免费注册 登录 | 广告服务 | 客服中心
中华工控网工控产品 → WTB4-3P3161,WT4-2P301,WT4-2P132
产品名称: WTB4-3P3161,WT4-2P301,WT4-2P132
型 号: WTB4-3P3161,WT4-2P301
价 格:
品 牌:
sick施克光电开关WTB4-3P3161,WT4-2P301,WTB4-3N136,WT4-2P132
WTB4S-3N1361光电开关,WTB4S-3N1361S16光电开关,WT4-2N132光电开关
精巧型光電感測器/感應器W2
W2 (精巧型/扁平型)
尺寸:7.6x22x13.5mm
長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67 / IP69K
工作環境溫度:-20℃...+50℃
類型:直接反射型 WT2
反射片型 WL2
對照型 WS/WE2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image1701''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image99''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
精巧型光電感測器/感應器W4-3
W4-3
尺寸:16x32x12mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP66 / IP67
工作環境溫度:-40℃...+60℃
類型:直接反射型WT4-3/WTB4-3
反射片型 WL4-3
對照型 WS/WE4-3
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image171''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image98''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
精巧型光電感測器/感應器W4-3
W4-3 鐵氟龍
尺寸:22x42x22mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP68/IP69K
工作環境溫度:-40℃...+60℃
類型:直接反射型WT4-3鐵弗龍
對照型 WS/WE4-3鐵弗龍
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image177''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">光電感測器-W4-3 鐵氟龍
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image178''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">Photoelectric sensor_W4-3
精巧型光電感測器/感應器W4S-3
W4S-3
尺寸:41.8x12.2x17.3mm
長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP66 / IP67
工作環境溫度:-40℃...+60℃
類型:直接反射型WTB4S-3
反射片型WL4S-3/WLG4S-3
對照型 WSE4S-3
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image1721''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">光電感測器 W4S-3
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image179''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">Photoelectric Sensor W4S-3
精巧型光電感測器/感應器W100
W 8
尺寸:11x31x20mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP65
工作環境溫度:-25℃...+55℃
類型:直接反射型WTB8
直接反射型 WTB8L(雷射光)
反射片型 WL8
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image180''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">W8光電感測器
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image1291''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
精巧型光電感測器/感應器W100
W 100
尺寸:11x31x20mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP65
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT100
反射片型 WL100
對照型 WS/WE100
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image1731''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image129''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
精巧型光電感測器/感應器W140-2
W140-2
尺寸:11x31x20mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT140-2
反射片型 WL140-2
對照型 WS/WE140-2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image130''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
精巧型光電感測器/感應器W150
W150
尺寸:10x28x17.5mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT150
反射片型 WL150
對照型 WS/WE150
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image132''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
  小型
小型光電感測器W160
W 160
尺寸:11x23x38mm 長x高x深
11x38x23mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT160
反射片型 WL160
對照型 WS/WE160
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image108''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W160T
W160T
尺寸:11x23x38mm 長x高x深
11x38x23
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT160T
反射片型 WL160T
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image165''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W170
W170
尺寸:12x37x29mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-25℃...+55℃
類型:直接反射型 WT170
反射片型 WL2170
對照型 WS/WE170
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image131''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器WT190T
WT 190T
尺寸:15x44.4x30mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN,Q可程式
防護等級:IP67
工作環境溫度:-20℃...+50℃
類型:直接反射型 WTB190T
(背景遮蔽)
直接反射型 WTV190T
       (前景遮蔽)
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image166''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W190
W190 雷射標準型
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN,Q可程式
防護等級:IP67
工作環境溫度:-10℃...+40℃
類型:直接反射型 WTB190L
反射片型 WL190L
對照型 WS/WE190L
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image167''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W190
W 190 雷射高階型
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN
防護等級:IP67
工作環境溫度:-10℃...+40℃
類型:直接反射型 WTB190TL
反射片型 WLG 190T
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image169''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W9-2
W 9-2
尺寸:12x40x22mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN ,Q+
防護等級:IP67
工作環境溫度:-40℃...+60℃
類型:直接反射型 WT9-2
反射片型 WL9-2
對照型 WS/WE9-2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image174''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image168''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W9L
W 9L 雷射型
尺寸:12x40x22mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN
防護等級:IP65
工作環境溫度:-10℃...+50℃
類型:直接反射型 WT9L
反射片型 WL9L
對照型 WS/WE9L
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image164''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W11
W 11-2
尺寸:15x49x41.5mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-30℃...+60℃
類型:直接反射型 WT11-2
反射片型 WL11-2
對照型 WS/WE11-2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image163''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W12-2
W 12-3
外殼材質:金屬
電源電壓:10...30VDC
感應輸出:PNP/NPN,Q+
防護等級:IP67
工作環境溫度:-40℃...+60℃
類型:直接反射型 WT12-3
反射片型 WL12-3
對照型 WS/WE12-32
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image161''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W12L-2
W 12L-2
尺寸:12x49x41.5mm 長x高x深
外殼材質:金屬
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-10℃...+50℃
類型:直接反射型 WT12L-2
反射片型 WL12L-2
對照型 WS/WE12L-2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image159''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W14-2
W 14-2
尺寸:17.6x75.5x33.5mm
長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP/NPN,Q+
防護等級:IP65
工作環境溫度:-25℃...+60℃
類型:直接反射型 WT14-2
反射片型  WL14-2
對照型   WS/WE14-2
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image158''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
小型光電感測器W18-3
W 18-3
尺寸:60x76x31.5mm 長x高x深
外殼材質:塑膠
電源電壓:10...30VDC
感應輸出:PNP / NPN
防護等級:IP67
工作環境溫度:-40℃...+60℃
類型:直接反射型 WT18-3
反射片型  WL18-3
對照型   WS/WE18-3
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image176''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FCN-R.gif''''''''%2C1)%22">
onmouseout_fckprotectedatt="%20onmouseout%3D%22MM_swapImgRestore()%22" onmouseover_fckprotectedatt="%20onmouseover%3D%22MM_swapImage(''''''''Image157''''''''%2C''''''''''''''''%2C''''''''..%2F..%2F..%2Fimage%2FEN-R.gif''''''''%2C1)%22">
(function(sogouExplorer){ sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location); if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); while(a) { hint.push({"text":a.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 0); } })(window.external.sogouExplorer(window,7));
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
