Output mothod Ý”³öģʽ |
NPN N.O. |
SN10-N |
SN10-NK |
¨C |
NPN N.C. |
SN10-N2 |
SN10-N2K |
¨C |
PNP N.O. |
SN10-P |
SN10-PK |
¨C |
PNP N.C. |
SN10-P2 |
SN10-P2K |
¨C |
NPN N.O./N.C. PNP N.O./N.C. |
SN10-KP2 |
¨C |
¨C |
SCR N.O. |
¨C |
¨C |
SN10-A |
SCR N.C. |
¨C |
¨C |
SN10-A2 |
Sensing surface / ™zœy·½Ïò |
Top surface / ǰ·½ |
Top surface / ǰ·½ |
Standard sensing object / ˜ËœÊ™zœyÎï |
Iron 30 x 30 x 1mm |
Sensing distance / ™z³ö¾àëx |
10 mm |
10 mm |
Secure sensing distance / ½¨×h¾àëx |
0 to 8 mm |
0 to 8 mm |
Hysteresis / ßtœþ |
¨Q 10 % of sensing distance |
Response time / ·´‘ª•rég |
3.3 ms Max. |
50 ms Max. |
Operating voltage / ¹¤×÷늉º |
DC10 ~ 30 V |
AC90 ~ 260 V |
Current consumption / ÏûºÄëŠÁ÷ |
8 mA Max. |
2 mA Max. |
Load current / Ø“ÝdëŠÁ÷ |
100 mA Max. at DC30V |
5~300 mA Max. |
Leakage current / ©ëŠÁ÷ |
¨Q 1.1mA no-load |
¨Q 2.0mA no-load |
Residual voltage / šˆðN늉º |
¨QDC 1.5V |
¨Q AC 4V |
Insulation resistance / ¸ôëx×迹 |
20M ¦¸ min. (DC500V) |
Voltage withstandability / ½^¾‰Ä͉º |
AC1000V 60Hz for 60 Sec. |
Operating temperature / ¹¤×÷œØ¶È¹ ‡ú |
-20¡æ ~ + 60¡æ |
-20¡æ ~ + 60¡æ |
Protection degree / ·ÀË®µÈ¼‰ |
IP 66 |
IP 66 |
Wiring method / ³ö¾€·½Ê½ |
Pre-wired Ø5.2 x 2M/3-wires (KP2:Ø5.2 x 2M/4 wires) |
M12 pigtailed type /M12 ½Óî^15cm늾€Ê½ |
Pre-wire Ø5.2 x 2M/2-wires |
Weight / ÖØÁ¿ |
Approx. 125g |
Approx. 70g |
Approx. 125g |
