̨ÍåÑôÃ÷fotek½Ó½ü¿ª¹ØPS-10N£¬Ì¨ÍåÑôÃ÷fotek½Ó½ü¿ª¹ØPS-10N̨ÍåÑôÃ÷fotek PS-10N,PS-15N³¤¾àÀë½Ó½ü¿ª¹Ø
̨ÍåÑôÃ÷FOTEK·½Ðͽӽü¿ª¹Ø²úÆ·Ñ¡ÐÍ
Êä³ö·½Ê½ |
¸ÐÓ¦¾àÀë |
°²Ñb°²Ê½ |
¸ÐÓ¦·½Ïò |
¹¤×÷늉º |
·´‘ªîlÂÊ |
PL-05N |
NPN |
5.0mm |
Flushed |
Horizontal |
10~30VDC |
800HZ |
PL-05P |
PNP |
PL-08N |
NPN |
8.0mm |
Non-Flushed |
PL-08P |
PNP |
PS-05N |
NPN |
5.0mm |
Flushed |
Horizontal |
10~30 |
800HZ |
PS-05P |
PNP |
VDC |
PS-08N |
NPN |
8.0mm |
Non-Flushed |
PS-08P |
PNP |
PS-04N-V |
NPN |
4.0mm |
Non-Flushed |
Vertical |
10~30 |
PS-04P-V |
PNP |
VDC |
PS-04N |
NPN |
4.0mm |
Horizontal |
2KHZ |
PS-04P |
PNP |
LS-04N-V |
NPN |
4.0mm |
Non-Flushed |
Vertical |
10~30 |
2KHZ |
LS-04P-V |
PNP |
VDC |
LS-04N |
NPN |
Horizontal |
LS-04P |
PNP |
BS-02N |
NPN |
2.0mm |
Flushed |
Vertical |
10~30 |
2KHZ |
BS-02P |
PNP |
VDC |
BS-04N |
NPN |
4.0mm |
Non-Flushed |
BS-04P |
PNP |
SP-05N |
NPN |
5.0mm |
Non-Flushed |
Vertical |
10~30VDC |
800HZ |
SP-05P |
PNP |
PP-05N |
NPN |
5.0mm |
Flushed |
Vertical |
10~30VDC |
800HZ |
PP-05P |
PNP |
PP-08N |
NPN |
8.0mm |
Non-Flushed |
PP-08P |
PNP |
PS-05S |
SCR |
5.0mm |
Flushed |
Horizontal |
<, TD rowSpan=2 width=72 _fckxhtmljob="4" tyle="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: #ece9d8; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0cm; WIDTH: 54pt; PADDING-RIGHT: 0cm; HEIGHT: 14.25pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-bottom-alt: solid black .5pt; mso-border-right-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" s,>
90~250VAC
20HZ |
PS-08S |
SCR |
8.0mm |
Non-Flushed |
PS-10N |
NPN |
10.0mm |
Flushed |
Horizontal |
10~30VDC |
500HZ |
PS-10P |
PNP |
PS-15N |
NPN |
15.0mm |
Non-Flushed |
PS-15P |
PNP |
PS-10S |
SCR |
10.0mm |
Flushed |
Horizontal |
90~250VAC |
20HZ |
, xhtmljob="4" h="111" widt,>
NPN
