MVS-8504 |
File Download Link |
PC Requirements
166Mhz Pentium class CPU or Greater
£¨MMX required for PatMax software£© |
An AGP-based video display adaptor with at least 8MB of RAM |
Direct Draw, and operating in a minimum 256 color mode. AGP is preferred. |
One open +5V/32-bit PCI expansion slot |
Optional: Microsoft VB.NET, Visual C++.NET(UNMANAGED),or C# |
Memory |
16MB frame buffer |
Video Input |
Four independent standard and high-speed analog channels£¬with mixed camera formats |
Supports high resolution£¬rapid reset£¬progressive scan£¬and interlaced cameras |
Supports grayscale |
Parallel I/O |
16 bi-directional TTL I/O |
Four line can be configured as trigger input |
Four line can be configured as trigger output |
Opto-isolation available via a breakout box |
