operations (binary, the ratio transformation, opening operation and closing operation, expansion, corrosion, filtering, edge detection), geometric computing, image merge, image rotation, contour and other functions. Also can be customized according to customer special features.
    CkVision the software is open architecture-based, well compatible with a variety of popular image capture card, Digital camera, analog camera, linear camera, developing package to provide a direct image data obtained from the hardware features, to use more Simple.
    CkVision positioning tool is based on geometric features, the outline of the most advanced detection technology to identify objects and patterns. The clutter in the image, the brightness fluctuations, image blurring and object duplication has a significant role. Powerful fuzzy algorithm can use to distinguish between multiple models and correctly identify the object, even if the object is very similar to the positioning tool able to return to target location, direction, scale and user-defined reference point and including the matching quality indicators and matching object symmetry information.
    CkVision present in the electronic, semiconductor, laser, PCB, packaging, measurement, monitoring, games and other industries have wide applications.
www.ckvision.net
公司名称: 深圳市创科自动化控制技术有限公司
电 话: 0755 33938285 / 黎友
手机: 13480974764
地 址: 深圳市宝安区福永镇街道莱福大厦4楼
邮 编: 518103
主 页: http://www.ckvision.net
  • 机器视觉包装机自动检测控制系统
  • 利用机器视觉优化太阳能生产
  • 国内最专业的机器视觉软件开发商
  • 机器视觉软件彩色匹配分析应用
  • 最好用的机器视觉软件ckvisionV5.0正式发布
  • LCD机器视觉检测系统组
  • 机器视觉自动识别浇铸终点系统
  • 机器视觉
  • 机器视觉检测|CCD检测|视觉检测
  • UVW平台|对位平台|CCD对位平台
