IEEE1394 DCAM(FireWire) |
File Download Link |
PC Requirements
166Mhz Pentium class CPU or Greater
£¨MMX required for PatMax software£© |
PCI-or AGP-based video display adaptor with at least 8MB of RAM£¬support for Direct Draw£¬and operating in a minimum 256 color mode£¬AGP is preferred. |
One open +5V/3.3V PCI expansion slot |
Optional: Microsoft VB.NET, Visual C++.NET(UNMANAGED),or C# |
Memory |
N/A |
Video Input |
Supports IEEE 1394a and IEEE 1394b (FireWire) camera using DCAM 1.3or later |
Up to three (3) cameras can be connected directly to the interface card. FireWire hubs are supported to enable additional cameras |
Supports resolutions from 640X480 up to 2KX2K |
Supports both color and monochrome cameras |
Parallel I/O |
Optional I/O kit provides: |
24 lines of digital TTL I/O |
Two banks of 8£¬two banks of 4£¬each bank programmable as input or output |
Eight lines of opto-isolation available via breakout panel |
