¼ò½é
MPC-122-Kº£ÊÂרÓÃÆ½°åµçÄÔÅ䱸Á˸ßÐÔÄܵÄIntel Core 2 Duo processor£¬Ö§³Ö¸ß´ï4 GBµÄϵͳÄڴ棬Ϊº£ÑóÓ¦ÓÃÌṩ Á˿ɿ¿Îȶ¨µÄ²Ù×÷ƽ̨¡£²»½öÈç´Ë£¬Á½¸öRS-232/422/485Ö§ ³Ö¹âµç¸ôÀëµÄ´®¿ÚÌṩ¿É¿¿µÄ´®¿ÚͨѶ£¬Á½¸öǧÕ×ÒÔÌ«Íø¶Ë¿Ú ¿ÉÖ§³Ö¸ßËÙÒÔÌ«Íø´«ÊäºÍÍøÂçÈßÓà¡£ ¸Ãƽ°åµçÄÔ¾ßÓи÷ÖÖ¹¤ÒµÌØÐÔ£¬Èç¹âѧճºÏ£¨¿ÉÑ¡£©¡¢¿íÊӽǡ¢ È«·½Î»µ÷¹âµÈ¡£´ËÍ⣬¸Ãƽ°åµçÄÔÊÇÄ£×黯Éè¼Æ£¬½µµÍϵͳ¼¯ ³ÉµÄ³É±¾£¬¼õÉÙ²úÆ·ÍÆÏòÊг¡µÄʱ¼ä¡£È«·½Î»Ö§³Ö¸÷ÖÖÃæ°å ·Ö±æÂÊ£¬ÒÔÂú×㲻ͬº£ÑóÓ¦ÓõÄÌØ¶¨ÒªÇó¡£ MPC-122-Kº£ÑóרÓÃÆ½°åµçÄÔ¼æÈݸ÷ÖÖ¹¤Òµº£Ê±ê×¼£¬Èç IEC 60945£¬DNVºÍIACS-E10µÈ£¬ÒÔÈ·±£ÔÚº£ÊÂÓ¦ÓÃÖеÄÊÊ Ó¦ÐÔ¡£IP66µÈ¼¶µÄÍâ¿Ç¿ÉÒÔÌṩӦ¶Ô¶ñÁÓº£Ñó»·¾³µÄ¶îÍâ±£ »¤¡£
ÌØµã
- 22¿ÉÊÓͼÏñ³ß´ç£¬³¤¿í±È16:10£¬1680 x 1050ÏñËØ·Ö±æÂÊ
- Ö§³ÖIntel Core 2 Duo2.26 GHz´¦ÀíÆ÷£¬ÐÔÄܸü¸ß
- È«·¶Î§µ÷¹â£¬¹âѧճºÏ£¨¿ÉÑ¡£©ºÍ¹ã½Ç£¨178/178£©
- Ë«¶ÀÁ¢ÏÔʾ£¨VGA + DVI-D£©
- IP66·À»¤µÈ¼¶Íâ¿Ç£¬¿É·ÀË®·À³¾£¨°µ×°£©
- 2¸öǧÕ×ÒÔÌ«Íø¿Ú
- 2¸öRS-232/422/485´®¿Ú£¬´ø¹âµç¸ôÀë
- 7¸öUSB 2.0¸ßËÙ¶Ë¿Ú
- Ö§³ÖCompactFlash²å²Û£¬ÓÃÓÚ´æ´¢À©Õ¹
- 2¸öSATAÁ¬½ÓÆ÷£¬ÓÃÓÚ´æ´¢À©Õ¹
- Ö§³ÖWindows 7ºÍWindows XP SP3
- ¼á¹Ì£¬ÎÞ·çÉÈÉè¼Æ
¹æ¸ñ£º
¼ÆËã»ú CPU£ºIntel Core 2 Duo SP9300 2.26 GHz, 6 MB for L2 cache OS£ºWindows 7, Windows XP SP3 (¸ù¾ÝÐèҪԤװOS) ϵͳоƬ£ºIntel GS45 + ICH9M BIOS£º8 Mbit Flash BIOS SPI type, Ö§³ÖACPI FSB£º1066 MHz ϵͳÄڴ棺°åÔØ2 GB DDR3 SDRAM (Ö§³ÖDDR3£¬×î¸ß¿É ´ï4 GB) ͼÐοØÖÆÆ÷£ºÄÚ½¨Intel GS45 ÊÓÆµÊä³ö£ºDVI-D x 1, VGA x 1 (female) À©Õ¹×ÜÏߣº°åÔØMini-PCIe USB£ºUSB 2.0 hosts x 7, type A connectors, Ö§³ÖϵͳÆô ¶¯ (¼ÆËã»úÉÏ6¸ö¿Ú£¬Ãæ°åÉÏ1¸ö¿Ú) ´æ´¢ ´æ´¢À©Õ¹£ºCompactFlash²å²Û SATA´æ´¢£º(¸ù¾ÝÐèÇó¿ÉԤװSDD/HDD) • 2.5-inch SSD • 2.5-inch HDD ÆäËûÖܱßÉ豸 KB/MS£º1¸öPS/2½Ó¿Ú£¬Ö§³Ö±ê×¼PS/2¼üÅ̺ÍÊó±ê (YÐÍÏß ÀÂ) ÒôƵ£ºÊäÈë/Êä³ö½Ó¿Ú£¬3.5 mmÃÔÄã²å¿× ÏÔʾ Ãæ°å³ß´ç£º22¡±¿í¿ÉÊÓͼÏñ³ß´ç Ãæ°åÀàÐÍ£ºMVA ³¤¿í±È£º16:10 ÏñËØ£º1680 x 1050 (WSXGA+) µã¾à£¨RGB£©£º0.282 (H) x 0.282 (V) mm ÏìӦʱ¼ä£º8 ms (gray to gray) ¶Ô±È¶È£º1000:1 ¹âÇ¿£º300 cd/mxm ¿ÉÊӽǶȣº178/178 ÓÐЧÏÔÊ¾Çø£º473.76 (H) x 296.1 (V) mm ¹æ¸ñ ×î´óÉ«²Ê£º16.7M (8 bits/color) ·Ö±æÂÊ£º • VGA£º640 x 480 • SVGA£º800 x 600 • XGA£º1024 x 768 • SXGA£º1280 x 1024 • WSXGA+£º1680 x 1050 (optimal setting) ÒÔÌ«Íø LAN£º2¸ö£¬×ÔÊÊÓ¦10/100/1000 Mbps ports (RJ45) µç´Å¸ôÀë±£»¤£º1.5 KV built-in ´®¿Ú ´®¿Ú±ê×¼£º2¸öRS-232/422/485¿Ú£¬Èí¼þ¿ÉÑ¡ (DB9 male) ¹âµç¸ôÀë±£»¤£º4 KV ´®¿ÚͨѶ²ÎÊý Êý¾Ýλ£º5, 6, 7, 8 ֹͣλ£º1, 1.5, 2 УÑéλ£ºNone, Even, Odd, Space, Mark Á÷¿Ø£ºRTS/CTS, XON/XOFF, ADDC® (automatic data direction control) for RS-485 Baudrate£º50 bps to 921.6 Kbps (supports nonstandard baudrates; see user¡¯s manual for details) ´®¿ÚÐźŠRS-232£ºTxD, RxD, DTR, DSR, RTS, CTS, DCD, GND RS-422£ºTxD+, TxD-, RxD+, RxD-, GND RS-485-4w£ºTxD+, TxD-, RxD+, RxD-, GND RS-485-2w£ºData+, Data-, GND LED ϵͳ£º´æ´¢£¬µçÔ´ Íø¿Ú£º100M/Link x 2, 1000M/Link x 2 (on connector) Ç°Ãæ°å LEDµÆ£º´æ´¢£¬µçÔ´ OSD£º1 x OSD control USB£º1 USB 2.0 host µçλ¼Æ£ºÁÁ¶È¿ØÖÆ »úÐµÌØÐÔ Íâ¿Ç£ºÂÁÖÆÍâ¿Ç ÖØÁ¿£º5 kg ³ß´ç£º24 x 560 x 420 mm (4.88 x 22.05 x 16.54 in) °²×°·½Ê½£ºÂñÈë°²×° ¹¤×÷»·¾³ ¹¤×÷ζȣº-15 ~ 55 ¡æ (5 ~ 131¡ãF) ´æ´¢Î¶ȣº-20 ~ 60 ¡æ (-4 ~ 140¡ãF) Ïà¶Ôʪ¶È£º5 ~ 95% (non-condensing) ·ÀÕ𣺠• IEC 60945 • DNV 2.4, Class A/Class C µçÔ´ÐèÇó ÊäÈëµçѹ£º18 ~ 36 VDC (screw-type terminal block) µçÔ´¹¦ºÄ£º112 W • 6.21 A @ 18 VDC • 4.55 A @ 24 VDC • 2.95 A @ 36 VDC °²¹æÈÏÖ¤ Safety£ºUL/cUL EMC£ºEN 55022 Class B, EN 55024-4-2, EN 55024-4-3, EN 55024-4-4, FCC Part 15 Subpart B Class A Marine£ºIEC 60945 4th. (Pending), DNV (Pending), IACS-E10 (Pending) Green Product£ºRoHS, cRoHS, WEEE ¿É¿¿ÐÔ ×Ô¶¯ÖØÐ´¥·¢Æ÷£ºBuilt-in WDT (watchdog timer) supporting 1-255 levels for time interval system reset, software programmable MTBF £º39,675 h ±£ÐÞ ±£ÐÞÆÚ£º1Äê
¶©¹ºÐÅÏ¢£º
| ¿ÉÑ¡ÐͺŠ|
²úÆ·±àºÅ |
ÃèÊö |
MPC-122Y-K (glass with tape bonding) |
x86¼Ü¹¹º£ÊÂרÓÃÆ½°åµçÄÔ,22¡°¿í¿ÉÊÓÆÁÄ», È«µ÷¹â, Intel Core 2 Duo 2.26 GHz, DVI-D, VGA, audio, 2¸öǧÕ×Íø¿Ú, 2¸ö¹âµç¸ôÀë±£»¤´®¿Ú, 7¸öUSB 2.0¿Ú, CF¿¨ |
MPC-122X-K (glass with tape bonding) |
x86¼Ü¹¹º£ÊÂרÓÃÆ½°åµçÄÔ, 22¡¯¡¯¿í¿ÉÊÓÆÁÄ», È«µ÷¹â, Intel Core 2 Duo 2.26 GHz, DVI-D, VGA, audio, 2¸öǧÕ×Íø¿Ú, 2¸ö¹âµç¸ôÀë±£»¤´®¿Ú, 7¸öUSB 2.0¿Ú, CF¿¨ |
PDFÎĵµÏÂÔØ
²úƷʾÒâͼ
Èí¼þÇý¶¯
